dean.psiropoulos(at)veriz Guest
Posted: Sun Jul 05, 2009 4:12 pm Post subject: Control cables, prop and electrical items for sale. |
I still have a few things leftover from the completion of my RV-6A project.
All electrical parts are new in the package (if they came in a package).
See below and contact me off list if there is anything you need:
Dean Psiropoulos
N197DM
Tarpon Sprgs, FL
1) Rocky Mountain Instrument - Micro Encoder (Unassembled Kit), fits std 3
1/8 inch instrument hole, displays airspeed, altitude, VSI, OAT, Altitude
alerting, misc warnings. Half the price of new at $450.00
2) Wingtip/Windscreen antenna kit - originally sold through Van's $10.00
3) Control Cables, Black Knob Friction Lock (for throttle control) $30 each
a) ACS Products, A800BL0445-V, 44.5 inches long (RV-6 with
carburetor)
b) ACS Products, A800BL0505-V, 50.5 inches long (RV, FWD facing
sump)
4) Control Cables, Black Knob with bare wire ends (used for carb/cabin heat
control) $15.00 each
a) ACS Products, A740BL0720, 6 feet long (Black Knob no button)
b) ACS Products, A740BL0720, 6 feet long (Black Knob no button)
5) Cable Safe, bulkhead penetration/mount for control cable, (for 1/4 in OD
cable). Fits control cables in (4) above $5.00
6) Gooseneck Chart Light with separate Dimmer control (B&C GCL) $50.00
7) Ray Allen Rocker Switch (4 wire, for electric trim servo control)$15.00
Ray Allen LED bar graph indicator (shows trim servo position). $60.00
9) Lighted Rocker Switch, Amber lens Carling Brand SPST, 1 piece (.55 x
1.125 hole) $2.50
10) Lighted Rocker Switch, red LED, SPST, 1 piece (.512 x .752 hole) $2.50
11) 2 Large Terminal blocks, (10 connections), #8 screws, $5.00 each
12) 1 Large Terminal block, (16 connections), #8 screws, $5.00
13) Flexible fuel line, std 3/8 inch with firesleeve, 15 inches long (Van's
part VA-129) $30.00 (never installed)
14) Wood prop install kit for 0-360 engine:
a) Aluminum machined spacer, 2 1/4 inch, $200.00
b) Aluminum crush plate and AN steel bolts $140.00
15) Wood prop for 0-360, 70x82, Ed Sterba, mfg 2006, 6 hours TT $450.00
16) Van's fiberglass spinner, fits 70x82 Sterba wood prop, painted metallic
silver $100.00
