Classic exhausts
avgashead(at)btinternet.c
PostPosted: Sun Aug 09, 2009 3:39 am    Post subject: Classic exhausts Reply with quote
After recent concerns over classic exhausts and their availability, John Richardson kindly allowed CKT to use his classic to model for a slightly revised system.
CKT has not in the past had access to a classic so needless to say small problems in the old system have been ironed out including moving the tailpipe to allow for trigears.
The system is also in stainless so a better job all round.
I figure that there are those out there who need a system or will do fairly imminently so maybe you could register your needs with Roger at the factory. Myself and others mentioned above have gone to a reasonable amount of time and effort to ensure systems are available for the classic and Europa/CKT need a production batch (albeit small) to make the manufacturing viable.
I can’t advise on price from the factory, but I suspect the new systems will be more expensive, but with this comes greater longevity and all previous issues of poor fitting should be consigned to the forum archive.
Kind regards
Richard Scanlan
#103 Mono
