Air intake tube vanes and EGT's
Lynn Matteson
PostPosted: Fri Jul 17, 2009 7:50 am    Post subject: Air intake tube vanes and EGT's Reply with quote
Fifteen months after I first built vanes into my fiberglass air
intake tube, I finally tried something different, and got success.
When I first installed the vanes into my existing homebuilt
fiberglass 90-degree intake tube, I didn't notice any improvement. I
had been fighting a high #4 cylinder EGT (1405-1425 degrees F) for
quite a while, and it seemed that no amount of rotating the carb
would change that. I had tried swapping the EGT probes but that
didn't prove anything. So today I decided to try rotating the tube so
that the vanes were at a different position relative to the carb.
This finally made the difference. Before, #4 was always the hottest
at 110 to 126 degrees hotter than #3 at 2940- 2960 rpm. Then I
decided to try...again...to rotate the carb bottom towards the hot
(left) side. I had done this in the past, but it never seemed to help
enough. Then a few days ago, I rotated it as much as the throttle
mount bracket would allow before it hit the motor mount. This got the
difference down to 45-63 degrees, with #4 still being the hottest.
But today I rotated the vaned intake tube, and man, what a
difference! Now, #3 is the hottest at 19-55 degrees hotter than #4.
The highest I now see #4 is 1318, and the highest I see #3 is 1356.
These numbers were taken at various throttle settings, around 3400'
MSL, and on 56-60 degrees OAT at altitude.
I don't know why I didn't try the tube rotation as relative to the
carb before. Right after I installed the vanes into the tube, I guess
I just thought that if it didn't change things dramatically the very
first time I attached it, nothing was changed by installing the
vanes. It just goes to show that you shouldn't give up without at
least trying something a little different. Now I will try rotating
the carb back a little bit, and see if I can get the #3 and #4 closer
together. The exhaust gas temp spread is now
between 85 -132 depending on throttle position.
Lynn Matteson
Jabiru 2200, #2062, 705.6 hrs
Sensenich 62"x46" Wood prop
Status: flying
Lynn
Kitfox IV-Jabiru 2200
N369LM
wb2ssj(at)frontiernet.net
PostPosted: Fri Jul 17, 2009 5:06 pm    Post subject: Air intake tube vanes and EGT's Reply with quote
Lynn, are you talking about vanes you installed in the air duct from the
airfilter to the carb, and if so do you have a picture?
Lynn Matteson
PostPosted: Fri Jul 17, 2009 6:21 pm    Post subject: Air intake tube vanes and EGT's Reply with quote
Sure do, Tex....here it is. I also have pictures of building the
vanes. The gist of it is, I cut the tube down the vertical middle,
then using two separate sheets of fiberglass, I built the vanes
inside the tube, then fiberglassed the tube halves back together.
Lynn Matteson
Jabiru 2200, #2062, 706.2 hrs
Status: flying
On Jul 17, 2009, at 9:00 PM, Tex Mantell wrote:
<wb2ssj(at)frontiernet.net>
from the airfilter to the carb, and if so do you have a picture?
 Filesize:  370.49 KB
 Viewed:  2480 Time(s)
Lynn
N369LM
