tcone1(at)comcast.net Guest
Posted: Thu Aug 06, 2009 6:12 am Post subject: smoke system |
Matte,
Go to Northerntool.com and pick a tank. I picked one that fits nicely in
the drop down section of the forward baggage compartment...they had one that
dropped right in. 3.5 gals.
The pump is just an ordinary ag pump...check online.
Here are a couple of pics, http://picasaweb.google.com/tconerv8/SmokeSystem#
Thanks for the compliment on the 37 ship. My homebrewed smoke was looking
just fine as Delta 3 and I was the only smoker in that file.
Timothy E. Cone
tcone1(at)comcast.net (tcone1(at)comcast.net)
wgill10(at)comcast.net Guest
Posted: Thu Aug 06, 2009 7:17 am Post subject: smoke system |
Tim,
Do you have a P/N for the tank? I could not find one like the one in your photo. Thanks in advance for your reply.
Bill
RV-7 N151WP
pilots2(at)yahoo.com Guest
Posted: Sat Aug 08, 2009 9:18 am Post subject: smoke system |
All,
Im doin my own smoke system and have designed a 6 gal fiberglass tank that fits right behind the right seat (with minimal loss of baggage area) for a 7A. All the pumps I have seen are huge. Has anyone tried the Facet fuel pump (the one with the AN fittings)? And what is everyone using for the electrionic shutoff?
Reuven Silberman
N7WT KSEE
Pilots2(at)yahoo.com (Pilots2(at)yahoo.com)
--- On Thu, 8/6/09, wgill10(at)comcast.net <wgill10(at)comcast.net> wrote:
From: wgill10(at)comcast.net <wgill10(at)comcast.net>
Subject: Re: smoke system
To: rv-list(at)matronics.com
Date: Thursday, August 6, 2009, 8:12 AM
#yiv979971372 p {margin:0;} Tim,
Bill
RV-7 N151WP
wdleonard(at)gmail.com Guest
Posted: Sun Aug 09, 2009 4:09 pm Post subject: smoke system |
Ruben, I am using a whelen pump that weighs only 1 lb. and has an internal spring-loaded check valve. Currently it flows .83 gal/min (controlled by the size of the holes in the injector. Will burn out quick if run without oil, so I use a fluid level switch to turn it off.
Example:
http://www.expressfuelpumps.com/gsl391-190lph-walbro-inline-fuel-pump-universal-p-3782.html
David Leonard
On Sat, Aug 8, 2009 at 10:15 AM, Reuven Silberman <pilots2(at)yahoo.com (pilots2(at)yahoo.com)> wrote:
[quote] All,
Reuven Silberman
N7WT KSEE
--- On Thu, 8/6/09, wgill10(at)comcast.net (wgill10(at)comcast.net) <wgill10(at)comcast.net (wgill10(at)comcast.net)> wrote:
From: wgill10(at)comcast.net (wgill10(at)comcast.net) <wgill10(at)comcast.net (wgill10(at)comcast.net)>
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Tim,
Bill
RV-7 N151WP
Posted: Sun Aug 09, 2009 4:10 pm Post subject: smoke system |
Eh, sorry, that is a Walbro pump.
David Leonard
On Sun, Aug 9, 2009 at 5:08 PM, David Leonard <wdleonard(at)gmail.com (wdleonard(at)gmail.com)> wrote:
[quote] Ruben, I am using a whelen pump that weighs only 1 lb. and has an internal spring-loaded check valve. Currently it flows .83 gal/min (controlled by the size of the holes in the injector. Will burn out quick if run without oil, so I use a fluid level switch to turn it off.
Example:
David Leonard
[quote] All,
Reuven Silberman
N7WT KSEE
Tim,
Bill
RV-7 N151WP
