Rudder Rivet Question
Brian Steeves
PostPosted: Tue Jul 21, 2009 5:13 am    Post subject: Rudder Rivet Question Reply with quote
I have just started my RV10 build and am now working on the rudder and have a question about getting at a rivet.
When installing the bottom rib R1004 to the skin. There are the 2 rivets at the aft section where there is no room to get anything into buck the rivets.
Can any help me with a better way to do them?
Appreciate the help.
Brian
jochs(at)froody.org
PostPosted: Tue Jul 21, 2009 5:48 am    Post subject: Rudder Rivet Question Reply with quote
One method is to back rivet it using a thin, flat piece of metal
against the shop end of the rivet and use the flat set of the rivet
gun... you put the gun on top of the metal right next to the rib and
bang on the top of the metal. An old chisel works pretty well for
this. Keep the rivet gun as close to the end of the chisel as you
can. Sorry I don't have a picture of it, but hopefully you get the
idea.
Let me see if i can do an ascii art drawing Wink
rivet gun
------ upper rib flange
----------------------------------------------------------> chisel/
flat piece of steel
o shop head of rivet
----- rib flange you are riveting
------------- back rivet plate
Brian
http://forums.matronics.com/viewtopic.php?p 54081#254081
Neal.George(at)hurlburt.a
PostPosted: Tue Jul 21, 2009 5:51 am    Post subject: Rudder Rivet Question Reply with quote
Brian -
If you have a pneumatic squeezer, a thin-nose, no-hole yoke may fit.
A short piece of steel bar stock clamped in your vice may be used as a anvil -
this takes an extra set of hands to support the rudder while you guide the
rivet into position and shoot it.
Or you could use a pop-rivet.
Neal
Brian
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.04 KB
 Downloaded:  561 Time(s)
tc1234c(at)roadrunner.com
PostPosted: Tue Jul 21, 2009 6:06 am    Post subject: Rudder Rivet Question Reply with quote
The plan calls out blind rivet for the last hole (check the manual for
instruction). For the one before you can use the indirect riveting
technique.
If you are a member of EAA, here is the video:
http://eaa.org/video/homebuilders.html?videoId 9739765001
Ted
T.C. Chang
http://3limafoxtrot.com/
RV-9A, Lycoming (ECI) O320-D2A, 160 hp, Carb, left Mag + right Lightspeed
EI, Sensenich FP
GRT dual DU H1, TT DigiFlight II VSGV, 620 hrs Hobbs
Last flight: http://www.mail2600.com/cgi-bin/track.cgi?call=KD8IIR&last=1
RV10 Wing, #40948, N718PF reserved
Brian Steeves
PostPosted: Tue Jul 21, 2009 7:13 am    Post subject: Re: Rudder Rivet Question Reply with quote
Thank you very much everyone for your help. Should have used a little more common sense and probably would have figured it out. Over analyzing.
Brian
Sstella(at)incisaledge.co
PostPosted: Tue Jul 21, 2009 7:24 am    Post subject: Rudder Rivet Question Reply with quote
I used the chisel idea on the second to the end and a blind rivet on the
last one.
Steve Stella
#40654 Wings
N521RV reserved
jeff(at)westcottpress.com
PostPosted: Tue Jul 21, 2009 9:12 am    Post subject: Rudder Rivet Question Reply with quote
The bucking bar pictured below from Avery is a very useful tool. Aside from letting you dimple hard to access areas with your rivet gun, a simple modification will allow you to set rivets in tight places. I ground out a chunk of the bar as you can see in the attached pictures. It gives you a very strong, but thin surface to slide in to those tight spaces and set rivets against. I also counter sunk a couple of holes that, when push comes to shove, can be used with a rivet and gun to dimple holes in very tight spots.
Jeff Carpenter
40304
Doors (and not too happy about it)
DSC_0001
DSC_0002
DSC_0003
On Jul 21, 2009, at 6:13 AM, BGS wrote:
[quote]--> RV10-List message posted by: "BGS" <Brian.Steeves(at)Parkenna.com (Brian.Steeves(at)Parkenna.com)>
Brian
http://forums.matronics.com/viewtopic.php?p=254081#254081
- The RV10-List --> &n========================
 Filesize:  14.53 KB
 Viewed:  7398 Time(s)
 Filesize:  15.81 KB
 Filesize:  15.18 KB
Avery_Tools_LP_-_DIMPLING-RIVETING_BLOCK_SET.pdf
 Filename:  Avery_Tools_LP_-_DIMPLING-RIVETING_BLOCK_SET.pdf
 Filesize:  114.77 KB
 Downloaded:  637 Time(s)
daveleikam(at)wi.rr.com
PostPosted: Tue Jul 21, 2009 8:17 pm    Post subject: Rudder Rivet Question Reply with quote
I used a flat head screw driver as a bucking bar, with a back rivet plate
behind.
Dave Leikam
RV-10 #40496
N89DA
Muskego, WI
