VOM Troubles
Dennis Johnson
PostPosted: Sun Aug 16, 2009 2:25 pm    Post subject: VOM Troubles Reply with quote
I have a Fluke model 87 digital VOM (Volt-Ohm-Milliammeter) that has just started discharging the internal 9 volt battery in less than a month while it is turned OFF. I've had this meter for 15 years and used it throughout building my airplane, as well as various hobbies before that, so I guess I got my money's worth out of it, but I'm puzzled.
Using another meter, I measured about 10 microamps current out of the Fluke's internal 9 volt transistor radio battery while it's turned OFF. If a 9 volt transistor radio battery holds 0.5 amp-hours, then with 10 microamps, the battery should last 50,000 hours. But the last two batteries lasted about a month each. They test good before I put them in and have an expiration date of 2013.
First, is my arithmetic correct? I think a milliamp is 0.001 amps and a microamp is 0.000001 amps. I think a 10 microamp current through a half amp-hour battery would take 50,000 hours to deplete the battery.
Second, did I read my digital VOM correctly? Using a nice German BBC VOM, set on the 2 milliamp scale, it reads .009. Using a cheap Harbor Freight digital VOM, set on the 200 microamp scale, it reads 09.5.
You can see that something is wrong, either with my math or the way I'm reading the scale on the VOMs. Or maybe the Duracell fairies are sneaking in and sucking all the juice out of my batteries?
I talked to Fluke customer support and he said there was no published spec on the current draw from the battery while it was turned off and couldn't say if mine was bad or not. My model 87 isn't supported anymore and he wanted me to buy the new version.
Any ideas?
Dennis Johnson
Lancair Legacy, 330 flight hours
PostPosted: Mon Aug 17, 2009 6:09 am    Post subject: VOM Troubles Reply with quote
At 05:25 PM 8/16/2009, you wrote:
--> AeroElectric-List message posted by: "Dennis Johnson" <pinetownd(at)volcano.net>
Great instrument. I've had one since they came
on the market.
[img]cid:.0[/img]
A Duracell 9v has published performance data as shown
above. The smallest discharge curve is for 2 ma
so with a end of life voltage of say 7 volts, yes
the device should deliver 500 mAh of service at
2 mA and MORE at still smaller drains. The internal
resistance of the battery becomes less significant
as current demands drop . . .
Yup, that's about right.
The interpretation of your observations seems
correct.
My model 87 is 100 miles away right now
but I'll be back in that shop tomorrow or
Wednesday. I'll duplicate your experiment
so we can compare results. In the mean time,
perhaps someone else here on the List has
a model 87 Fluke and can do their own
investigation.
( -Thomas Paine 1776- )
 Filesize:  50.55 KB
 Viewed:  9992 Time(s)
david.nelson(at)pobox.com
PostPosted: Mon Aug 17, 2009 9:12 am    Post subject: VOM Troubles Reply with quote
I've a Fluke 87 so I'll check it out this PM and report back.
/\/elson
~~ Lately my memory seems to be like a steel trap .... without any spring. ~~
on the market.
Emacs!
correct.
of my batteries?
investigation.
simon(at)synchdes.com
PostPosted: Mon Aug 17, 2009 4:51 pm    Post subject: VOM Troubles Reply with quote
Dennis, your math is correct. You will get 50,000 hrs out of a 0.5 Amp-Hr
battery at 10 uA. I took my trusty Fluke 87 into work today to have its
battery current measured. It was 7.9 uA. There is something wrong with
your meter. I'm guessing one of the components has failed or there is FOD
somewhere causing low resistance.
If it is FOD, possibly you can solve it by cleaning the PWB or the rotary
switch. This particular problem may be exacerbated by the auto-turn off
feature, which is controlled by a microcontroller. The reason is because a
FOD can cause a small amount of current to flow in the right place and tell
the microcontroller to turn the whole meter on and keep it on. It may be
worth it to blow clean both the PWB and the rotary switch and then retest
it.
I've had this meter since the 1980s, and I'd hate to see it go. It's a
really good meter!
Good luck.
Simon Ramirez
Copyright 2009
Dennis Johnson
PostPosted: Mon Aug 17, 2009 6:00 pm    Post subject: Re: VOM Troubles Reply with quote
Thanks to Bob for confirming that my calculations weren't off by a few decimal points. Thanks to Simon for measuring the current draw of his Fluke 87.
Simon's current draw, when turned off, was 7.9 micro amps. Mine was 9.5 micro amps. So it seems like my meter is probably okay. I'll try blowing out dust and I'll go with another new 9 volt battery and hope the gremlins leave me alone. Could be a bad batch of 9 volt batteries? Still a puzzle.
Thanks, guys!
Dennis Johnson
ulflyer(at)verizon.net
PostPosted: Mon Aug 17, 2009 8:25 pm    Post subject: VOM Troubles Reply with quote
Hey Guys,
Can't say about the batteries you have but the Duracells are not the
battery they used to be. You used to be able to put them into a
piece of equipment and not have to worry about them leaking, were
great for meters and cameras, not so any more. If I had to put my
finger on it I would say it started when they came out with their
more expensive (longer life) ultra's. Ever wonder what's inside a
Duracell battery, see the link below.
http://www.extremetech.com/article2/0,3973,1155268,00.asp
Sounds like your going to need a new Du-witcher - cost $150 bucks -
that's the thing the test leads plug into to.
Note, if you have a Duracell (alkaline) battery that has leaked,
clean it up best you can using white vinegar & Q--Tips for the tight
spots. Alkaline is a base - when it leaks it is quite aggressive and
can eat things up in a short time. It can be neutralized with a acid
which vinegar supplies.
jerb
of his Fluke 87.
Thanks, guys!
Dennis Johnson
PostPosted: Tue Aug 18, 2009 8:33 am    Post subject: VOM Troubles Reply with quote
At 11:22 PM 8/17/2009, you wrote:
Hey Guys,
piece of equipment and not have to worry about them leaking . . .
I've not experienced a leaking incident with
flashlight cells in years. I did loose a digital
caliper last month because an alkaline button cell
leaked . . . but it was a case where the tool was
stored for a long time with a discharged cell. Our
battery powered devices are working tools that generally
don't get stored for long periods of time with dead
cells.
. . . they were great for meters and cameras, not so any more.
I've not detected any 'changes' in these products
tendencies to leak in our regular change-out working
environment. Has anyone else on the list experienced
a messy event with their alkaline cells of any brand?
jindoguy(at)gmail.com
PostPosted: Tue Aug 18, 2009 9:08 am    Post subject: VOM Troubles Reply with quote
Bob, When I had my LSA inspected I found the Duracells in the ELT (dated to 2010) had leaked all over the inside. Later that summer I had a maglite also taken out of commission by some Duracells. In both cases they were D size. That was last year. Except for the new ELT in which I have to, I don't buy Duracell anymore.  Going by a study you did a few years back, I buy the chicom batteries at Dollar General. Can't tell you anything about electrical characteristics, but I do know that we've never had one of any size leak.
Rick Girard
On Tue, Aug 18, 2009 at 8:45 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
--> AeroElectric-List message posted by: jerb <ulflyer(at)verizon.net (ulflyer(at)verizon.net)>
Hey Guys,
Can't say about the batteries you have but the Duracells are not the battery they used to be.  You used to be able to put them into a piece of equipment and not have to worry about them leaking . . .
  cells.
http://forums.matronics.com
le, List Admin.
trumanst(at)neitel.net
PostPosted: Tue Aug 18, 2009 3:36 pm    Post subject: VOM Troubles Reply with quote
Bob,I had the Duracell D's in my ETL leak also.
I had the Batterys.com AA cells leak in my Lowrance 2000C. Had Duracell AA cells swell in my Mag Lite.
Had one hell-of-a time shaking it out. Did get it out though. A bit of a mess to clean up, but no apparent damage to any of my devices.
Kevin Boddicker
Tri Q 200 N7868B 140.6 hours
Luana, IA.
Hey Guys,
cells.
- The AeroElectric-List Email Forum -
--> http://www.matronics.com/Navigator?AeroElectric-List
- MATRONICS WEB FORUMS -
--> http://forums.matronics.com
- List Contribution Web Site -
Thank you for your generous support!
--> http://www.matronics.com/contribution
raymondj(at)frontiernet.n
PostPosted: Thu Aug 20, 2009 9:48 am    Post subject: VOM Troubles Reply with quote
Bob,
I've had several Duracell batteries leak in the last couple of years.
They were C & D cells in Maglight flashlights. They were kept in
vehicles, which resulted in them being cold soaked to temps of -20 deg
f. I attributed their failures to the cold exposure, but that was pure
conjecture. They were installed in the fall and found to have leaked in
the spring.
Raymond Julian
Kettle River, MN
"Hope for the best, but prepare for the worst"
<nuckolls.bob(at)aeroelectric.com>
> Hey Guys,
cells.
