Robert_Harris(at)intuit.c Guest
Posted: Mon Apr 03, 2006 8:08 am Post subject: Good job norm RE: Corvair in a Fox V |
Good job Norm. Your engine install looks great. Will you existing
cowling still work? What is your planes empty weight? You should post
some pics on the Corvair Web site.
Rober
nebchmp(at)wcc.net Guest
Posted: Mon Apr 03, 2006 5:42 pm Post subject: Good job norm RE: Corvair in a Fox V |
The empty weight is about 28 pounds lighter actually. I forgot to
deduct the weight of the wheel chocks I had on the scales. They were
two and a half pounds apiece. The empty weight is now 920. The cg is
at 10.26. Factory most foward is 9.96. Thanks for the kudos guys. Norm
Harris, Robert wrote:
| Quote: | -->
Clem Nichols
Joined: 10 Jan 2006 Posts: 88 Location: Munfordville, Ky
Posted: Mon Apr 03, 2006 6:57 pm Post subject: Good job norm RE: Corvair in a Fox V |
Norm:
If my arithmetic is correct, then with an empty weight of 920 pounds, you
can't weigh more than 124 pounds and carry full fuel of 26 gallons. Is this
correct? The heading indicates you have a Kitfox V, but the uploaded pics
on Sportflight say it's a Model IV.
Clem Nichols
