n19z(at)dslextreme.com Guest
Posted: Sun Aug 02, 2009 12:21 am Post subject: Skylight |
Jon.
The plans show a raise of 35 mm (1 3/8") in the center of the sklight but the sheet with the kit is flat.
Bruce Cruikshank
| | - The Matronics Zenith750-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Zenith750-List |
mcjon77
Posted: Sun Aug 02, 2009 6:46 am Post subject: Re: Skylight |
Thanks Bruce, that makes sense. The specs say that there is only an inch difference in headroom, but when I sat in both I noticed well over 2 inches. Looking at a few pictures, it looked as if the skylight was slightly domed. I might want to try that in a 701 to get a little more headroom.
_________________ Jon McDonald
Building Sonex #1287
Next up CH 701  |
jdsmit8(at)attglobal.net Guest
Posted: Sun Aug 02, 2009 7:27 am Post subject: Skylight |
Hi Bruce,
The bracing across the top is a flat piece when it arrives but you actually cut the "dome" into the piece. A piece of rubber or cork on the top and you're ready to install the glass. It's easier than it looks. Look at the photo guide.
Good luck.
J Smith
