IO-390 Governor Oil Line...?
Site Admin
PostPosted: Sat Aug 15, 2009 2:38 pm    Post subject: IO-390 Governor Oil Line...? Reply with quote
Van's includes a document called "Service Instruction No. 1435" describing a long, aluminimum tube that connects from the front of the engine to the rear where the prop governor is attached (see attached photo).
Since the prop governor on the IO-390 is mounted up front, is there even such a tube for this application? If so, what's the part number and where's a good place to get one?
Thanks!
RV-8 #82880 N998RV
http://www.mykitlog.com/dralle
Engine and Exhaust Mounted; Now What...?
 Filesize:  195.47 KB
 Viewed:  2469 Time(s)
 Filesize:  229.36 KB
khorton01(at)rogers.com
PostPosted: Sat Aug 15, 2009 4:08 pm    Post subject: IO-390 Governor Oil Line...? Reply with quote
attached photo).
No. With the front-mounted governor, all the oil passages are
internal to the engine.
Kevin Horton
RV-8 (Flight Test Phase)
Ottawa, Canada
http://www.kilohotel.com/rv8
