Charles Heathco
Posted: Sun Aug 16, 2009 3:41 pm Post subject: brake drag |
I searched arcives and cant find specific procedure to pull the puck and change the o ring, other that a mention of using viton o-rings and high temp fluid. I also found my post of same question 3 yers ago, one answer that only said check free movment on pins. main concern is keeping fluitd from all running out and does spruce have the viton orings? Charlie H/
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Posted: Sun Aug 16, 2009 3:53 pm Post subject: brake drag |
Charlie,
I couldn't get them from spruce when I got them - so I got a bunch. If you can't find a pair, let me know - we'll work something out.
Meanwhile, I'll try to remember where I got mine......
Ralph
Kellym
Posted: Sun Aug 16, 2009 3:54 pm Post subject: brake drag |
Take compressed air blow gun, and apply very loosely to brake line
fitting, to blow the cylinder out of the caliper. All cautions about
having rag to catch it and very low pressure to prevent damage/injury.
charlie heathco wrote:
Quote: | I searched arcives and cant find specific procedure to pull the puck and
orings? Charlie H/
KCHD |
Posted: Sun Aug 16, 2009 4:11 pm Post subject: brake drag |
Maybe I can answer the question as it was asked - now that I read the entire passage.
I changed mine over prior to filling them with fluid in the first place. All I did was blow a little compressed air in and it popped out right in my hand as I was holding the assembly together. It was a little messy with the assembly fliud - but manageable.
HTH,
Ralph
Tailgummer(at)aol.com Guest
Posted: Sun Aug 16, 2009 7:02 pm Post subject: brake drag |
From Randy Lervold's site:
Standard MS replacement O-rings areMS28775-218; 2-218V-75 are the Viton O-rings. Try Ace Seal: http://www.aceseal.com.
The High temp fluid is: . MIL-H-83282. Google Royco 782 or Aeroshell 31.
John D
In a message dated 8/16/2009 4:42:52 P.M. Pacific Daylight Time, cheathco(at)cox.net writes:
Quote: | I searched arcives and cant find specific procedure to pull the puck and change the o ring, other that a mention of using viton o-rings and high temp fluid. I also found my post of same question 3 yers ago, one answer that only said check free movment on pins. main concern is keeping fluitd from all running out and does spruce have the viton orings? Charlie H/
Posted: Sun Aug 16, 2009 7:39 pm Post subject: brake drag |
These were my vendors too! Thanks for the reminder....
rv9jim(at)juno.com Guest
Posted: Mon Aug 17, 2009 5:07 am Post subject: brake drag |
Charlie,
I have a small industrial supply shop and I sell O-Rings.
Needless to say, I installed my brakes with Viton. I also, used the high
temp fluid. I feel more comfortable, if I get into a situation where I
have to really get on the brakes, not have them over heat. I believe the
O-Rings is a #243 but its been several years so a double check on the
part number. The archives have the part number. I also put a small
spring on the master cylinders to be sure that the system would fully
retract when using the brakes. No drag with this system.
Jim
Find a Beauty School
Locate beauty training in your area & request course info today!
http://thirdpartyoffers.juno.com/TGL2141/c?cp=F_ejhBEzr_e_MZbLgEi4ugAAJ1DOX6m7NtFYSFKPhB8gxgzbAAQAAAAFAAAAAHM7vT0AAAAAAAAAAAAAAAAAEiEXAAAAAA==
Charles Heathco
Posted: Mon Aug 17, 2009 10:45 am Post subject: brake drag |
Jim. I found your post re the viton, was couple years ago t I hink, then
when I went to write down the part #, I hit a wrong key and lost that post,
could not find it again. That was Sunday. Seems you said something about
pluging the line to keep fluid from running out, but How did you do that?
Charlie. BTW, you have a couple extr viton ?
Posted: Mon Aug 17, 2009 1:06 pm Post subject: brake drag |
Hi Charlie,
If your system has fluid in it, there is no way you can change
the wheel puck O-Rings with out getting air into the system. (well there
is one way) At this juncture, I would get a AN plug for that line size.
That way when you loosen the line from the brake cyl, you can keep a
large amount (actually a very small amount of fluid) from draining down
and out of the system. I would then, remove the wheel CYL and replace
the O-Rings. Then, replace the wheel cyl and fill the assy with fluid
until it comes out of the fitting that attaches to the brake line. IF
you are quick, and have someone inside that can apply pressure when you
remove the AN plug, you could reconnect the line and not get any air into
the system. Can be done. If you find any softness, then you need to
bleed the system on the side that seems to be soft. I have found that
using a large syringe filled with brake fluid and a small PVC hose from
HD or Lows you can add fluid back into the system and run the bubbles
out. Hint, when adding pressure when reattaching the brake CYL, do it
with just enough pressure to force fluid out of the line as the AN
fitting comes off. Quickly reattaching the line will get it done with
out air. With all the air out of the wheel CYL, it should work fine. I
always have a lot of paper towels on hand especially to cover the brake
assy. from getting fluid on the disk etc. Just some thoughts that may
help you.
Jim
Best eMarketing Solution
Automate Your Online Marketing and Boost ROI. Download the Guide Now.
http://thirdpartyoffers.juno.com/TGL2141/c?cp=E8fr_uTMLW7nLNnuc-Fv0QAAJ1DOX6m7NtFYSFKPhB8gxgzbAAUAAAAAAAAAAAisnD0yRXkW0eM6nONFWkjvXf_ZAAAAAA==
Charles Heathco
Posted: Mon Aug 17, 2009 6:07 pm Post subject: brake drag |
Thanks Jim, the info has been very helpful, Ill have to get ahold of the
viton, I will hae to go back and check, I beleive Ralph Capen emailed the
viton part # yesterday. or someone if mem serves (desnt serve like it used
to )
gmcjetpilot
Posted: Tue Aug 18, 2009 3:16 am Post subject: brake drag |
Service the Brakes,
Replace the Break Pads***
Clean and lube moving parts (brake pad plates pins removed corrosion)**
(be careful keep lube off of disk and pads clean)
Bleed carefully with help bottom up top down
Might as well replace bearings
Might as well rotate tires*
* (Remove tire from rims, re-install on opposite rim balance)
** (Consider an overhaul of caliper disassemble, inspect, new O-ring, corrosion in the piston bore can cause breaks to stick, moisture can get into the cylinder on the outer side of the O-ring and cause corrosion.)
*** When the pads get worn, even look like they have life this will cause brakes to stick. The caliper piston has to extend further and it can get cocked ever so slightly, since so little is engaged with in the caliper body. This causes it to stick extended, even lock.
Inspect Inspect Inspect, clean, service, remove and replace anything that is not perfect.
That should solve your problems
Cheers George
Posted: Tue Aug 18, 2009 6:07 am Post subject: brake drag |
Not sure what this meant .... but do not lube the pins. They're
designed to work dry. Almost any lube will attract dirt and really gum
up the works.
Linn
Cheers George
Kellym
Posted: Tue Aug 18, 2009 8:51 am Post subject: brake drag |
Not true. Caliper pins should be lubed with silicone grease intended for
disk brakes. Dry they will wear.
Linn Walters wrote:
> Service the Brakes,
up the works.
Linn
KCHD |
Posted: Tue Aug 18, 2009 9:10 am Post subject: brake drag |
Could you point me to the instructions that say to do that???
Linn
>> Service the Brakes,
> gum up the works.
> Linn
Kellym
Posted: Tue Aug 18, 2009 1:10 pm Post subject: brake drag |
http://members.eaa.org/home/homebuilders/building/landing/1Your%20Brake%20Installation.html?
Is one location. Look near the bottom of the article regarding anchor pins.
Linn Walters wrote:
Linn
> for disk brakes. Dry they will wear.
>>> Service the Brakes,
>> gum up the works.
>> Linn
KCHD |
Posted: Tue Aug 18, 2009 2:03 pm Post subject: brake drag |
OK, I can accept that. For most of us 'lube' means grease. The
important word is 'dry', and here is what they said:
Keep the anchor bolts free of rust and lubricate them with a dry
lubricant spray like G. E. Silicone or graphite. Don't use your old
favorite WD-40, or any kind of wet grease as they will only attract dirt
and compound the wear.
I was taught to clean any dirt, rust etc, and reassemble dry. Never
seen any pins assembled that way 'wear out' except where something else
failed.
Linn
> Linn
>>>> Service the Brakes,
>>>> corrosion)**
>>> gum up the works.
>>> Linn
Kellym
Posted: Tue Aug 18, 2009 2:11 pm Post subject: brake drag |
All the higher time brakes I inspect show wear, which comes from
combination of rust and lack of lube. While silicone spray will work,
IMHO it is inadequate to last from one annual to the next. A grease like
DC-4 or other silicone grease accomplishes the same thing, with much
more staying power and will reduce chance of rust.
Your modern cars all use floating calipers, just like your standard
Cleveland calipers, and they all specify the same silicone grease, and
often supply it with replacement pads or hardware kits. If the anchor
pins are dry, they will get mud from splash drying on them and that will
promote both rust and wear. Spray silicone does little to protect
against that. Graphite is not good around aluminum and magnesium.
But, you are experimental, and you can experiment all you want.
failed.
Linn
> pins.
>> Linn
>>> Linn Walters wrote:
>>>> <pitts_pilot(at)bellsouth.net>
>>>>> Service the Brakes,
>>>>> corrosion)**
>>>> gum up the works.
>>>> Linn
KCHD |
