Seat Belt hard points
flysrv10(at)gmail.com
PostPosted: Tue Apr 04, 2006 3:40 am    Post subject: Seat Belt hard points Reply with quote
Hello everyone. I really need help with dimensions on the enclosed
drawing as I am nearing my first flight. In my haste to prime my
fiberglass parts, I painted over the seatbelt hard points.
My apologies if the file takes a while. I made it as small as I could.
seat_belts.pdf
 Filename:  seat_belts.pdf
 Filesize:  6.46 KB
 Downloaded:  446 Time(s)
LarryRosen
PostPosted: Tue Apr 04, 2006 5:26 am    Post subject: Seat Belt hard points Reply with quote
Unfortunately you are not going to like the answer I got. The
dimensions to the center of the hard point are not the same on the right
and left side of the canopy. I will send the marked up pdf off list, to
save bandwidth.
Larry
Larry Rosen
#40356
N205EN (reserved)
<http>
