ghinman(at)mts.net Guest
Posted: Fri Aug 07, 2009 6:18 am Post subject: Alternator output fuse |
I am using a CAM 040AD alternator
Which is a DENSO alternator 18504-6220 .
It is a 40amp alternator,and the instructions say
to use a
40amp fuse on the output.
After about 15hrs on the RV-8 ,the breaker blew.
It seems I will need a larger breaker.What size are
others using
for output on a 40amp alternator??
George H. Inman
ghinman(at)mts.net
Home 204 287 8334
Cell 204 799 7062
rickpegser(at)yahoo.com Guest
Posted: Fri Aug 07, 2009 7:44 am Post subject: Alternator output fuse |
are you using did the breaker trip or did it fail. if it failed you probably had a loose wire on it. if it just triped it did its job and you have foo much load.
rick
--- On Fri, 8/7/09, George Inman 204 287 8334 <ghinman(at)mts.net> wrote:
| Quote: | From: George Inman 204 287 8334 <ghinman(at)mts.net>
Subject: Alternator output fuse
To: "RV-list matronics" <rv-list(at)matronics.com>
Date: Friday, August 7, 2009, 7:21 AM
alternator
Which is a
say to use a
blew.
others using
George H. Inman
ghinman(at)mts.net
Home 204 287 8334
Cell 204 799 7062
Forum -
FAQ,
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
