carlossa52(at)gmail.com Guest
Posted: Mon Aug 10, 2009 3:10 pm Post subject: centre wing, HD(S) question |
Hello, all
Did anybody bother to bend plate 6V11-4 to fit the curvature of the wing?
I see small gaps at the front and rear, something around 1.0 mm ... see attached file...
Carlos
CH601-HD, plans
251.95 KB |
4203 Time(s) |
grs-pms(at)comcast.net Guest
Posted: Mon Aug 10, 2009 4:20 pm Post subject: centre wing, HD(S) question |
Carlos:
Yes, I bent that plate. I supported the ends on a couple of pieces of wood and bumped the middle (carefully) with a wood block and hammer. Mine fits the contour perfectly.
I also bevelled the edges and put a generous radius on the corners.
George Swinford
MHerder
Joined: 11 Feb 2008 Posts: 143 Location: Fort Worth TX
Posted: Mon Aug 10, 2009 8:38 pm Post subject: Re: centre wing, HD(S) question |
I didn't bother, I figured the amount of A5 rivets in there would suck it tight, and I was right. I'm sure it wouldn't hurt either way though. Good luck and keep trucking along. I agree 100 percent with taking your time to round those corners good and beveling, its smart structurally and that plate is pretty visible, so make it look right.
_________________ Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying |
Posted: Tue Aug 11, 2009 6:49 am Post subject: centre wing, HD(S) question |
Yes Carlos,
I had to bump the plate into a nearly imperceptible curve to get a fit.
Carlos Sa wrote:
| Quote: | Hello, all
Carlos
CH601-HD, plans
