Lynn Matteson
Posted: Sat Aug 15, 2009 10:21 am Post subject: ROP versus LOP...might be off-topic for some |
Over the last week, I've had some fun making some tests with my newly-
installed Rotec TBI-40 mixture-adjustable, carburetor-replacement
device on my Jabiru engine. I don't know whether two of these units
will work on a Rotax, so many of you might want to hit the delete key
right now.
For the most part, I was flying it LOP (lean-of-peak), but yesterday
I made a flight and decided that I would try ROP (rich-of-peak). In
flying LOP, the articles I've read say to keep the power requirements
low, and LOP will work and you won't burn the engine down. I was
amazed that this LOP thing even works at all, let alone work as well
as I've found that it seems too....I guess I'm still a bit of a
skeptic. After all, if going lean is a bad thing, how can going even
leaner be a good thing? I won't argue whether or not it's a good or
bad thing, and there are those of you that may not be able to do any
leaning at all, as I was until I got this unit.
Three days ago, I made two trips totaling 475 miles, using LOP
settings, and yesterday I made a 310-mile trip, using ROP settings. I
had flown the 475 miles leaning out the engine until peak EGT, then
leaning more until the engine was obviously low on power, and I
contentedly flew at this setting, watching the scenery crawl by.
Yesterday I decided to actually GO somewhere, and never mind the fuel
saving, I just wanted to get there, so I decided to try ROP.
Here are the average numbers from those trips:
LOP: 27.77 miles per gallon; 3.3 gallons per hour; 93.14
miles per hour
ROP: 23.66 miles per gallon; 4.37 gallons per hour; 103.3 miles per
hour
Altitudes on all of these flight were anywhere from 3000' MSL (with a
base of 1000') to 10,000 MSL, with throttle settings from 2600 rpm to
3050. Fuel flow as seen on the gauge, ranged from 2.5 gallons per
hour to 5.0 not including takeoffs, but including climbs.
So you can see from these figures (admittedly a low number of
samples) that it does pay to tweak the mixture, and even if flown
LOP, the speed is not too bad.
Lynn Matteson
Jabiru 2200, #2062, 737.3 hrs
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Sat Aug 15, 2009 2:10 pm Post subject: Re: ROP versus LOP...might be off-topic for some |
Lynn, being that I am a two stroke guy the word lean gets my attention right away. I guess it is different for 4 stroke engines.
I learned to fly in a Cherokee 180. The instructions for best economy in the POH for that airplane were. Lean until max EGT is reached then continue to lean until EGT drops a minimum of 25 degrees. It also said do not lean the engine when running above 75% power.
For best power the instructions are to lean until maximum EGT is reached then richen until EGT decreases 25 degrees.
It is interesting for me so I enjoy reading your posts on this stuff. You will be able to write the POH for your engine with all the information you are collecting.
edited to change increases to decreases in the best power sentence. tj
_________________ Tom Jones
Classic IV
Ellensburg, WA
Lynn Matteson
Posted: Sat Aug 15, 2009 4:10 pm Post subject: ROP versus LOP...might be off-topic for some |
Tom, this is all very new to me, and so it surprises me that the
instructions for a 180 include leaning beyond the max EGT. I only
began hearing about this "black magic" about a month ago. During
recent searches on the subject, I found that it's been discussed for
five years or more. (I must have taken a really long nap!) I always
like to find new information about things that were seemingly cast in
stone, and not to be tried.
Lynn Matteson
Status: flying
On Aug 15, 2009, at 6:10 PM, Tom Jones wrote:
75% power.
reached then richen until EGT increases 25 degrees.
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p 57868#257868
N369LM |
Fox5flyer Guest
Posted: Sat Aug 15, 2009 5:06 pm Post subject: ROP versus LOP...might be off-topic for some |
Lynn, I've been leaning LOP on my EA81 with Ellison TB for more than the
past 300 hours. It's actually been done for much longer than 5 years. I
spoke with a friend who flew B25s and he said it was routine operation.
Like you said, you lose a small amount of power, but the fuel savings payoff
is worth it. The caveat here is that one needs to have a good display of
the cylinder EGTs and to not do it with high manifold pressures.
Good report you gave on the topic. Thanks.
Below is the article written by John Deacon on the subject. Lengthy, but
enlightening.
http://www.avweb.com/news/pelican/182084-1.html
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 430+ TT
- Joseph Joubert
MichaelGibbs(at)cox.net Guest
Posted: Sun Aug 16, 2009 1:23 am Post subject: ROP versus LOP...might be off-topic for some |
Lynn,
Aviation is loaded with myth and wives tales about LOP operations.
If you'd like to learn the straight scoop from some folks that have
been studying the issue intensely for years now, check out
<http://www.gami.com/>, particularly the articles
<http://www.gami.com/articles/articles.php>.
These guys have reams of data from some of the most
heavily-instrumented engines on the planet and they are firm
believers in LOP operation.
Mike G.
Kitfox IV-1200 Speedster
Phoenix, AZ
Lynn Matteson
Posted: Sun Aug 16, 2009 2:23 am Post subject: ROP versus LOP...might be off-topic for some |
Thanks for the links, Mike...and speaking of "reams", I just went to
the Deakin article that Deke mentioned, and it's gonna take a ream of
paper to print THAT one, but I will.
In fact, it was a local lady pilot that was telling me about the GAMI
folks and how she had just got done running some LOP tests in her
CH801. When she told me about leaning beyond peak EGT, and the temps
went DOWN, I was shocked. First off, that a woman would know about
this "magic" before I did, and second, that it would work at all.
Sorry about being sexist, ladies, but I guess old habits die hard.
Damn, I really DID spend too much time as a photographer, and let my
motor skills snooze.
Lynn Matteson
Status: flying
On Aug 16, 2009, at 4:59 AM, Michael Gibbs wrote:
<MichaelGibbs(at)cox.net>
Lynn,
been studying the issue intensely for years now, check out <http://
www.gami.com/>, particularly the articles <http://www.gami.com/
These guys have reams of data from some of the most heavily-
instrumented engines on the planet and they are firm believers in
LOP operation.
Mike G.
Phoenix, AZ
N369LM |
Paul A. Franz, P.E.
Posted: Sun Aug 16, 2009 3:57 am Post subject: ROP versus LOP...might be off-topic for some |
On Sun, August 16, 2009 1:59 am, Michael Gibbs wrote:
| Quote: | Aviation is loaded with myth and wives tales about LOP operations.
Mikel,
You've found an excellent and very interesting collection of articles. In this one:
<http://www.gami.com/articles/frugalflyer.php>
They say:
Not all GA engines can run safely LOP. Carbureted engines, for example, lack precise
fuel/air metering systems and typically run rough and lose power LOP. And electronic
engine monitors that show cylinder head and exhaust gas temperatures for every
cylinder are necessary for safe LOP operations. Graphic engine monitors are even
better.
The danger of flying LOP with a single-cylinder CHT or EGT probe is that some
rich-running cylinders could become too hot, damaging internal valves and guides, and
causing a loss of engine compression that would require a top overhaul.
“The problem isn’t running too lean,” Braly said. “The problem is running too rich
without knowing about it.”
Bill Middlebrook, president of Penn Yan Aero, a New York company that performs about
400 engine overhauls annually, said properly equipped engines are operating lean of
peak safely and reliably. But carbureted engines, and those without engine monitors,
can and are being damaged from pilots running them too lean. “We’ve never had any
issues with lean-of-peak operations in engines equipped with GAMI injectors and
graphic engine monitors,” Middlebrook said. “In fact, we’ve got them on our own
aircraft fleet. But we’re also seeing burned valves and cylinder damage in carbureted
engines or those with single-point EGTs trying to fly lean of peak. If you don’t have
matched fuel injection nozzles and a six-point engine monitor, you just don’t have
enough information for lean-of-peak operations.”
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
"The collection of taxes which are not absolutely required, which
do not beyond reasonable doubt contribute to the public welfare, is
only a species of legalized larceny. The wise and correct course to
follow in taxation is not to destroy those who have already secured
success, but to create conditions under which everyone will have a
better chance to be successful."
-- President Calvin Coolidge (1873-1933)
It's passionately interesting for me that the things that I learned in a
small town, in a very modest home, are just the things that I believe
have won the election.
-- Margaret Thatcher
Take time to deliberate; but when the time for action arrives, stop
thinking and go in.
-- Andrew Jackson
"We have rights, as individuals, to give as much of our own money as
we please to charity; but as members of Congress we have no right so
to appropriate a dollar of public money."
-- American hunter, frontiersman, soldier and politician Davy Crockett (1786-1836)
"Would it not be better to simplify the system of taxation rather
than to spread it over such a variety of subjects and pass through
so many new hands."
--Thomas Jefferson, letter to James Madison, 1784
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Posted: Sun Aug 16, 2009 9:15 pm Post subject: ROP versus LOP...might be off-topic for some |
| Quote: | Mikel,
My partners and I have GAMInjectors on our Turbo Arrow III, that's
how I became aware of their company and web site.
Mike G.
Phoenix, AZ
Lynn Matteson
Posted: Mon Aug 17, 2009 9:46 am Post subject: ROP versus LOP...might be off-topic for some |
I know what you mean, Tom....lean to you means less oil to lube the
bottom end, eh? Unless things have changed since I last ran a 2-
stroke, all the bottom end stuff gets lubed via the oil, right? Or is
that what the oil injected engines do, is take care of the lubing so
the fuel can go oil-less?
Lynn Matteson
Jabiru 2200, #2062, 739.7 hrs
Status: flying
75% power.
Tom Jones
Classic IV
Ellensburg, WA
N369LM |
Tom Jones
Posted: Mon Aug 17, 2009 11:17 am Post subject: Re: ROP versus LOP...might be off-topic for some |
| Quote: | I know what you mean, Tom....lean to you means less oil to lube the
the fuel can go oil-less? |
Lynn, pretty much what you say about the lube is correct. The top end...piston skirts and wrist pins/bearings...are also lubed with the two stroke oil. Premixed or injected the oil serves the same purpose.
The fuel also cools the top of the pistons. A lean fuel/air mixture can burn a hole in the top of the pistons or melt the outside of the top of the piston around the rings and cause the pistons to seize to the cylinder walls.
The good book of Rotax says "Thou shalt not exceed EGT of 1200 degrees F in Thy two stroke engine".
Classic IV
Ellensburg, WA |
mhubel
Posted: Sun Sep 06, 2009 5:30 pm Post subject: Rotac TBI 40 installation details- |
I am considering using the Rotac TBI 40 for a Jabiru 3300 in a Zenith CH601XL.
I wonder what your experience was with the primer button on the regulator, did you connect it to a cable in the cabin? If so just what sort of assembly was used?
I was also wondering how the mixture cable was supported, I don't see any method of supporting the mixture cable in the pictures on the ROTAC web site.
_________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
Lynn Matteson
Posted: Sun Sep 06, 2009 7:09 pm Post subject: ROP versus LOP...might be off-topic for some |
After about three weeks of using the TBI without hooking up a control
cable to the primer button, I finally did it and it works great. Here
are some pictures of how I made a small bellcrank to actuate my
button, and of the bellcrank that I built that transferred throttle
cable motion from one side of the TBI to the other side and increase
the throw of the throttle to provide better control/easier
operation. The orange bellcrank also shows the bracket that allows
for attachment of the throttle cable and for the mixture control
cable. Regarding the primer control, I was kinda cramped for room in
the engine compartment, so the mechanical "advantage" of the leverage
is a non-advantage. The picture doesn't show the cable attachment,
but it is too close for proper operation, meaning that it takes a lot
of puling power on the cable to get the button depressed, but it does
work. I'm going to rework it to provide a better mechanical
advantage. And yes, the cable goes into the cabin right alongside the
mixture control and throttle cables.
Here is a picture of the main bellcrank/cable attachment device
that I built....the orange device (in case the captions get mixed
up). You can see the brackets that I welded on where the mixture (top
hole with slot), and throttle (bottom hole with slot) control cables
go. I built this up out of aluminum, and TIG-welded the assembly
together...steel could also be used, of course. Because I wanted to
retain the original throttle cable, and because I wanted to increase
the travel of the throttle for better control of rpm, I made the arms
long and short accordingly. I used the former "choke" cable to the
original Bing carb for the mixture control cable...painting the knob
red, of course.
I sent this picture to Rotec, per their request, so as to maybe give
Jabiru owners another way to make the connections, but apparently
they haven't posted it yet. This required bending of the end of the
throttle slide-actuating attachment, but it was an easy bend, and
this mechanism works perfectly.
And here is the primer button-actuating bellcrank. If I can do a
little "massaging" of the firewall footwell area, I'll be able to
lengthen the upper part of the bellcrank, and that will make for an
easier pull on the cable. Right now the cable only moves about a half-
inch, and requires a bit of a pull.
Lynn Matteson
Jabiru 2200, #2062, 760.3 hrs
Status: flying
On Sep 6, 2009, at 9:30 PM, mhubel wrote:
Zenith CH601XL.
the ROTAC web site.
Mark Hubelbank
157.09 KB |
13553 Time(s) |
90.06 KB |
13553 Time(s) |
N369LM |
mhubel
Posted: Sun Sep 06, 2009 7:23 pm Post subject: Re: ROP versus LOP...might be off-topic for some |
Thanks, If I go in this direction, now I know what to expect. I am a bit surprised that Rotec does not offer the option of some pre made assemblies to mount the mixture and primer cables.
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
Lynn Matteson
Posted: Mon Sep 07, 2009 2:19 am Post subject: ROP versus LOP...might be off-topic for some |
I'm thinking that this TBI is a bit new to them, and it might just be
that later on they will. Apparently they don't even offer the intake
flange, either. Although Paul, their rep at Oshkosh, said that they
have done major testing on their engine and on Jabiru's , and that
shows that they've had it for some time.
Lynn Matteson
Status: flying
On Sep 6, 2009, at 11:23 PM, mhubel wrote:
Mark Hubelbank
http://forums.matronics.com/viewtopic.php?p 61811#261811
N369LM |
Lynn Matteson
Posted: Mon Sep 07, 2009 3:04 am Post subject: ROP versus LOP...might be off-topic for some |
red, of course.
Lynn Matteson
Status: flying
Zenith CH601XL.
the ROTAC web site.
Mark Hubelbank
157.09 KB |
13538 Time(s) |
90.06 KB |
13538 Time(s) |
N369LM |
