Std vs. Aerobatic Engine Vibration Mounts
Site Admin
PostPosted: Wed Aug 05, 2009 3:50 pm    Post subject: Std vs. Aerobatic Engine Vibration Mounts Reply with quote
Dear Listers,
I've got an IO-390 to mount on the RV-8. What are the pros and cons and opinions regarding the use of the "Standard" vs. "Aerobatic" engine vibration mounts? I have a set of both and can't decide which to use. Will there be more sag with the Std version over time? Is the different in vibration noticeable? Does having the larger engine make any difference in the selection? What other gotchas are there between the two different types.
One other question. Do they have a shelf life? Does a set sitting in the box, on a shelf for 15 years have any noticeable reduction in "performance"?
Thanks for your feedback!
RV-8 #82880 N998RV
FWF Starting This Weekend!
Vanremog(at)aol.com
PostPosted: Wed Aug 05, 2009 6:50 pm    Post subject: Std vs. Aerobatic Engine Vibration Mounts Reply with quote
Matt-
One wearout mode besides compression set (sag) in these isolators is loss of elastomeric properties over time due to outgassing of the natural oils/emollients in the rubber compound. This increases the durometer of the compound over time and increases their transmissibility. Aerobatic mounts are naturally stiffer than standard isolators from the get-go.  IMO you should buy fresh standard isolators and immediately coat them in DC4, then you should dynamically balance your engine/prop combination. They then should last until engine TBO.
N1GV (RV-6A Flying 924TTAE Silicon Valley, CA)
In a message dated 8/5/2009 4:51:38 P.M. Pacific Daylight Time, dralle(at)matronics.com writes:
martin(at)gbonline.com
PostPosted: Thu Aug 06, 2009 5:12 am    Post subject: Std vs. Aerobatic Engine Vibration Mounts Reply with quote
PostPosted: Thu Aug 06, 2009 5:20 am    Post subject: Std vs. Aerobatic Engine Vibration Mounts Reply with quote
Listers,
I now have 1000 hours on my 390 installation. I will be happy to comment
via telephone (at)920 619 6968.
Dick Martin
RV8 N233M
PostPosted: Thu Aug 06, 2009 5:21 am    Post subject: Std vs. Aerobatic Engine Vibration Mounts Reply with quote
I now have 1000 hours on my IO-390 from Barrett Performance AC. I used the
aerobatic mounts because I noticed on my old IO360 on my RV8 that there was
some sag. As of this date their is no sag with the aerobatic mounts. Also
there is no descernable difference in vibration etc. The alignment of the
engine within the cowl shows no difference.
I did use a shim washer under one of the mounts to achieve perfect alignment
of the engine within the cowl.
Note, I also use a Aerocomposites 74" Carbon fiber prop with a Sam James
cowl and plenum. More speed and less weight.
Dick Martin
RV8 N233M
If you want to discuss, call me (at)9206196968
JohnInReno
PostPosted: Thu Aug 06, 2009 6:44 am    Post subject: Std vs. Aerobatic Engine Vibration Mounts Reply with quote
What is DC4?
John
Vanremog(at)aol.com (Vanremog(at)aol.com) wrote: [quote] Matt-
John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale
Vanremog(at)AOL.COM
PostPosted: Thu Aug 06, 2009 8:34 am    Post subject: Std vs. Aerobatic Engine Vibration Mounts Reply with quote
http://www.aircraftspruce.com/catalog/cspages/dc4.php
In a message dated 8/6/2009 7:45:18 A.M. Pacific Daylight Time, john(at)morgensen.com writes:
What is DC4?
John
Matt-
="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
AV8ORJWC
PostPosted: Thu Aug 06, 2009 9:04 am    Post subject: Std vs. Aerobatic Engine Vibration Mounts Reply with quote
It is silicone in a tube and often used when installing O rings.
John
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Morgensen
Sent: Thursday, August 06, 2009 7:42 AM
To: rv-list(at)matronics.com
Subject: Re: Std vs. Aerobatic Engine Vibration Mounts
What is DC4?
John
Matt-
[quote] [/b][/b][/b][/b][/b][/b]http://www.matronics.com/Navigator?RV-List[/b][/b][/b][/b]http://forums.matronics.com[/b][/b][/b][/b][/b]http://www.matronics.com/contribution[/b][/b] [b]
Dale Ensing
PostPosted: Thu Aug 06, 2009 4:26 pm    Post subject: Std vs. Aerobatic Engine Vibration Mounts Reply with quote
DC4 is Dow Corning 4 compound.
see : http://www..aircraftspruce.com/catalog/cspages/dc4.php
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
