john_s_bright(at)yahoo.co Guest
Posted: Fri Jul 24, 2009 1:35 pm Post subject: RV9-List: About those stiffening circles around the lighteni |
Those rings add stiffness to prevent buckling of the rib web. If you flatten or remove the stiffening rings it's not a problem if you add stiffeners; for instance you might mount your stuff on extruded angles that provide stiffness to the rib.
John Bright
