jrlark
Posted: Mon Jul 13, 2009 8:19 am Post subject: static lines |
Hi all
Just trying to assemble a parts list for Airventure and would like to use
the Cleveland Tools static ports. It appears they are designed for 1/4"
tygon tubing which I have lots of experience with.
My concern is whether it is ridged enough and can support itself on it's way
to the instrument panel from the tail ( ie will it sag and pinch itself off
in between ribs etc?).
Other possible solutions would be Safeairs fittings/tubing etc. Also ACS
has their tubing etc. General consensus??
Any and all opinions welcome. Thx
Rick
40956
bcondrey
Posted: Mon Jul 13, 2009 8:29 am Post subject: static lines |
I used them and transitioned to 1/4" OD tubing just aft of the baggage
bulkhead.
Bob
N442PM (flying)
AirMike
Posted: Mon Jul 13, 2009 8:35 am Post subject: static lines |
I have the Cleveland kit. It seems fairly rigid. Be sure to run an arc higher than the ports to drain water. I suspended it with tie wraps behind the cabin and then ran it in the regular holes protected with snap bushings. If you are really concerned buy some Click Bond fasteners to secure the tubing to the airframe between frames. You should look into the Click Bond fasteners anyway for wire runs. Way good stuff but pricey.
http://www.theflightshop.com/
_________________ See you OSH '18
Q/B - sold. |
rene(at)felker.com Guest
Posted: Mon Jul 13, 2009 8:40 am Post subject: static lines |
I used the safeair ports, tubing and fittings. Works great.
Also, I think Stein is also selling the quick disconnect fittings.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
jeff(at)westcottpress.com Guest
Posted: Mon Jul 13, 2009 8:52 am Post subject: static lines |
I've got the Clevelnd ports interfaced to Stein's static tubing with
1/4" id clear tubing from the aviation department of my True Value
hardware store. It wasn't too hard to mount and support it all in a
way that will not pinch itself off... I don't have any pics, but could
take some in the next day or two if that would be helpful.
Jeff Carpenter
40304
On Jul 13, 2009, at 9:16 AM, Sandra & Rick Lark wrote:
<jrlark(at)bmts.com>
Hi all
to use the Cleveland Tools static ports. It appears they are
designed for 1/4" tygon tubing which I have lots of experience with.
it's way to the instrument panel from the tail ( ie will it sag and
pinch itself off in between ribs etc?).
Also ACS has their tubing etc. General consensus??
Rick
40956
MauleDriver(at)nc.rr.com Guest
Posted: Mon Jul 13, 2009 9:42 am Post subject: static lines |
Like others, I used Tygon to attach to the ports then transitioned to
the stiff stuff and the quick connect fittings right behind the baggage
area. I had first plumbed it with Tygon all the way to the front but
went back and changed it to the stiff stuff and the screw on fittings
because the fittings are easier to handle than the barbed stuff. And
the stiff tubing may be tougher than the Tygon.
Remember that if you are installing a GRT or similar system with a
remote AHRS, you may need to plumb a static drop or two for he the
AHRS. My dual GRT AHRS is installed on the Vans supplied shelf next to
the battery and pitch AP servo.
Bill Watson
40605
Hi all
use the Cleveland Tools static ports. It appears they are designed
Rick
40956
Lew Gallagher
Joined: 04 Jan 2008 Posts: 402 Location: Greenville , SC
Posted: Mon Jul 13, 2009 9:42 am Post subject: Re: static lines |
Hey Jeff,
Pictures would be great. Thanks in advance.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
hotwheels
Posted: Tue Jul 14, 2009 6:45 am Post subject: Re: static lines |
At one point someone gave me some leftover pitot stuff (not sure where it came from). It had crappy connectors - nothing metal and sorry cheap plastic. Anything that looked cheesy went straight into the trash as this system needs to be reliable (my wife always asks!).
I ordered the safeair1 kit from www.safeair1.com/index.htm. Nice stuff... but I have dual GRT AHRS and needed additional fittings than were supplied. Most of what was needed, I found (and ordered) from McMaster-Carr. Also ended up ordering a couple of multi-manifold fittings from Stein although McMaster has some too.
It's best to inventory everything and then figure out what's missing before going crazy ordering stuff. The attached diagram helped.
Jay
5181K234 (Same as 5181K23) - Crack-Resistant Polyethylene Tubing .170" ID, 1/4" OD, .04" Wall Thickness, Green http://www.mcmaster.com/#catalog/115/110/=2qpy9h
http://www.mcmaster.com/#catalog/115/170/=2qpruv
5111K385 Polybutylene & Brass Push-to-Connect Fitting 90 Deg Elbow for 1/4" Tube OD X 1/8" NPT Female
5111K221 - Polybutylene & Brass Push-to-Connect Fitting Swvl 90 Deg Elbow for 1/4" Tube OD X 1/8" NPT Male
5111K81 - Polybutylene & Brass Push-to-Connect Fitting Adapter for 1/4" Tube OD X 1/8" NPT Male Pipe
5111K271 - Polybutylene & Brass Push-to-Connect Fitting Swivel Branch Tee for 1/4" Tube OD X 1/8" NPT Male
Multi-Manifold fittings: http://www.mcmaster.com/#catalog/115/171/=2qput3
Clippard TV-2SP - Panel mount static Pitot test switch... 2-way toggle valve w/ 1/8 npt http://www.clippard.com/store/display_details.asp?sku=TV-2SP
PitotPlumbing.pdf |
19.69 KB |
615 Time(s) |
Posted: Tue Jul 21, 2009 9:12 am Post subject: static lines |
I think this shows it...
Jeff Carpenter
40304
On Jul 13, 2009, at 10:42 AM, Lew Gallagher wrote:
Hey Jeff,
Later, - Lew
non-pilot
Painting done!
On with wiring and avionics.
http://forums.matronics.com/viewtopic.php?p 52811#252811
151.94 KB |
11205 Time(s) |
149.74 KB |
11205 Time(s) |
jochs(at)froody.org Guest
Posted: Tue Jul 21, 2009 9:51 am Post subject: static lines |
Just a thought, but you might want to relocate the T on your static
line so that it is higher than the port so that you will drain any
water out of the static port rather than down into the line towards
the avionics...
James
On Jul 21, 2009, at 11:58 AM, Jeff Carpenter wrote:
| Quote: | I think this shows it...
Jeff Carpenter
40304
<DSC_0006.jpg><DSC_0004.jpg>
> <lewgall(at)charter.net>
> Hey Jeff,
> Later, - Lew
> non-pilot
> Painting done!
Posted: Tue Jul 21, 2009 10:24 am Post subject: static lines |
Thanks James... I will.
On Jul 21, 2009, at 10:47 AM, James Ochs wrote:
the avionics...
James
> Jeff Carpenter
> 40304
>> Hey Jeff,
>> Later, - Lew
>> non-pilot
>> Painting done!
jim(at)CombsFive.Com Guest
Posted: Tue Jul 21, 2009 12:19 pm Post subject: static lines |
Jeff,You might want to re-run those static lines. The "T" should be as high as possible so that water will run out of the lines not into them and collect / freeze.Jim CombsN312F Flying - 90 hours--------------------------------------------------------I think this shows it...Jeff Carpenter40304On Jul 13, 2009, at 10:42 AM, Lew Gallagher wrote:> --> RV10-List message posted by: "Lew Gallagher" <lewgall(at)charter.net>>> Hey Jeff,>> Pictures would be great. Thanks in advance.>> Later, - Lew>> --------> non-pilot> crazy about building> NOW OFICIALLY BUILDER #40549> Painting done!> On with wiring and avionics.>>>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.php?p 52811#252811>>>>>>>>>> [quote][b]
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Tue Jul 21, 2009 6:10 pm Post subject: Re: static lines |
All good suggestions but also consider using cable tie mounts (adhesive squares that you can run a tie-wrap through) to support the tubing runs. I used the barbed tees because they work fine and are dirt cheap. Once installed you never touch them again. The slip in connectors are nice but totally unnecessary and expensive. I used them on my O2 system. Remember there is no flow through the static system. Keep it simple.
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
