Overhead Console
Strasnuts
PostPosted: Wed Aug 19, 2009 7:35 pm    Post subject: Overhead Console Reply with quote
I am getting ready to order an overhead console. Anyone have one they REALLY like? or suggest?
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
orchidman
PostPosted: Thu Aug 20, 2009 3:31 am    Post subject: Re: Overhead Console Reply with quote
I have the one that Stein now sells. After you get the top fit, pull it off and fit the overhead while the top is upside down on some sawhorses.
Use some of the rubber seal to seal the aft edge against the rear bulkhead. Install 2 of the scat tube flanges to the aft side of the bulkhead and add 2 naca inlets to provide the air. You will get a bunch of air out of this configuration even with all 4 vents open.
Some of my pictures can be seen at http://www.wingscc.com/N2GB/43-CabinCover/100_2897.html
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
Strasnuts
PostPosted: Thu Aug 20, 2009 4:52 am    Post subject: Overhead Console Reply with quote
That is exactly the info I was hoping for.
Thanks for the reply Orchidman. (Is that a super hero?)
780 Hours
SuperSTOL 60 hours
rv(at)thelefflers.com
PostPosted: Thu Aug 20, 2009 5:41 am    Post subject: Overhead Console Reply with quote
Sean,
Depending on how urgent your need is, Aerosport Products should have a
carbon fiber overhead available shortly. If you were at OSH, you may have
saw Aerosport's carbon fiber instrument panel at either SteinAir's or AFS's
booth. Geoff also had product at the RV-10 HQ at Camp Scholler.
The advantages are that the carbon fiber will be lighter than the fiberglass
overhead. If you have a newer (i.e. pink) canopy, these should fit better
than previously available consoles. With the inconsistencies of the green
canopies, it's amazing that anything fit well.
The product is in the final design stage and Geoff should have the initial
prototype available soon. He had my pink canopy scanned and digitized,
which is why I'm aware of the product. Also, I am also helping him with
getting his website online (which should be live soon).
bob
aircarepros(at)yahoo.com
PostPosted: Thu Aug 20, 2009 6:12 am    Post subject: Overhead Console Reply with quote
Check out www.flightlineac.com.
kearney
PostPosted: Thu Aug 20, 2009 8:29 am    Post subject: Overhead Console Reply with quote
Sean
I have seen Stien's console on a couple of -10s at KOSH and they are very
nice.
If you are a bit more ambitious, you might want to take a page out of John
G's book and make your own.
Attached are a couple of photos of my "amateur built" console that was built
using John's technique. It took a more than a few hours but was good f/g
practise for a neophyte. I am, now more comfortable with f/g although I
still hate sanding the damn stuff.
I plan to have the canopy interior painted in a couple of weeks by a
professional shop. Painting is one thing I don't want to do because I don't
the requisite skills or equipment. and expect it to look quite respectable.
The "long runs" were fabbed using 3/4" foam about 12" wide. The raised vent
holders were fabbed from shaped foam.
The holes in mine are for eyeball lights and Steins eyeball vents. Speaking
of vents, don't bother with anyone else's vents. I bought some Aveo vents
from ACS and sent them back and got Stien's which really are far superior.
Cheers
Les
#40643 - Living in a f/g world
 Filesize:  75.42 KB
 Viewed:  13032 Time(s)
 Filesize:  27.9 KB
Strasnuts
PostPosted: Thu Aug 20, 2009 8:44 am    Post subject: Re: Overhead Console Reply with quote
Those look nice Les. If I had to order today I would buy Stein's with the black vents and map lights. I am very interested in the carbon fiber one. I didn't realize that I should fit the cabin top and then mount the console. That sounds logical. I am just finishing section 29 so I will be ordering soon. I hope the carbon fiber one will be available by the time I am ready.
780 Hours
SuperSTOL 60 hours
robin1(at)mrmoisture.com
PostPosted: Thu Aug 20, 2009 9:14 am    Post subject: Overhead Console Reply with quote
Sean,
I agree with everything said to date. I especially like the build your
own if you want to save $ and have something specific to your needs.
Obviously a few more hours will be needed. That being said when we were
building the AA was the only game in town so we installed that poor
fitting piece of... Fiberglass on our old style canopy. Something about
a monkey and a football. If I were doing it again today I would wait for
the carbon fiber one before deciding. If it's anything like the panels
they offer it should be sensational.
Here is a link to my OH build:
http://www.painttheweb.com/rv-10/console.htm
Robin
rnewman(at)tcwtech.com
PostPosted: Thu Aug 20, 2009 9:17 am    Post subject: Overhead Console Reply with quote
If you are interested in a DIY overhead console here's the link to my web
album. Go to the chapter titled "fiberglass work" starting around photo
111 there's a progression of the overhead I did for my rv-10. It's being
fed air from naca scoops in the rear with the addition of two axial fans to
provide airflow while on the ground.
http://picasaweb.google.com/rcnewman64
Bob Newman
www.tcwtech.com
#40176 glass work and panel and wiring and stuff.
rbibb
PostPosted: Thu Aug 20, 2009 11:15 am    Post subject: Overhead Console Reply with quote
Bob:
OT but that is one nice looking workshop with the Post and Beam
construction. I expected to see Norm Abrams show up in the picture sequence
somewhere....
Not too shabby looking fiberglass boat looking thing with all the holes in
it either.... Smile
Richard Bibb
972-771-2598
972-835-5979 mobile
kearney
PostPosted: Thu Aug 20, 2009 11:21 am    Post subject: Overhead Console Reply with quote
Sean
Amy way you slice it, the canopy and doors will require a lot of work. My
"pink doors" have / had a lot of voids were it appears that the mold was not
clean when the doors were made. As well my "green canopy" was a real treat
cleaning up.
Stien's stuff is great although I used the ACS eyeball LED lights and his
vents.
Cheers
les
Walt Fuller
PostPosted: Tue Dec 15, 2009 4:49 am    Post subject: Re: Overhead Console Reply with quote
Our f/g overhead...went with the short version Very Happy
Walt Fuller
 Filesize:  2.66 MB
 Viewed:  12719 Time(s)
Strasnuts
PostPosted: Thu Dec 17, 2009 11:53 am    Post subject: Re: Overhead Console Reply with quote
Just received my overhead console from Geoff Combs today! Looks really nice and can't wait to install it.
780 Hours
SuperSTOL 60 hours
