heisan
Posted: Wed Jul 15, 2009 11:42 am Post subject: Contacter, or not? |
After all the great info and advice I got on the fuses, I thought I would try asking about contacters too .
The aircraft manufacturer, and the engine manual both give a wiring diagram that does NOT include a master contacter. The battery positive goes directly to a master switch, and then to the main bus.
This is the first time I have seen a configuration like this (without the contacter). What are the advantages, and disadvantages of doing it this way? My maximum current draw is around 10A, so well within the continuous current range of a small toggle switch.
Thanks!
Justin
frank.hinde(at)hp.com Guest
heisan
mprather(at)spro.net Guest
Posted: Wed Jul 15, 2009 12:41 pm Post subject: Contacter, or not? |
With a peak current demand of 10A, I think you have a few options..
- Use a small(er) relay mounted close (6") to the battery. Mount your
distribution bus anywhere you wish. This is basically a scaled-down
version of existing architectures and provides all of the normal Z
functionality. This is how my hand-started Varieze is setup.
- If your battery is located close to the pilot's seat, you may be able
to replace the battery relay with a manually operated battery switch.
Cable operated switches have been discussed here in the past.
- Use a battery bus mounted close to the battery. This is fine if you
don't care about being able to make the whole system "cold" with one
switch.
- Use an appropriately sized inline fuse to feed the battery to a bus
which is located elsewhere in the plane. This is probably OK if none of
the electrical equipment is "critical to continued flight".. Faulting
the fat feeder would cause it's protection to open up, causing all your
electrical stuff to go dark.
Using a relay of any type (esp a fat contactor) causes an extra load on
the electrical system. If your sole source of power is a small PM dynamo,
every watt starts to add up. Small relays only draw on the order of 100mA
- less than 1% of the B&C dynamo on my O-200 - an acceptable load..
Matt-
<justin(at)expertron.co.za>
would
| Quote: | try asking about contacters too [Wink] .
the
| Quote: | contacter). What are the advantages, and disadvantages of doing it this
continuous
If your battery is located any significant distance from your starter, you
need a heavy relay or heavy switch.. It's bad practice to have a long
unprotected cable in the airplane which can't otherwise be made cold (via
a switch or contactor).
Matt-
frank.hinde(at)hp.com wrote:
> Where does the starter current go?..Usually it goes through the master
> contactor..You won't be sending that kind of current through a normal
> toggle switch..well more than once anyway...
Ah - forgot to mention - the starter has a built in solenoid.
http://forums.matronics.com/viewtopic.php?p 53216#253216
phil(at)petrasoft.net Guest
Posted: Wed Jul 15, 2009 12:50 pm Post subject: Contacter, or not? |
For only 10 Amps go with the switch. It takes almost an amp of
current to hold the master contactor closed so you'd be using ~10% of
your power just to keep the power on.
One advantage to a master contactor is that the big fat wire that
doesn't have a fuse on it can be very short. You can replicate this
for 10A with an automotive relay near the battery and a small wire
coming back to the switch, but that is one more thing that can fail.
If it were me, I'd probably just put a fusible link near the battery,
then run the wire from that to the switch and then to the main buss.
Simple is good!
Phil Birkelbach
Houston RV7 - 727WB
http://www.myrv7.com/
On Jul 15, 2009, at 2:42 PM, heisan wrote:
would try asking about contacters too [Wink] .
Thanks!
Justin
http://forums.matronics.com/viewtopic.php?p 53209#253209
heisan
Posted: Wed Jul 15, 2009 1:13 pm Post subject: Re: Contacter, or not? |
The battery is mounted around 12" from the starter, and 20" from the panel. All 'heavy' current wires are fairly short.
I really like the idea of making it as simple as possible. Added complexity just means extra failure points.
I will definitely go for a fusible link and a switch.
Thanks for the info.
Justin
Posted: Wed Jul 15, 2009 3:21 pm Post subject: Contacter, or not? |
At 02:42 PM 7/15/2009, you wrote:
| Quote: | --> AeroElectric-List message posted by: "heisan" <justin(at)expertron.co.za>
After all the great info and advice I got on the fuses, I thought I would try asking about contacters too [Wink] .
This is the first time I have seen a configuration like this (without the contacter). What are the advantages, and disadvantages of doing it this way? My maximum current draw is around 10A, so well within the continuous current range of a small toggle switch. |
The legacy design goal for a battery master
disconnect is to provide a means by which nearly
all wiring in the airplane is 'cold' when the
disconnect is open. If the battery is conveniently
located then some form of manual switch can be
considered. Perhaps like this?
[img]cid:.0[/img]
[img]cid:.1[/img]
The next reason for a battery master disconnect is
to provide a means by which the battery can be
shut off if the starter contactor (solenoid)
sticks.
If the battery master cannot positioned conveniently
for manual operation, then perhaps a contactor is
indicated. These can be low power devices like the
EV series devices from TYCO . . . but it's pretty
easy to make an el-cheeso contactor emulate the
low power characteristics of the TYCO device.
Finally, a couple of guys on the list were working
on versions of remotely controlled, manual switches
like this:
http://aeroelectric.com/Catalog/AEC/9042/9042-100.pdf
In any case, there's two good reasons for a battery
master disconnect. The style is up to you as is
the choice for installing one.
( -Thomas Paine 1776- )
39.39 KB |
13803 Time(s) |
39.39 KB |
13803 Time(s) |
Posted: Wed Jul 15, 2009 3:52 pm Post subject: Contacter, or not? |
Bob,
Your comments gave me another idea.. If you only have 12-14A to play with
(little dynamo), and the airplane has a starter.. And your normal running
power budget is a fairly high percentage of the output of the dynamo..
One could install a battery contactor (or starter relay) just for running
the starter - in series with any starter/engine mounted relay/solenoid.
Once the engine is running, the current draw from the monster contactor
can be eliminated and you can drop back to a more power-frugal relay for
driving the rest of the electronics on the airplane - a relay installed in
parallel. I can't think of any downside.
Matt-
Emacs!
Emacs!
sticks.
like this:
Posted: Thu Jul 16, 2009 7:11 am Post subject: Contacter, or not? |
At 06:50 PM 7/15/2009, you wrote:
Bob,
That would work too. I'm thinking that for small airplanes,
the manual battery switch makes the most sense. They're light
and inexpensive.
I've got a prototype contactor power manager on the bench but
didn't get to finish evaluating it before I had to pull
the plugs and start moving equipment and inventory.
It would allow the builder to achieve low power operation
with an el-cheeso contactor. Further, if the contactor
needs replacing, you don't have to replace the associated
electronics too . . . and vice versa
