rv8ch
Posted: Tue Apr 04, 2006 8:21 am Post subject: instrument panel water jet cutting |
Hi,
Anyone have some suggestions for instrument panel
water jet cutting? I've tried experimentalair.com
but I'm not getting any response. Perhaps I'm being
too impatient. Stein's focusing on complete panels,
as is affordable panels.
Thanks for any pointers.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
skytop(at)megsinet.net Guest
Posted: Tue Apr 04, 2006 10:47 am Post subject: instrument panel water jet cutting |
Werner Berry of Pacific Panel uses CNC, but the end results are perfect
holes. Great service too.
http://www.sptpanel.com/
Tom Barnes -6 first flight two years today.
stevea(at)svpal.org Guest
Any particular reason you want water jet cutting? NC (numerically
controlled) routing is also used to cut instrument panels. The 1/8 inch
diameter router bit used can not cut as tight a corner as a water jet,
so some filing may be required for tighter corners. Avionics panel
shops should be familiar with this. Other than that, the cut panel
should come out the same. The avionics shops I talked to use NC routers.
My panel is at an avionics shop (as I type this) to be cut, painted,
engraved and matte finish epoxy clear coated. Contact me off list if
you want to know my experience so far.
Steve
RV-6A
Mickey Coggins wrote:
| Quote: | Anyone have some suggestions for instrument panel
jpl(at)showpage.org Guest
Posted: Tue Apr 04, 2006 11:23 am Post subject: instrument panel water jet cutting |
I think he was asking about water jet cutting as that's what's used
at experimentailair.com. This site has what appears to be pretty
reasonable prices for designing and cutting your panel, so I can see
the attraction.
-Joe
RV-6A. Well, I think I'm about halfway through the "V" so far
On Apr 4, 2006, at 1:45 PM, Steve Allison wrote:
inch
routers.
Steve
RV-6A
Rhonda(at)bpaengines.com Guest
Posted: Tue Apr 04, 2006 11:59 am Post subject: instrument panel water jet cutting |
Experimental Air is owned by Ross Schlotthauer who built an RV-7. I
left him a voice mail and will be happy to pass on his phone number as
soon as I get the go ahead from him.
Rhonda
wgill10(at)comcast.net Guest
Posted: Tue Apr 04, 2006 4:00 pm Post subject: instrument panel water jet cutting |
Mickey,
Experimentalair does great work, your patience will payoff.
A satisfied customer.
Bill
emrath(at)comcast.net Guest
Posted: Wed Apr 05, 2006 5:46 pm Post subject: instrument panel water jet cutting |
There is a gentlemen in Nashville TN that cut mine for me. Lee Moore, who's
email is "Jet(at)south-tech.us" or call him at (615) 847-8226. He was very
helpful. I started with my own Turbo Cad file and he spiffed it up, cut a
piece of scrap for fit up and then we cut the real deal. I actually had him
make three pieces, a frame that will be permanently mounted in the RV and
then two panels, left and right, leaving a center cutout for my radios.
Very accurate cutting, with no metal burning as in a laser cut. He can
punch holes in 1.5" thick steel. It is worth a visit if you have not seen
this live.
Marty in Nashville TN, RV-6A panel mounting.
