gregoryf.flyboy(at)comcas Guest
Posted: Fri Aug 07, 2009 4:27 pm Post subject: Tailplane Pitch tubes: EUR002 Bolts not seating |
The EUR002 Bolts are to be cut to a length of 1.5" measured from under the
head, and then installed into the CS17A end fittings on either side of the
main pitch push-rod. They are to be threaded in from the cupped side, after
fitting Loctite.
The problem I am having is that they don't seat onto the flat surface of the
cupped side. The threads bottom out just before the head seats, leaving a
gap of about 1.7mm, or about 1/16 (inch).
Has anyone had this happen, or has everyone had this happen?
Posted: Fri Aug 07, 2009 6:27 pm Post subject: Tailplane Pitch tubes: EUR002 Bolts not seating |
surface of the
leaving a
Greg...I do not recall such a problem...Fred
Posted: Sat Aug 08, 2009 7:20 am Post subject: Tailplane Pitch tubes: EUR002 Bolts not seating |
It appears that everyone is in agreement with you, Fred.
Looks like its back to the Europa Supply Depot for me...
Greg
