Pitot cover
orchidman
PostPosted: Sat Jul 04, 2009 7:56 am    Post subject: Pitot cover Reply with quote
Well it is summer time and the mud dobbers finally got me.
I have the GRETZ heated pitot tube and yesterday on TO the plane was accelerating faster then the airspeed. The plane jumped into the air at 60 KIAS. Climb out I got to about 70. Coming back around for a landing I was doing 50 on downwind and 0 on turn to final. Shocked
Wonder what my miles per gallon flown was Mr. Green
Took less then an hour to clean, test and flight check.
Question: What are people using for a pitot cover? I can make one but ACS has one for $6.95 (#15210) but I am not sure if this one will fit and if it is the best option.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
Tim Olson
PostPosted: Sat Jul 04, 2009 12:10 pm    Post subject: Pitot cover Reply with quote
I just got one at one of the pilot shops. It's just the red rubber cap, I
think 3/4", that has the "remove before flight" streamer on it.
There were 2 sizes, and I think I bought the larger one. No
big deal. I have the gretz too.
Tim
was doing 50 on downwind and 0 on turn to final. [Shocked]
Wonder what my miles per gallon flown was [Mr. Green]
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p 51461#251461
AirMike
PostPosted: Sat Jul 04, 2009 12:17 pm    Post subject: Pitot cover Reply with quote
Good flying Gary. After this happens once you will NEVER fail to put a pitot cover on your plane's pitot head - even in the hanger. The Spruce item with the velcro works well. Make it a double check part of your check list, especially on the low wing aircraft. You will also learn that it is important to not just see that the A/S comes alive on the takeoff roll, but that it correlates to your approximate speed.
See you OSH '18
Q/B - sold.
gengrumpy(at)aol.com
PostPosted: Sat Jul 04, 2009 2:42 pm    Post subject: Pitot cover Reply with quote
The "L" shaped one from Spruce works great and for under $10.
Never leave the pitot tube uncovered!!!
Think the surprise had you been heading off into IMC......
grumpy
N184JM
[Shocked]
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
orchidman
PostPosted: Sat Jul 04, 2009 8:19 pm    Post subject: Re: Pitot cover Reply with quote
grumpy
N184JM
I knew I would need a cover but put off getting one. Right now I have some of the blue painters tape keeping the little guys out with a tail hanging about to the floor. Monday, I will order the larger of the 2 sizes.
Thanks.
Before my first flight there were several of the 'airport bums' Wink asking when was I going to do my high speed taxing and I would reply back Van's thoughts about not doing them. This plane accelerates so fast that I cross check the engine instruments while watching outside until almost rotate speed and then check the airspeed indicator. It was low but not that low so I did what the plane told me it wanted to do. I felt safer flying the plane then trying to do a high speed abort on the runway.
With my past training and the flying of my -10, I feel comfortable flying the plane by the seat of my pants, sounds and visual cues.
For new pilots, I sure hope that your flight instructors give you good training on partial panel, including full loss of airspeed. You never know when it will be used.
Mine went up to about 70 KIAS and then did a genital decrease to zero.
The comment about if I was in the soup, well I would fly the plane first and then later on, with my 496, bring up the instrument screen. It has a GPS airspeed which would give you something in the ball park. Combine that with the winds for the airport and you should be within 10 knots, more then safe for lowering flaps and starting an approach.
This is a great plane !!!!
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
dmaib@me.com
PostPosted: Sun Jul 05, 2009 4:44 am    Post subject: Pitot cover Reply with quote
Tell us more about that decrease to zero part! Smile
David Maib
grumpy
N184JM
of the 2 sizes.
Thanks.
bums' [Wink] asking when was I going to do my high speed taxing and
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p 51547#251547
David Maib
RV-10 #40559
New Smyrna Beach, FL
orchidman
PostPosted: Sun Jul 05, 2009 6:41 am    Post subject: Re: Pitot cover Reply with quote
David Maib
Not a whole lot to tell. It looked like it plugged solid some where around rotate and then bled off to nothing in the following minutes.
After rotate, I knew I had an unreliable airspeed so by and large, it was excluded from my cross-check. And to top it off, I had a 'low-n-slow' plane in front of me doing a full stop so I had to extend to allow him to clear the runway. It took some time to fly the pattern but I was in no rush.
Overall I felt it was no big deal but did require 110% attention and concentration. Another good reason to make sure you get the best training possible. Alex, if you are listening, another thumbs up to the transition training.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
PostPosted: Sun Jul 05, 2009 7:19 am    Post subject: Pitot cover Reply with quote
Another great reason to have AOA - totally independent of the pitot
static system!!
grumpy
N184JM
> David Maib
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p 51580#251580
dlm46007(at)cox.net
PostPosted: Sun Jul 05, 2009 8:21 am    Post subject: Pitot cover Reply with quote
Had a pitot ice in IMC. Noticed gradual decrease in airspeed. Light bulb in
head came on and upon application of pitot heat the airspeed went from 0-140
in a few milliseconds.
dlm46007(at)cox.net
PostPosted: Sun Jul 05, 2009 8:39 am    Post subject: Pitot cover Reply with quote
Think; if the pitot ices at altitude and you are descending, airspeed can
decrease as low pressure in the iced pitot is contrasted with higher static
pressure at lower altitude. Opposite is also true. B-727 going to BUF to
pick Buffalo Bills football team out of LGA. Crew failed to turn on pitot
heats for all three pitot tubes and they iced in a climb. Higher pressure
air from lower altitudes was trapped in the pitot lines. As the altitude
rapidly increased because the aircraft was light, The airspeed appeared to
keep increasing because static pressure was decreasing. Instead of cross
checking other instruments, they saw airspeed over speed and continued to
pull back the yoke. When the aircraft finally stalled the FDR indicated that
the pitch angle was 30 degrees up. The crew fixated on the airspeed and
stalled the aircraft about FL250. It took about a minute to hit the ground.
pitts_pilot(at)bellsouth.
PostPosted: Sun Jul 05, 2009 10:25 am    Post subject: Pitot cover Reply with quote
The cheapest and most available thing is a pipe cleaner. Bend it in the
shape of a tall cowboy hat with the brim turned up. slip the long end
in the pitot tube. Also works to keep critters out of the gas tank
vents. You can leave them in with exception of pitot tube if you have
even an inkling of using pitot heat. Also won't work on pitots with
tiny holes.
Linn
> grumpy
> N184JM
Thanks.
Before my first flight there were several of the 'airport bums' [Wink] asking when was I going to do my high speed taxing and I would reply back Van's thoughts about not doing them. This plane accelerates so fast that I cross check the engine instruments while watching outside until almost rotate speed and then check the airspeed indicator. It was low but not that low so I did what the plane told me it wanted to do. I felt safer flying the plane then trying to do a high speed abort on the runway.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
Jim Berry
PostPosted: Sun Jul 05, 2009 1:20 pm    Post subject: Re: Pitot cover Reply with quote
Orchidman wrote "Mine went up to about 70 KIAS and then did a genital decrease to zero."
Over the years I have seen a lot of guys in the office whose genitals suffered a decrease, but I never knew it could affect their airspeed.
Jim Berry
40482
N15JB
Strasnuts
PostPosted: Sun Jul 05, 2009 1:32 pm    Post subject: Re: Pitot cover Reply with quote
I know some severe cases of genital decrease is caused by acute pucker factor.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
Strasnuts
PostPosted: Sun Jul 05, 2009 1:59 pm    Post subject: Re: Pitot cover Reply with quote
http://www.aopa.org/asf/epilot_acc/mia04la070.html?WT.mc_id=090703epilot&WT.mc_sect=sap
This is a story of a Cirrus that was washed with tap water and had contamination in the pitot system. he had erratic gauges then deployed his parachute. He forgot to use the alternate static source which would have worked. The NTSB hinted that the cause was flouride in the tap water.
780 Hours
SuperSTOL 60 hours
orchidman
PostPosted: Sun Jul 05, 2009 2:08 pm    Post subject: Re: Pitot cover Reply with quote
Jim Berry
40482
N15JB
Isn't spell check great Rolling Eyes but you have to hit the right option also.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
doctornigel
PostPosted: Sun Jul 05, 2009 3:39 pm    Post subject: Re: Pitot cover Reply with quote
The NTSB wasn't hinting at fluoride being the cause, but that the water's source was from tap water and not condensation or rain. However here is proof of fluoride's general danger.
 Filesize:  395.36 KB
 Viewed:  16162 Time(s)
