mike Guest
Posted: Sat Apr 01, 2006 4:05 pm Post subject: cabin heat |
I wanted to post this again. It was a response to winter flying.
Most of the winter I flew with the shivers. Then I figured out a great way for heat. I took an oil funnel and strapped it to the back of the radiator cooler(wire ties) and then took some of that hose with metal wire inside for aircraft(about 1.5 inches diameter) and pop rivited it to the funnel, I cut the opening to the funnel for good flow. Then I put this hose up through the floor and pointed it to the front. Works fantastic, will raise the temp inside at least 20 degrees f. Under 45 degrees outside I add 3 inches of 2inch duck tape to the front of the cooler, puts the temp right at 180 degrees. below 35 outside temp I put on 6 inches of tape. above 60 degrees you will be opening vents. Took me 15 minutes to hook this up.
The best thing about this setup is no electrical usage, and no taping into the water system. You get heat on the ground and the amount of heat is like you have the heater on high in your pickup.
Posted: Mon Apr 03, 2006 6:38 am Post subject: cabin heat |
Just to let you know, I did immediately copy and save
your first posting of this info. I am glad it works
and will keep it for my future mods. As we all know,
our plane is never done, just getting better.
I also have used duct tape on the rad for temp
control, but I need to add something variable yet for
cross countries when the OAT changes a lot. Still
collecting ideas....
Kurt S. S-5/NSI turbo
--- kitfoxmike <kitfoxmike(at)yahoo.com> wrote:
| Quote: | I wanted to post this again. It was a response to
winter flying.
kitfoxmike
kitfox4 1200 912ul speedster
http://www.frappr.com/kitfoxmike
mike Guest
Posted: Mon Apr 03, 2006 6:47 am Post subject: Re: cabin heat |
I agree, but then again, a stop and go is fun as well. Along with taking care of the radiator you can releive yourself as well.
