n1cxo320(at)salidaco.com Guest
Posted: Wed Aug 12, 2009 5:35 pm Post subject: Oil pressure variation |
I am puzzled by this: my RV6A with a Lyc O-320 uses no oil between changes, isn't leaking oil, and oil temps are completely normal.
On the way back from OSH I noticed the oil pressure (as measured on an International Electronics digital OPT-1 meter) dropping to 20PSI - it normally runs 72-74 PSI. I was running at 2300 RPM so I increased engine RPM to 2500 and the oil pressure immediately climbed back to normal and stayed there for (perhaps) an hour and the did it again. Increase in RPM again put the oil pressure into normal range and it stayed there for the rest of the flight.
My thought it that the sensor may be at fault, but at $123 to replace it I want to eliminate everything else I can think of before buying a replacement.
What is your guess, ideas, suggestions, hints, etc. Any input would be appreciated.
John at Salida, CO
burnsm(at)suddenlink.net Guest
Posted: Wed Aug 12, 2009 6:25 pm Post subject: Oil pressure variation |
John,
Sounds like something going on with the oil pressure relief valve to me.
I’d take it out, look it over real good and clean it well. Some little something my have gotten stuck on the steel ball.
Just something to try.
Mark
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Fasching
Sent: Wednesday, August 12, 2009 8:34 PM
To: rv-list(at)matronics.com
Subject: Oil pressure variation
John at Salida, CO
| Quote: | | http://www.matronics.com/Navigator?RV-List | 0123456789
No virus found in this incoming message. Checked by AVG - www.avg.com 270.13.53/2299 - Release Date: 08/12/09 18:12:00 [quote][b]
jim jewell
Joined: 09 Jan 2006 Posts: 82 Location: Kelowna B.C. Canada
mmckenna(at)bellsouth.net Guest
Posted: Thu Aug 13, 2009 5:10 am Post subject: Oil pressure variation |
John,
Poor electrical connections will also cause the symptoms you are experiencing. Check all connections at the sensor and instrument ends. Also look for any possible intermittent short to ground along the sender wire.
Mike Mckenna
[quote] --
ronlee(at)pcisys.net Guest
Posted: Thu Aug 13, 2009 5:24 am Post subject: Oil pressure variation |
Jim, you are exactly right. I was troubleshooting something like this on my RV.
Added another oil pressure gauge to verify my system. When that confirmed
the readings were right I checked the oil screen and it was full of metal.
I am not saying that it is the case with you John but I would check things
as Jim suggested before flying again.
Ron Lee
mrobert569(at)hotmail.com Guest
Posted: Thu Aug 13, 2009 6:24 am Post subject: Oil pressure variation |
Everyone else has made good suggestions. After all that there is one more thing to keep in the bacvk of your head. It may not be an issue but then again...... And that would be the oil pump. If the gears in the oil pump are starting to go it can display the symptoms you gave. If all else looks good then this amy be where you will end up looking especially if you can't find evidence in the engine logs that the AD about this was ever accomplished. Check everything else first C then ground run it some more with a direct reading pressure gauge before you do any tearing into.
Mike Robertson
Das Fed
Subject: RE: Oil pressure variation
Date: Thu C 13 Aug 2009 09:09:01 -0500
John C
Mike Mckenna
Posted: Fri Aug 14, 2009 10:57 am Post subject: Oil Pressure Variation |
I appreciate all the suggestions. This morning I drained the oil. Opened the oil pressure relief valve, looked clean, but swabbed it 6 times with a q-tip dipped in acetone to be sure. Spring was OK.
Opened the oil screen...clean as it could be...
Changed oil filter...cut open old filter, put the filter material in acetone and washed it out real good...used a magnet to see if there was any material in the bottom of the bucket...came up perfectly clean..absolutely nothing. Visual inspection of the filter material showed nothing...no little sparkles or any foreign material.
Ran the engine after the oil change....pressure came up immediately and ran about 62psi at 900rpm, and came up to 80psi at 1700 rpm...oil was at ambient temp, around 75-deg F. All seems OK.
Will fly tomorrow and get altitude and stay within gliding range of the airport and fly for an hour and see what happens. I hope there was some small bit of junk on the ball in the pressure relief valve that I did not see.
My oil pump gear has the last AD per Carter who did the overhaul of the engine, that now as 513-hours on it. Never has used oil, always had changes of Aeroshall 15-50 every 4 months...never missed a change of oil or filter.
Will post results.
John at Salida, CO
n1cxo320@salidaco.com
Posted: Sat Aug 15, 2009 11:46 am Post subject: Re: Oil pressure variation |
I flew this morning for half an hour, circling near the airport just in case, and there was never a hint of problem with oil pressure. Stayed at 73/74 the entire time. On run up on the pad I saw these rpm/oil pressure readings: 800rpm/56psi, 1,000/62, 1200/67, 1,300/70, 2250/74. In flight 2,300/74 and rock steady at 73 or 74 psi.
I can only HOPE that the oil pressure relief valve cleaning did the trick. More flying in the next few days to verify. (But this is all taking time away from my RV-12 construction !)
Thanks again for the suggestions folks.
John at Salida, CO
