pjeffers(at)talktalk.net Guest
Posted: Thu Aug 20, 2009 12:57 am Post subject: U/C frame |
From: Peter Jeffers [mailto:pjeffers(at)talktalk.net]
Sent: 20 August 2009 08:52
To: 'owner-europa-list-server(at)matronics.com'
Subject: U/C frame
Hi Rob,
The struts that you say ‘appear to be glued in’ are in fact. These struts were incorporated into the U/C frame as a mod way back in 1996 as a mandatory mod. The mod concerned is no 28 and since you will probably not have a copy of it I attach one herewith.
So they will be removable with some local heating and a bit of persuasion. Hot air gun heat should be enough. No flames! As you will notice it is ‘stuck in with Redux 420.
Later build kits had these struts welded in as standard.
Hope this helps.
Pete Jeffers
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Robert Hatton
Sent: 20 August 2009 01:54
Subject: Landing Gear Frame
I am checking over the landing gear after a heavy landing and one of the supports in the Landing Gear Frame appears to have a slight and small crack. Although it still attached to the frame. It does not seem to have been welded (but I could be wrong), it seems to have been glued in, and I wonder if anyone has any advice for how I might remove the support in order to clean up and subsequently re-attach it? I am taking the opportunity to clean up the rest of the Landing gear frame too, which does not display any other issues.
I have attached the diagram and a photo to show what I am looking at, although it is difficult to see the crack. Any advice would be gratefully received.
All the Best
Rob
Robert Hatton
email: roberthatton1(at)googlemail.com
US Cell: +01 303 906 9395
Checked by AVG - www.avg.com
08/19/09 06:03:00
111.81 KB |
1003 Time(s) |
49.87 KB |
1003 Time(s) |
