aslsa.rng(at)gmail.com Guest
Posted: Tue Jul 28, 2009 2:20 am Post subject: Yet another engine option |
A while back I offered a new Rotax B gearbox with a 2.00 to 1 ratio up for sale and had no takers here on the list, but it did sell quickly to a fellow in Thailand through eBay. Yesterday Prayote sent me a few pictures of the installation. Thought it might be of interest. The engine is a Subaru EA71.
Rick Girard
| Description: |
| Filesize: |
141.7 KB |
| Viewed: |
6308 Time(s) |
| Description: |
| Filesize: |
166.32 KB |
| Viewed: |
6308 Time(s) |
| Description: |
| Filesize: |
74.24 KB |
| Viewed: |
6308 Time(s) |
JetPilot
Posted: Tue Jul 28, 2009 4:45 am Post subject: Re: Yet another engine option |
Very interesting !!!
I did not know a B box would take that kind of horsepower, I wonder if it will last ?? I think I would have used a C box on an engine that big. Adapting a Rotax gear box to an existing engine sounds like a great idea though. I would like to see an inexpensive and reliable alternative to the 912-S developed... But I'm not holding my breath, people have been trying to do that for many years now with very little success.
Mike
Kolb MK-III Xtra, 912-S |
herbgh(at)nctc.com Guest
Posted: Tue Jul 28, 2009 5:54 am Post subject: Yet another engine option |
The EA71 engine is pretty ancient...60 hp at the best... Its
successor was the EA81...then the EA82... Herb
At 07:45 AM 7/28/2009, you wrote:
Mike
you could have !!!
http://forums.matronics.com/viewtopic.php?p 54985#254985
Checked by AVG - www.avg.com
07/27/09 05:58:00
lucien
Posted: Tue Jul 28, 2009 9:21 am Post subject: Re: Yet another engine option |
| JetPilot wrote: | Very interesting !!!
Mike |
The real issue with the B box is supporting whatever shaft the small drive gear is fitted to - unlike the C box, there's no separate bearing for the drive shaft to take the side loads. On the rotax motor the PTO crank bearings perform this job, partly why the provision 8 motors are so hugely beefy at the PTO end.....
I'd imagine the builder came up with a seperate bearing for this?
Also, any info on the weight? Looks like it weights a ton just looking at the photo, but then looks can be deceiving...
Looks like it flies tho!
LS
_________________ LS
Titan II SS |
JetPilot
Posted: Tue Jul 28, 2009 1:44 pm Post subject: Re: Yet another engine option |
I have always liked the looks of the BMW engine conversion. I have seen this on a Trike. my friend flys it, and it is smooth, powerful, with fuel injection and seems to work very well and trouble free.
http://www.ultralightnews.com/engineinfo/bmwconversion.htm
Mike
| Description: |
| Filesize: |
11.96 KB |
| Viewed: |
6281 Time(s) |
Posted: Tue Jul 28, 2009 2:24 pm Post subject: Yet another engine option |
Mike, what is the displacement of that engine?
BB
On 28, Jul 2009, at 5:44 PM, JetPilot wrote:
Posted: Tue Jul 28, 2009 2:49 pm Post subject: Yet another engine option |
Another Mike...has a BMW engine on his MkIII... He made an adapter
plate and used a c or e box as I recall.. Last I looked, it is for
sale on Barnstormers...Herb
At 04:44 PM 7/28/2009, you wrote:
elleryweld(at)AOL.COM Guest
Posted: Tue Jul 28, 2009 7:22 pm Post subject: Yet another engine option |
I have a EA-81 in my shop but I figure it would be to heavy for any Kolb at 240lbs But I think its the best alternative (just My opinion) if you can use an engine that weight
Ellery in Maine Back in the Saddle again
Mike
have !!!
[url=http://forums.matronics.com/viewtopic.php?p 54985#254985]http://forums.matronics.com/viewtopic.php?p 54985#254985[/url]
