Commander 680 FLP
hcourier(at)cox.net
PostPosted: Tue Jul 07, 2009 4:40 pm    Post subject: Commander 680 FLP Reply with quote
Hello Commander website folks,
The plane I fly is going through it's annual inspection and some corrosion has been found on the left engine, left side motor mount. The maintenance folks say it's bad enough that the mount must be replaced.
Sooooooo.....we're looking for a motor mount. I don't know the details, part nos, etc. If you have knowledge of where such an animal can be found or think you might have one, please call Brent Cowart, our maintenance guy at 256-845-9129. He's the owner of Valley Aviation in Ft. Payne, AL and knows part nos and details about the engine mount.
You can also email me or call with any information if that's easier.
A note to any Aero Commander 680FLP owners, MR RPM conversion. I recently lost all hydraulics when a small hyd line in the left engine wheel well broke. It broke at the flange where the line was secured by the nut to the connector. I can't describe the part other than it was normal aluminium tubing, not very long, about 4-5" with a compount curve and was in front of the accumulator in the aft area of the left wheel well. We lost all hydraulic fluid, gear, flaps, brakes and steering. Landed at Birmingham, AL....there's a long runway there. Coasted into the grass between the taxiway and ramp otherwise couldn't stop. No damage to plane or pax. The boss was on board, but he's a cool guy.
You might want to check for cracked hydraulic lines if you have a 680FLP. Call me if you want more details.
Ray Mansfield
850-217-5185
N91ES
 Filesize:  5.54 KB
 Viewed:  4899 Time(s)
rsrandazzo(at)precisionma
PostPosted: Tue Jul 07, 2009 7:19 pm    Post subject: Commander 680 FLP Reply with quote
Ray-
Can you send a photo of the offending segment? That would help some of us with similar systems to identify and learn…
Robert S. Randazzo
N414C
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Ray Mansfield
Sent: Tuesday, July 07, 2009 5:40 PM
Subject: Commander 680 FLP
Ray Mansfield
850-217-5185
N91ES
 Filesize:  5.54 KB
hcourier(at)cox.net
PostPosted: Wed Jul 08, 2009 4:42 am    Post subject: Commander 680 FLP Reply with quote
Hi Robert,
Unfortunately I don't have a photo of the offending hyd line. Didn't think to take a px when it was off the plane. The plane is in Ft. Payne, AL now and I'm in Destin, FL so can't get a px at the moment. Besides, it's real hard to see the line where it's located. It's just forward of the accumulator in the left wheel well. One end is attached to what I believe to be the pressure switch for the aux hyd pump, and that's where it broke.
Ray M.
 Filesize:  5.54 KB
 Viewed:  4898 Time(s)
tfisher(at)commandergroup
PostPosted: Wed Jul 08, 2009 5:09 am    Post subject: Commander 680 FLP Reply with quote
Thank you your notice I will check the line today.
I too have a deteriorating engine mount and need another, when you find a source please share that with us.
Tom
C-GISS
680FLP (Mr.RPM)
 Filesize:  5.54 KB
hcourier(at)cox.net
PostPosted: Wed Jul 08, 2009 5:40 am    Post subject: Commander 680 FLP Reply with quote
Thanks Tom. Will let you know if I find a source.
RM
 Filesize:  5.54 KB
kamala(at)MSN.COM
PostPosted: Wed Jul 08, 2009 5:42 am    Post subject: Commander 680 FLP Reply with quote
lost a line in west texas.  in an emergency a John Deere tractor line will get you home. gmc
Subject: Commander-List: Commander 680 FLP
Date: Tue C 7 Jul 2009 19:39:48 -0500
.ExternalClass {font-size:10pt;margin-left:10px;color:#0033cc;font-family:Arial C Helvetica;} Hello Commander website folks C
The plane I fly is going through it's annual inspection and some corrosion has been found on the left engine C left side motor mount.  The maintenance folks say it's bad enough that the mount must be replaced.
Sooooooo.....we're looking for a motor mount.  I don't know the details C part nos C etc.  If you have knowledge of where such an animal can be found or think you might have one C please call Brent Cowart C our maintenance guy at 256-845-9129.  He's the owner of Valley Aviation in Ft. Payne C AL and knows part nos and details about the engine mount.
A note to any Aero Commander 680FLP owners C MR RPM conversion.  I recently lost all hydraulics when a small hyd line in the left engine wheel well broke.  It broke at the flange where the line was secured by the nut to the connector.  I can't describe the part other than it was normal aluminium tubing C not very long C about 4-5" with a compount curve and was in front of the accumulator in the aft area of the left wheel well.  We lost all hydraulic fluid C gear C flaps C brakes and steering.  Landed at Birmingham C AL....there's a long runway there.  Coasted into the grass between the taxiway and ramp otherwise couldn't stop.  No damage to plane or pax.  The boss was on board C but he's a cool guy.
Ray Mansfield
850-217-5185
N91ES
 Filesize:  5.54 KB
tylor.hall(at)sbcglobal.n
PostPosted: Wed Jul 08, 2009 6:14 am    Post subject: Commander 680 FLP Reply with quote
What happened to MRRPMPerformance.com???Their web site is down. The name seems to be available.
Didn't they hold the Mr RPM STC's?
Tylor Hall
To: commander-list(at)matronics.com (commander-list(at)matronics.com)
Date: Tue, 7 Jul 2009 19:39:48 -0500
Ray Mansfield
850-217-5185
N91ES
BobsV35B(at)aol.com
PostPosted: Wed Jul 08, 2009 8:07 am    Post subject: Commander 680 FLP Reply with quote
Good Morning All,
Just a comment on hydraulic lines in general.
It was just a few months after the DC-10 was introduced to service when one took off out of MIA and experienced a hydraulic system failure. The captain declared his emergency and returned to MIA as expeditiously as possible. When he landed two of the systems were totally inoperative and the third was almost out of fluid. Another couple of minutes and the airplane would have been uncontrollable.
It seems that all three of the hydraulic systems were mounted with slightly flexible mounts to the aircraft structure, but all of the hydraulic lines were solid tubing.
The primary unit failed.
The secondary took over as it should but the additional strain failed one of it's supply tubes as well.
The third system was supplying control, but a crack developed in it's tubing and fluid was being lost. I may have some of the details all wrong, but the fix was to replace all of the connecting tubing with flexible lines in lieu of the fixed tubing.
It was a fleet wide mandatory immediate action AD.
If the short tubing in the Aero Commander could possibly be replaced with a hunk of high quality flexible tubing, it is certainly something I would consider doing!
Happy Skies,
Old Bob
In a message dated 7/8/2009 8:42:35 A.M. Central Daylight Time, kamala(at)MSN.COM writes:
.ExternalClass {font-size:10pt;margin-left:10px;color:#0033cc;font-family:Arial, Helvetica;} Hello Commander website folks,
Ray Mansfield
850-217-5185
N91ES
Popular laptop deals plus free shipping!
blorber(at)southwestcirru
PostPosted: Wed Jul 08, 2009 9:41 am    Post subject: Commander 680 FLP Reply with quote
Yoda replaced that line on 400CH with flexible line for the exact same reason. It wasn't leaking, but the pressure regulator was. When we took out the regulator so that he could cut new gaskets for it, we discovered that the flare was cut through about 40% of the way around.
hcourier(at)cox.net
PostPosted: Wed Jul 08, 2009 10:07 am    Post subject: Commander 680 FLP Reply with quote
Did the part have a yellow tag or a GREEN tag? Ha! Ha!
Ray Mansfield
850-217-5185
N91ES
John Vormbaum
PostPosted: Wed Jul 08, 2009 10:13 am    Post subject: Commander 680 FLP Reply with quote
Hey....nothing runs like a Deere!
/J
View user's profile Send private message AIM Address Yahoo Messenger
