heavy wing
BobbyPaulk(at)comcast.net
PostPosted: Wed Jul 22, 2009 5:28 am    Post subject: heavy wing Reply with quote
List,
guys with the heavy wings. have you checked the Wash in / out of the wings. it should be no more than 10MM. ( about 3/8" ) mine was out about 1 1/2" and i know of at least 2 more A/C that were out that much or more. i had to shave off the rivet heads and drill a new skin to fit. this was one wing only. the other was O.K.
just a thought.
DO NOT ARCHIVE.
bobby
N131BP
PatrickW
PostPosted: Wed Jul 22, 2009 9:28 am    Post subject: Re: heavy wing Reply with quote
Excellent advice, and a great example of the nuggets of information that this forum is good for.
Knowing that there have been 601XL's that were still controllable with at least 1.5" of difference in the washout is valuable for those of us who are approaching First Flight.
- Pat
Scotsman
PostPosted: Wed Jul 22, 2009 9:41 am    Post subject: Re: heavy wing Reply with quote
Excuse the ignorance what is wash out?
Cell +27 83 675 0815
PatrickW
PostPosted: Wed Jul 22, 2009 9:58 am    Post subject: Re: heavy wing Reply with quote
Scotsman wrote:
what is wash out?
Twist that is built into the wing to reduce the angle of attack the further out from the root you go. It's so the ailerons maintain effectiveness as you approach a stall.
Can read about it here: "http://en.wikipedia.org/wiki/Washout_(aviation)"
- Pat
jaybannist(at)cs.com
PostPosted: Wed Jul 22, 2009 10:11 am    Post subject: heavy wing Reply with quote
James,
Wash out is used to describe a deliberatly twisted wing; such that the tip is at a lower angle of attack than the root. This delays the stalling of the tip of the wing to retain aileron effectiveness after the root has stalled. In some production airplanes, the whole wing has this twist. In the Zodiac, only the aileron is twisted during construction to achieve this wash out.
Jay Bannister
kkinney
PostPosted: Fri Jul 24, 2009 6:17 am    Post subject: Re: heavy wing Reply with quote
I'm attaching a PDF some of the RV guys use when they have a heavy wing. It's the first systematic approach to the problem I've seen.
I hope this helps those with a heavy wing.
Kevin Kinney
Wing_Heavy.pdf
A doc written for RV's with heavy wings
 Filename:  Wing_Heavy.pdf
 Filesize:  12.29 KB
 Downloaded:  1026 Time(s)
