Gaskets For Constant Speed Props & Misc...
Site Admin
PostPosted: Sat Aug 15, 2009 8:50 pm    Post subject: Gaskets For Constant Speed Props & Misc... Reply with quote
Is there a gasket to seal the CS prop to the crankshaft? Looks like there is a taper fitting between the prop and the crankshaft. What are the torque values for the prop bolts? I have a 72" Hartzell prop I got new from Van's, but I don't find the installation instructions in my pile of stuff. Anybody have any?
Thanks!
RV-8 #82880 N998RV
http://www.mykitlog.com/dralle
FWF
dave.saylor.aircrafters(a
PostPosted: Sat Aug 15, 2009 9:09 pm    Post subject: Gaskets For Constant Speed Props & Misc... Reply with quote
There's an O-ring in the ID of the prop that slips over the flange protruding from the crank.  Lube it with motor oil or vaseline.  If it's not in the prop already, it's still in the box or with the manual.
The torque should be on a label on the prop.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
