Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Sun Aug 09, 2009 6:23 am Post subject: Bolts, Propeller - 6 ea. |
I am trying to find some propeller bolts for my new project. The prop is a Woodcomp 3-blade ground adjustable prop on a Rotax 912. The bolts that came from the factory are 8x140mm. I don't think the bolts were sized right at the factory. The shank or shoulder of the bolt is about 110mm and the prop, hub and spacer take up 125-126 mm. That leaves the shank about 15 mm too short.
I talked to Lockwood and they sent me 6 bolts, with exactly the same shoulder. I called a place that sold Woodcomp props and talked to a fellow there. I'm having a little trouble getting follow through from him.
So, what is the opinion about putting the prop bolts back in and torqueing them down. They were in the engine for 380 hours. Somehow I don't think that is what I'm going to do.
Does anyone know a reliable source for some bolts?
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Tommy Walker
N25A - Anniston, AL |
alhays(at)hickoryhillfarm Guest
Posted: Sun Aug 09, 2009 7:33 am Post subject: Bolts, Propeller - 6 ea. |
Tommy,
This doesn't directly answer your question but may help. As I
understand it, there should be no shear load on the bolts as the
driving force is conveyed by large surface area under the pressure
achieved by maintaining proper torque on the bolts. As long as the
shoulder extends through or well into the parts it holds in alignment,
it may not need to be longer. Others with more experience or
credentials may explain it better or direct you to a good reference.
Al Hays
N701GH reserved - Gore, VA
