Rolling my Rv6a
Charles Heathco
PostPosted: Mon Jul 06, 2009 4:42 am    Post subject: Rolling my Rv6a Reply with quote
Yesterday I went up to test plane after OH my dead vac pump. I did a roll to the left and the stick jerked back and forth 2 or 3 inches at first part of roll, rapidly maybe 4 or 5 times, then was normal, never happeded before, did rt roll and it was ok. Anyone had this happen? any clues?
n801bh(at)netzero.com
PostPosted: Mon Jul 06, 2009 5:14 am    Post subject: Rolling my Rv6a Reply with quote
It is that "new" stick shaker Airbus designed for RV's..
jus kiddin.. :<)
Ben Haas
N801BH
www.haaspowerair.com
denis.walsh(at)comcast.ne
PostPosted: Mon Jul 06, 2009 6:11 am    Post subject: Rolling my Rv6a Reply with quote
Sure as heck if I say "they all do it" some one will argue that their's don't. So let me say that all the one's I have rolled with the stick at full deflection and medium to slow airspeed have exhibited stick" talk back", or mild jerking. quite unsellling but harmless.
I speak with no significant aerodynamic credentials but with a data base of thousands of RV-6A aileron rolls worth of experience.
N133Dw
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
rv8a2001(at)yahoo.com
PostPosted: Mon Jul 06, 2009 6:12 am    Post subject: Rolling my Rv6a Reply with quote
This is normal if you have max throw in the ailerons. Call Vans to confirm, I went through the same thing.
Scott
RV-8a
--- On Mon, 7/6/09, n801bh(at)netzero.com <n801bh(at)netzero.com> wrote:
From: n801bh(at)netzero.com <n801bh(at)netzero.com>
Subject: Re: Rolling my Rv6a
To: rv-list(at)matronics.com
Date: Monday, July 6, 2009, 6:05 AM
jus kiddin.. :<)
Ben Haas
N801BH
kahuna
PostPosted: Mon Jul 06, 2009 7:22 am    Post subject: Rolling my Rv6a Reply with quote
Charlie,
We discussed this when I flew the acro off your phase 1.
You are experiencing normal roll buffet found in all RV's at max deflection. It is nothing to be concerned about.
Best
Mike
[img]cid:1__=08BBFF78DFC04C628f9e8a93df938(at)us.ibm.com[/img]"charlie heathco" ---07/06/2009 09:00:47 AM---Yesterday I went up to test plane after OH my dead vac pump. I did a roll to the left and the stick
[img]cid:2__=08BBFF78DFC04C628f9e8a93df938(at)us.ibm.com[/img]
From:[img]cid:2__=08BBFF78DFC04C628f9e8a93df938(at)us.ibm.com[/img]
"charlie heathco" <cheathco(at)cox.net> [img]cid:2__=08BBFF78DFC04C628f9e8a93df938(at)us.ibm.com[/img]
To:[img]cid:2__=08BBFF78DFC04C628f9e8a93df938(at)us.ibm.com[/img]
"rv-list" <rv-list(at)matronics.com> [img]cid:2__=08BBFF78DFC04C628f9e8a93df938(at)us.ibm.com[/img]
Date:[img]cid:2__=08BBFF78DFC04C628f9e8a93df938(at)us.ibm.com[/img]
07/06/2009 09:00 AM [img]cid:2__=08BBFF78DFC04C628f9e8a93df938(at)us.ibm.com[/img]
Subject:[img]cid:2__=08BBFF78DFC04C628f9e8a93df938(at)us.ibm.com[/img]
Rolling my Rv6a [img]cid:2__=08BBFF78DFC04C628f9e8a93df938(at)us.ibm.com[/img]
Sent by:[img]cid:2__=08BBFF78DFC04C628f9e8a93df938(at)us.ibm.com[/img]
owner-rv-list-server(at)matronics.com
?RV-List">[b]http://www.matronics.com/Navigator?RV-List
u>http://forums.matronics.com[/u]
ion">[b]http://www.matronics.com/contribution
 Filesize:  105 Bytes
 Viewed:  5435 Time(s)
 Filesize:  45 Bytes
pbesing(at)yahoo.com
PostPosted: Mon Jul 06, 2009 7:43 am    Post subject: Rolling my Rv6a Reply with quote
Yep..its normal. Although seems a bit violent from your description. Both of my RV's would just "pulse" feedback at full deflection. Especially to the left.
Paul Besing
Sent: Monday, July 6, 2009 7:09:31 AM
Scott
RV-8a
jus kiddin.. :<)
Ben Haas
N801BH
