Icom 200
luigi
PostPosted: Mon Jul 27, 2009 12:27 pm    Post subject: Icom 200 Reply with quote
have this scheme.
It allows to comunicate between the two positions without doing anything.
Unfortunely the instruction is in italian, but you do not need it.
The circuit is with 4 relay Finder 30.22 or similar plus 7 wago connectors . Nothing more
I assure is very easy to built and very, very cheap. Not more than 20 USd
When you push the PTT from one position you connect the radio to the pin J and, very important isolate through the pin 11 the ground from F to the other PTT.So the copilot doesn't talk with outside.
And viceversa.
I realized it and works fine.
For any info I am here.
Greetings from Italy
Luigi
--- Dada Music Movement, tutta la musica che vuoi! ---
luigi
PostPosted: Mon Jul 27, 2009 9:23 pm    Post subject: Icom 200 Reply with quote
--- Messaggio originale --- --> AeroElectric-List message posted by: luigit(at)freemail.it have this scheme.
And viceversa.
Luigi
Circuito_di_gestione_di_due_cuffie_2.doc
 Filename:  Circuito_di_gestione_di_due_cuffie_2.doc
 Filesize:  95 KB
 Downloaded:  452 Time(s)
