Fuel Flow variations
Goto page 1, 2  Next
Deems Davis
PostPosted: Sat Aug 15, 2009 12:25 pm    Post subject: Fuel Flow variations Reply with quote
Is anyone experiencing variations in fuel flow readings?
I am experiencing variations in fuel flow readings of up to .5 gph.
Typically the variations are .1-.3 gph. I've got the flow meter mounted
in the tunnel per Van's plans. And after talking to Don Rivera (at) Airflow
Performance, he believes that the variations are due to the location of
the meter. Apparently the optimum location is between the servo and the
distribution spider. I've searched the archives, as I recalled some
dialogue on this subject and basically verified what Don said about
mounting location.
I'm interested to know if others are experiencing similar readings and
any attempts to improve or correct the situation.
Deems Davis N519PJ
http://deemsrv10.com/
Kelly McMullen
PostPosted: Sat Aug 15, 2009 1:13 pm    Post subject: Fuel Flow variations Reply with quote
There are differing opinions as to where it should go. The problem with putting it in the line to the spider is that line normally is mostly vertical, and there is very little horizontal line to insert the sender.  EI, which I think  uses the same sender recommends between the mechanical fuel pump and the fuel servo, unless it is a Continental time injection that returns fuel to the tank full time. It comes down to where it will conveniently fit, and have a straight, horizontal line/hose for several inches before the sending unit.
.1-.2 gph fluctuation is pretty normal, more than that may be a problem. The connections between the sending unit and the instrument can be an issue.
On Sat, Aug 15, 2009 at 1:24 PM, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:
[quote]--> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)>
I am experiencing variations in fuel flow readings of up to .5 gph.  Typically the variations are .1-.3 gph. I've got the flow meter mounted in the tunnel per Van's plans. And after talking to Don Rivera (at) Airflow Performance, he believes that the variations are due to the location of the meter. Apparently the optimum location is between the servo and the distribution spider. I've searched the archives, as I recalled some dialogue on this subject and basically verified what Don said about mounting location.
I'm interested to know if others are experiencing similar readings and any attempts to improve or correct the situation.
Deems Davis N519PJ
http://forums.matronics.com
le, List Admin.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
rv(at)thelefflers.com
PostPosted: Sat Aug 15, 2009 1:15 pm    Post subject: Fuel Flow variations Reply with quote
Deems, good timing on your question. Ivan Kristensen and I were having the
same discussion the other day. We too would like to hear from anyone that
mounted there fuel flow sensor in a non-standard location to minimize the
impact of when the fuel pump is engaged.
My memory seems to think that Gary B. may have done this and may have some
data since he's flying now.
Bob
#40684
dlm46007(at)cox.net
I think you need to put things in perspective. Everyone thinks that if you
have a digital reading that's the last word. It used to be analog needles
and a printed scale on the dial. Fluctuations occurred all the time but
measurements were not precise enough to matter or be discernible. A variety
of things including varying temps or pressures can cause a sensor to output
differently. We are measuring milli and micro values of electricity. It is
quite possible that the fluctuations are within the accuracy of the sensor
but the measurement of the volt or pressure or gph on a digital gauge
pretends to be more precise. That said: my fuel flow bounces around by .1 to
.3 with the engine driven pump. Turn on the boost pump and see the same
mixture setting show many gallons more flow.
wcurtis(at)nerv10.com
PostPosted: Sat Aug 15, 2009 1:24 pm    Post subject: Fuel Flow variations Reply with quote
Yes, this is the consensus of AFS, EI, Airflow et al.  For this reason as well as easier access to the transducer, I have moved my fuel flow transducer from the tunnel to the servo output port.  With some additional parts from AN Plumbing, I was able to put it there without any change to the hoses.
William
http://wcurtis.nerv10.com/
On Sat, Aug 15, 2009 at 4:24 PM, Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)> wrote:
Deems Davis N519PJ
br> www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
Matt Dralle, List Admin.
orchidman
PostPosted: Sat Aug 15, 2009 1:38 pm    Post subject: Re: Fuel Flow variations Reply with quote
I have no problems following AFS's recommendations as others here have also noted. The engine shop provided me with the new hoses.
 Filesize:  96.58 KB
 Viewed:  9423 Time(s)
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
speckter(at)comcast.net
PostPosted: Sat Aug 15, 2009 3:29 pm    Post subject: Fuel Flow variations Reply with quote
I too get variations using the stock location. In a previous aircraft I had
it located between the servo and the spider with good success, but as
pointed out, I did not have digital readout on it. I am tempted to move
mine, but would really like to get input from those who have found a rock
steady location.
Gary Specketer
rbibb
PostPosted: Sat Aug 15, 2009 4:03 pm    Post subject: Fuel Flow variations Reply with quote
On the Matronics web site Matt used to sell a small spherical device to put
in the line to dampen out pulsations to improve accuracy or minimize
disturbances. Sort of like a "water hammer" shock absorber put in your
water line at home.
Might be worth a try...
See: http://www.matronics.com/fuelchec/dampener.html
Richard Bibb
972-771-2598
972-835-5979 mobile
PostPosted: Sat Aug 15, 2009 4:04 pm    Post subject: Fuel Flow variations Reply with quote
I found photo's of Rob Hickman's installation:
http://lh6.ggpht.com/RobHickmanAFS/SNltW4FJUII/AAAAAAAAAQo/sX7EW06y0Zg/s800/
Gary Blankenbiller's at:
http://www.wingscc.com/n2gb/FF1-Engine/100_3207.jpg
Looking at the install procedures for the EI FT-60 on EI's site (which is
used by several of the EFIS vendors):
1. Find a convenient location between the Fuel Servo and Flow
Divider and away from any hot exhaust pipes to suspend the
Fuel Flow Transducer
dave.saylor.aircrafters(a
PostPosted: Sat Aug 15, 2009 4:35 pm    Post subject: Fuel Flow variations Reply with quote
FF is definitely more stable measured between the servo and the spider.  I moved my sender because of the erroneous reading with the boost pump on, and I'm happy with the results.  I do see very minor fluctuations now and then, but I suspect that with an analog instrument, you would never notice.  It's just that digital instruments are so...digital.
On Sat, Aug 15, 2009 at 4:25 PM, gary <speckter(at)comcast.net (speckter(at)comcast.net)> wrote:
[quote] --> RV10-List message posted by: "gary" <speckter(at)comcast.net (speckter(at)comcast.net)>
steady location.
Gary Specketer
AV8ORJWC
PostPosted: Sun Aug 16, 2009 8:49 am    Post subject: Fuel Flow variations Reply with quote
Matt Dralle offered a small but well built fluid accumulator which can
assist the dampening pressure fluctuations of pump actions. If the
accumulator is used and placed prior to the sensor the degree of
fluctuation should be reduced at the point of indication.
John
#40600
rv10builder(at)verizon.ne
PostPosted: Sun Aug 16, 2009 10:50 am    Post subject: Fuel Flow variations Reply with quote
I agree there is a proven improvement with the forward location and with
Matt's ball (which btw would never fit for me in my limited space) however I
remind the group the flip side to this. A while back Tim Olson and the
Grumpy General, two people I respect, mentioned that there is a brief time
the pump is actually even on, take off and landing. The time it actually
caused an issue was rather brief and played a minor issue in the total
scheme of things.
From a part of the e-mail by Tim, written last January- " While I do see the
increase in fuel flow, just like you do, with mine installed in the stock
location, it doesn't cause me any headaches. I only use the fuel boost for
maybe 60 seconds during takeoff, and even on landing if I do, it's only for
about 60 seconds again....just that timeframe that I'm under about 500' AGL
If you only use it a couple minutes during the flight, it won't change those
readings much at all. I've consistently been accurate to within about .1-.2
gallons over a 40-45 gallon flight, so it's just not worth worrying about.
In over 400 hours I've never had a fuel fill up that had any noticeable
amount of difference over what the totalizer told me I should be adding."
By all means consider moving the location to the front, especially if you
haven't done the install already per the plans, but for those who already
have the sensor in place, think about this before you make a modification
from the Van's plans- new hoses?, new setups?.. ask yourself with this
information if it's worth the effort?
Just bringing a difference perspective for anyone who worried about this, as
I did initially.
Tim may have changed his mind on this, if so Tim please advise.
Pascal
#40720
Sent: Sunday, August 16, 2009 9:45 AM
Subject: RE: Fuel Flow variations
John
#40600
Tim Olson
PostPosted: Sun Aug 16, 2009 11:20 am    Post subject: Fuel Flow variations Reply with quote
Nope, I'm still very happy. As far as access to the sender goes, I've
never had reason to touch it since it was first wired in. It works
plenty well for me and I can usually plan on the reading being dead on
when I refuel.
Tim
with Matt's ball (which btw would never fit for me in my limited
space) however I remind the group the flip side to this. A while
back Tim Olson and the Grumpy General, two people I respect,
mentioned that there is a brief time the pump is actually even on,
take off and landing. The time it actually caused an issue was
rather brief and played a minor issue in the total scheme of things.
> do see the
stock location, it doesn't cause me any headaches. I only use the
fuel boost for maybe 60 seconds during takeoff, and even on landing
if I do, it's only for about 60 seconds again....just that timeframe
that I'm under about 500' AGL If you only use it a couple minutes
during the flight, it won't change those readings much at all. I've
consistently been accurate to within about .1-.2 gallons over a
40-45 gallon flight, so it's just not worth worrying about. In over
adding."
if you haven't done the install already per the plans, but for those
who already have the sensor in place, think about this before you
make a modification from the Van's plans- new hoses?, new setups?..
ask yourself with this information if it's worth the effort?
this, as I did initially.
Pascal
#40720
> can
> John
> #40600
PostPosted: Sun Aug 16, 2009 3:14 pm    Post subject: Fuel Flow variations Reply with quote
I notice fluctuations while I am trying to adjust LOP. Like Tim, I can live
with the change during the operation of the boost pump, but the LOP
adjustment is more irritating.
Gary Specketer
gengrumpy(at)aol.com
PostPosted: Sun Aug 16, 2009 3:41 pm    Post subject: Fuel Flow variations Reply with quote
Same for me.
And on hot days if the engine driven pump pressure falls too low, I
use the electric fuel pump to keep the pressure up until I get to
altitude.
Totalizer and fuel used consistently accurate.
grumpy
N184JM
I've never had reason to touch it since it was first wired in. It
works plenty well for me and I can usually plan on the reading being
dead on when I refuel.
Tim
>> do see the
> timeframe that I'm under about 500' AGL If you only use it a couple
> minutes during the flight, it won't change those readings much at
> all. I've consistently been accurate to within about .1-.2 gallons
> noticeable amount of difference over what the totalizer told me I
> should be adding."
> those who already have the sensor in place, think about this before
> you make a modification from the Van's plans- new hoses?, new
> setups?.. ask yourself with this information if it's worth the
> effort?
> Pascal
> #40720
> From: "John Cox" <johnwcox(at)pacificnw.com>
> To: <rv10-list(at)matronics.com>
>> can
>> John
>> #40600
jump2(at)sbcglobal.net
PostPosted: Sun Aug 16, 2009 5:15 pm    Post subject: Fuel Flow variations Reply with quote
Has any one read their manuals from EI or JPI and How they are to mount their Transducer? You can learn a lot from manuals. Or go look at a shop and see how the Certified group put theirs in.,
Has anyone thought maybe your sucking air in your line just enough? Not big enough to see fuel stain but still sucking air. How about your bypass is opening and closing.Anything passing through you mechanical pump. Just a little leak passing by?
Everyone in Texas know how their fuel acst when its 100degree plus and just think when you stop and have that 100 dollar hamburger and then go and get in it to crank up.
These are just some of my thougths not knowing everyones paticular case but it is food for thought.
Keep asking, but try reading, sometime you learn more then you need.
Ok I'm not here to answere .
Patrick Thyssen
Yes I'm flying sorta When the electrons let me.
--- On Sat, 8/15/09, William Curtis <wcurtis(at)nerv10.com> wrote:
Subject: Re: Fuel Flow variations
Date: Saturday, August 15, 2009, 4:24 PM
William
On Sat, Aug 15, 2009 at 4:24 PM, Deems Davis <[url=/mc/compose?to=deemsdavis(at)cox.net]deemsdavis(at)cox.net[/url]> wrote:
--> RV10-List message posted by: Deems Davis <[url=/mc/compose?to=deemsdavis(at)cox.net]deemsdavis(at)cox.net[/url]>
Deems Davis N519PJ
http://www.matronics.com/Navigator?RV10-lank" href="http://forums.matronics.com">http://forums.matronics.com
dlm46007(at)cox.net
PostPosted: Sun Aug 16, 2009 5:34 pm    Post subject: Fuel Flow variations Reply with quote
The GRT display with the EIS system has a lean function and by using it EGTs
are used rather than fuel flow. GRT users can invoke the lean function and
watch the individual cylinders peak and then go lean: first to peak is boxed
green? And last to peak is boxed white? If all the minus numbers for EGT
data are between 0 to -30 and the engine is smooth I then look at the fuel
flow.
Deems Davis
PostPosted: Mon Aug 17, 2009 8:36 am    Post subject: Fuel Flow variations Reply with quote
Thanks to all for their responses on this topic.
What's driving me on this, is that I want to balance my injectors so I
can begin to play with LOP, and I'd like to have a more stable
measurement when collecting the data for the injectors. Thanks to the
link on Matt's bulb. I've got an email into him with some questions. Has
anyone had any experience with this? I'm just wondering if this is one
of those thing that should work i theory, but..... ? Also someone
mentioned a lack of space to install. I've asked Matt for dimensions. If
it works this might be the easiest 'fix'. We'll see,
Deems Davis N519PJ
http://deemsrv10.com/index.html
pitts_pilot(at)bellsouth.
PostPosted: Mon Aug 17, 2009 8:55 am    Post subject: Fuel Flow variations Reply with quote
I may be wrong here, but I don't think you get any valuable info from
fuel flow when trying to match injectors. The data point is EGT ......
which you work towards balancing the readings.
What info do you get from fuel flow in this scenario?
Linn
Deems Davis N519PJ
rene(at)felker.com
PostPosted: Mon Aug 17, 2009 9:12 am    Post subject: Fuel Flow variations Reply with quote
You plot individual cylinder peak against fuel flow. Trying to get them all
to peak within .2 gph or better. Because of sensor placement errors and
sensor accuracy, the actual EGT does not matter, just at what fuel flow it
peaks.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Goto page 1, 2  Next
Page 1 of 2
