Spike catcher diode
wroe1(at)dbtech.net
PostPosted: Fri Jul 03, 2009 8:12 am    Post subject: Spike catcher diode Reply with quote
I have the stock Van’s master and starter contactors. Does anyone know if either of these items have internal diodes? Also, what size diode should be used on the starter contactor assuming an external is needed? I’m referencing AEC Z-13/8. Thanks!
Wade Roe
SOUTHERN CARBIDE TECHNOLOGIES, INC.
7739 Unity Road M&D Industrial Park
Tuscaloosa, AL 35401
205-248-6700
205-248-6372 fax
PostPosted: Fri Jul 03, 2009 10:33 am    Post subject: Spike catcher diode Reply with quote
The master certainly would not. The starter MIGHT
and would say so stamped on the under side of
the mounting flange. In any case, two suppressors
are better than no suppressors.
There are no rectifier diodes you can pick that
will be at-risk for electrical overload. My personal
favorites are the electrical over-kill (but
mechanically robust) 1N540x series. These
are really inexpensive and available from
Radio Shack and others . . .
http://aeroelectric.com/Pictures/Misc/RS_Diodes.jpg
The 1A, 1N400x series are electrically quite
adequate but more fragile.
( -Thomas Paine 1776- )
wroe1(at)dbtech.net
PostPosted: Tue Jul 07, 2009 8:16 am    Post subject: Spike catcher diode Reply with quote
On the stock Van’s battery contactor, there is only three terminals (two 5 1/6 and one 3/16 front and center). I am unsure where to install the IN5400 diode. Can anyone comment on proper placement? Also, what about the diode placement on the Van’s stock starter contactor? Please excuse my very “green” hands regarding electronics…learning!
Thanks!
Wade Roe
EAA 557
Aeronca 7AC flying
RV-7 nearing completion
bob(at)bob-white.com
PostPosted: Tue Jul 07, 2009 8:55 am    Post subject: Spike catcher diode Reply with quote
Hi Wade,
You need to put the diode directly across the coil with the cathode
(the end marked with a stripe) connected to +12V. On a three terminal
contactor, +12V is on the terminal connected to the battery. Then
connect the anode to the small terminal used to actuate the relay.
Attached drawings lifted out of one of Bob's publications.
On Tue, 7 Jul 2009 10:53:39 -0500
"Wade Roe" <wroe1(at)dbtech.net> wrote:
[quote] On the stock Van's battery contactor, there is only three terminals (two
the diode placement on the Van's stock starter contactor? Please excuse
my very "green" hands regarding electronics.learning!
Thanks!
Wade Roe
EAA 557
Aeronca 7AC flying
 Filesize:  23.44 KB
 Viewed:  17561 Time(s)
rv(at)thelefflers.com
PostPosted: Tue Jul 07, 2009 8:56 am    Post subject: Spike catcher diode Reply with quote
Vertical Power has a nice document explaining contactor wiring.
http://www.verticalpower.com/docs/Contactor_Wiring.pdf
bob
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Wade Roe
Sent: Tuesday, July 07, 2009 11:54 AM
Subject: RE: Spike catcher diode
Thanks!
Wade Roe
EAA 557
Aeronca 7AC flying
wroe1(at)dbtech.net
PostPosted: Tue Jul 07, 2009 9:58 am    Post subject: Spike catcher diode Reply with quote
Thanks for the comments. The Vertical Power doc. is nicely done.
Wade Roe
EAA 557
Aeronca 7AC flying
Eric M. Jones
PostPosted: Wed Jul 08, 2009 6:13 am    Post subject: Re: Spike catcher diode Reply with quote
This issue has been argued here for years, so spare me your flames Bob.
Today, no electronic engineer recommends diodes for contactor coil suppression. They are not the best, nor the second, nor the third, nor even fourth best way to do the job.
Mechanical relays and contactors depend upon magnetism generated by an electric current running through a wire coil. When the current stops, the magnetic field collapses. But the relay does not know the difference between a wire coil moving in a magnetic field (as in a generator) or a magnetic field moving in a wire coil (as in a collapsing magnetic field). Thus a large voltage—1000V to 1500V typically—is induced in the coil. This current goes the same direction the original current did—so it slows the contact opening—allowing arcing, chatter, bouncing, contact welding and even re-closure! Perihelion Design sells 18V 600W Bi-Directional Zener Transient Voltage Suppressors P6KE18CA (for 14.5V systems) that provide the most modern technical solution to relay coil suppression.
See my website or buy your own. The Gigavac GX11 contactor already has bidirectional zeners for coil suppression. Gee, I wonder why!?
This issue has been argued here for years, so ignore me Bob.
"When I look up at the night sky and think about the billions of stars out there, I think to myself: I'm amazing."
- Peter Serafinowicz
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
PostPosted: Wed Jul 08, 2009 7:09 am    Post subject: Spike catcher diode Reply with quote
One of the battery contactor's large terminals
should be marked "BAT". The diode's banded end
connects to this terminal. The other end goes
to the 3/16" terminal.
This was the image of Van's starter contactor
from his website.
[img]cid:.0[/img]
The right small terminal is marked "I" and
is not used. The left small terminal is power
from the starter push button on the panel.
The banded end of the diode connects to
this terminal also. The other end connects to
one of the contactor's mouning bolts
which is also airframe ground.
 Filesize:  24.5 KB
 Viewed:  17541 Time(s)
longg(at)pjm.com
PostPosted: Wed Jul 08, 2009 8:18 am    Post subject: Spike catcher diode Reply with quote
Wade,
Which approach (Zeners, Diodes or nothing) you choose is up to you. On my website link below you can see where I employed Van’s “blue” starter diode (I have an extra contactor ‘cause it’s IR) which uses the same approach. As Bob indicated I snaked the other end around the contactor to the mounting bolt. Van’s little direction sheet is quite clear – don’t deviate from it. In my case the solenoids are mounted on carbon fiber so I use a ground back to the FG. I haven’t decided if I’m going to use zeeners, diodes or just replace the solenoid on some scheduled basis. I’ve yet to see anything from anyone which shows how much longer (days, weeks or years) a solenoid lasts by adding these gadgets. The problem is real, but actual life expectancy needs to be measured to satisfy my interest. If you are the typical pilot which flies 35 hours / year it will fail from sitting around before it fails from arching.
http://2.bp.blogspot.com/_hkAHk0Xu6wo/SdymLdP-KbI/AAAAAAAAA1A/rF4p8Xvi2UU/s1600-h/IMG_1312.JPG
Glenn
Thanks!
Wade Roe
EAA 557
Aeronca 7AC flying
mprather(at)spro.net
PostPosted: Wed Jul 08, 2009 8:59 am    Post subject: Spike catcher diode Reply with quote
My thinking is that going without spike protection will cause the
controlling switch to have a shorter service life. The high voltage is
across the coil... ANY of the spike protection methods will provide the
controlling switch with a relatively easy life.
The question of WHICH protection method is about RELAY performance and
life. Then too I would expect many of the relays in the airplane to not
particularly care about which protection method is employed. Many of them
aren't switching very high current, at least not very often. The
alternator relay should last "forever" as it should rarely if ever be
asked to switch the alternator when it's making much current.
The starter relay is the one that regularly gets hit hard - switching
hundreds of amps in many aircraft each flight. Setting that relay up to
open and close as succinctly as possible should help its service life. I
would think electrically operated landing gear controlling relays would be
the next one in terms of severity of duty.
Matt-
[quote] Wade,
my website link below you can see where I employed Van's "blue" starter
diode (I have an extra contactor 'cause it's IR) which uses the same
to the mounting bolt. Van's little direction sheet is quite clear -
don't deviate from it. In my case the solenoids are mounted on carbon
fiber so I use a ground back to the FG. I haven't decided if I'm going
basis. I've yet to see anything from anyone which shows how much longer
Glenn
Roe
my very "green" hands regarding electronics...learning!
Thanks!
Wade Roe
EAA 557
Aeronca 7AC flying
wroe1(at)dbtech.net
PostPosted: Wed Jul 08, 2009 2:13 pm    Post subject: Spike catcher diode Reply with quote
Thanks for everyone’s comments.
Wade Roe
-----Original Message----
Sent: Wednesday, July 08, 2009 10:07 AM
Subject: RE: AeroElectric-List: Spike catcher diode
At 10:53 AM 7/7/2009, you wrote: <![if !supportLineBreakNewLine]> <![endif]>
from his website.
 Filesize:  24.5 KB
 Viewed:  17533 Time(s)
bakerocb
PostPosted: Fri Jul 10, 2009 2:35 am    Post subject: Spike catcher diode Reply with quote
7/10/2009
Hello Glenn, You wrote: "I haven't decided if I'm going to use zeeners,
diodes or just replace the solenoid on some scheduled basis. I've yet to see
expectancy needs to be measured to satisfy my interest."
I think that the primary purpose of a spike catcher device is to protect the
points in the switch controlling the current through the solonoid coil. The
switch points are much more fragile and susceptible to failure than the
solonoid contact points.
We frequently see reports of switch point failures, particularly in the
keyed ignition switches.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Time: 09:18:10 AM PST US
Wade,
Glenn
PostPosted: Fri Jul 10, 2009 10:50 am    Post subject: Spike catcher diode Reply with quote
At 09:13 AM 7/8/2009, you wrote:
--> AeroElectric-List message posted by: "Eric M. Jones" <emjones(at)charter.net>
Please cite any posting I've made that could be
reasonably (or even unreasonably) described as a
"flame". They're all in the archives . . . cut and
paste a direct quotation please.
"The job" is not a constant . . . The means
by which "the job" is accomplished is also not
a constant. Many papers have been written on
replay performance and system integration issues.
Some were done by very competent designers who
were marginal writers/teachers. For example: In
the paper at:
http://www.aeroelectric.com/Reference_Docs/Tyco/Tyco-Paper_on_Coil_Suppression.pdf
The paper opens with a concern for damage to
normally open contacts that are switching high-
inrush currents and attributes this to selection
of coil suppression technique. In fact, the damage
being cited is mostly a matter of contact bounce
during a stressful portion of the operating cycle
where contacts close, open and re-close
perhaps a dozen times (at the worst possible moment)
when the switched currents are many times higher than the
steady state ratings of the contacts.
Further, coil suppression has nothing to do with
contactor performance on energizing the coil, only
upon the de-energizing event.
Keep in mind too that these guys write about
RELAYS rated to advertised service life in tens of
thousands if not hundreds of thousands of cycles.
We're discussing battery and starter contactors
that will probably fail due to corrosion before they
die from service life stresses.
Finally, I did real studies of changes to contact
spreading velocity at de-energization for the
two most aggressive devices in the airplane . . .
battery and starter contactors. I thought I might
have obvserved a 2 or 3% increase in arcing time
for diode versus NO coil suppression. How does this
drive a decision to put the hex on the lowly diode
coil suppressor?
See my website or buy your own. The Gigavac GX11 contactor already has bidirectional zeners for coil suppression. Gee, I wonder why!?\
I can suggest a good reason why: Simple diodes are
polarity sensitive . . . I.e. if you build the diode
into the contactor, options for coil connection are
bounded by polarity of the diode. In starter
contactors where diodes are commonly built in, the
base of the contactor is always (-) so the built in
diode offers low risk for miswiring. Bi-directional
Transorbs are goof-proof.
The bi-directional zener offers a form of coil energy
suppression that is not polarity sensitive and dissipates
stored inductive energy in a combination of coil resistance
and I*E product of the zener. Further current tending
to keep the contactor closed after deenergizing has
a lower on-set value . . . hence the faster drop-out
response.
So why bring it up again? I've measured, demonstrated and
explained the value/function of the various coil transient
suppression methods on the devices we're talking about . . .
CONTACTORS.
http://tinyurl.com/mcgg87
On your website at:
http://www.periheliondesign.com/suppressors.htm
you say . . .
"Thus a large voltage­1000V to 1500V typically­is induced
current did­so it slows the contact opening­allowing arcing,
chatter, bouncing, contact welding and even re-closure!"
The first statement is correct, the voltage is high . . . but
fails to say where it goes or what devices are placed at risk.
A diode delays contact opening after the coil power is removed. But
differences in contact spreading velocity are so small (if they
exist at all) as to be difficult to measure. I challenge you to
go to the workbench and show me a setup that produces bounce,
chatter, increased arcing, tendencies to weld N.O. contacts
upon de-energization, and/or evidence of re-closure as a
consequence of simple diode coil suppression.
If not demonstrable, how about a hypothesis as to how
contacts that are moving away from each other are subject
to a force that accelerates the contact mass in the opposite
direction and effects re-closure? May I suggest this notion is
absurd the the extreme?
Your hypothesized 60v transient generated by simply turning
off a large load is also in error. This event happens during
the automotive definition of load dump that includes a
BATTERY DISCONNECT. Alternators that go through MPA's
rebuild facilities are tested for it's effect on the
alternator . . . believe me it can be a whole lot worse
than 60V. But this is rare in airplanes. What's the likelihood
that dropping a max rated load is exactly coincident with
opening the battery contactor? In your functional description
at:
http://www.periheliondesign.com/suppressors/Whackjack%20Manual.pdf
There's no mention of battery disconnect . . . hence the
60v number is hyperbolic persuasion. Your citation of
FAR 25.581 is equally hyperbolic. If you're going to evoke
lightning qualification issues to an RV, then believe me,
the task is about 100x more complex than adding a "WhackJack"
to the system.
I've managed numerous investigations into relay and switch
contact failures in 40+ years of hammering on airplanes.
It was not uncommon to discover things about some products
than the "engineers" and "manufacturer's reps" assigned to
support those products did not know. Quite often,
those individuals were tasked with supporting a legacy
product they didn't design and never integrated into
a system.
There's an archive of Tyco publications on the subject
at:
These are largely factual and the ideas presented are useful
to consider where applicable . . . but they don't apply
to what we've been talking about.
If you choose to play in this sandbox, bring the right
shovel, bucket and support them with a willingness to explain
and teach. I'm sure that your products perform as they
are intended to by their designers. But their prophylactic
application to ward off the gremlins described on your
website is not consistent with what we have known about electrical
systems (and their component parts) in airplane for over 100 years.
PostPosted: Fri Jul 10, 2009 11:35 am    Post subject: Spike catcher diode Reply with quote
I haven't decided if I'm going to use zeeners, diodes or just
The inclusion of coil suppression is for the benefit of the
controlling device (switch or push-button). From the time
that batteries and starters went into light airplanes (1945?)
until the rectifier diodes came to Cessna's attention (1963?)
there was no coil suppression on battery or starter contactors.
We had a devil of a time converting a leaded electronic component
into an airplane part. We COULD have attached the diodes like
this . . .
http://www.aeroelectric.com/Pictures/Contactors/s701-1.jpg
But somebody decided to mount the diodes on little strips
of phenolic sheet with eyelets at the ends to accept
screws and wires with terminals crimped on them. Added a
whole lot of labor and fragility to an otherwise inexpensive,
robust device. I note that the Cessna Service parts lists
still show a lot of "diode assemblies" for $15 to $50. So
I guess they're still sticking diodes on some form of
built-up assembly.
Even today, plain-vanilla diodes are used across contactors
in production aircraft.
Excellent question. I don't recall that we were ever aware
of a service life "problem" with either contactors or their
controlling switches in the years before diodes. But I
recall Gordon Wood (our PhD physicist) putting a H-P peak-
reading voltmeter across a contactor coil, seeing a 500+ volt
reading and saying, "Hot damn . . . we need to do something
about that!" And we did.
Given that we were unaware of service life issues attributable
to LACK of DIODES, we were destined to be equally ignorant of
service life benefits after diodes were ADDED. But we sure took
care of that 500v spike! I don't think Gordo ever put a 'scope
on the system to see where the spike goes. I suspect he would
have seen this:
http://www.aeroelectric.com/articles/Spike_Catching/CH_Opening_No_Suppression.gif
Noise conducted to the bus is very low energy, low amplitude
compared to what the controlling switch sees.
Exactly! There's a ton of papers written to the task of
wringing the last few hours of service life from various products
rated in gazillions of cycles.
But if there was ever a low duty-cycle application for any
electro-whizzy, it's the personally owned light airplane,
snow-mobile, or bass boat.
Your perception of effects of age and environment being
more profound than effects of service life is quite
accurate!
jonlaury
PostPosted: Mon Jul 13, 2009 10:45 am    Post subject: Spike Catcher Diode Reply with quote
As long as this subject has bubbled up, I'd like to know how to test my contactors to see if they have internal SCD's. It's been nagging at me for awhile and I'm nearing installing them.
John
wroe1(at)dbtech.net
PostPosted: Mon Jul 13, 2009 1:52 pm    Post subject: Spike Catcher Diode Reply with quote
I know that the Vans contactors do not have diodes. Not sure about those from other sources.
Wade RoeIPhone message
On Jul 13, 2009, at 1:37 PM, "John Burnaby" <jonlaury(at)impulse.net (jonlaury(at)impulse.net)> wrote:
[quote] As long as this subject has bubbled up, I'd like to know how to test my contactors to see if they have internal SCD's. It's been nagging at me for awhile and I'm nearing installing them.
John
PostPosted: Mon Jul 13, 2009 4:35 pm    Post subject: Spike Catcher Diode Reply with quote
The only contactors that I've sold with built in
diodes said so on the bottom of the mounting
bracket. If you have a 'scope it's easy to tell
in a simple bench test setup (or just keep your
fingers across the coil contacts while you break
the circuit . . . if you don't "jump" then
there's a diode installed.
Given that they are easy to get and inexpensive,
put them on unless you already KNOW that they're
present inside. Very few contactors come with them
built in . . . I had to search for the one I
sold.
PostPosted: Mon Jul 13, 2009 5:10 pm    Post subject: Spike Catcher Diode Reply with quote
Seems like you could test for a diode with a 9V battery and a volt meter..
Apply voltage to the coil in one direction, and something close to the
full voltage of the battery should be present.. Swap the terminals on the
battery, and the voltage on the coil should be limited to a diode drop -
maybe about 0.8V depending on what kind of diode they use.
I don't think this method would put any of the components involved at risk.
Matt-
sold.
PostPosted: Tue Jul 14, 2009 4:33 am    Post subject: Spike Catcher Diode Reply with quote
MUCH better idea! Actually, if the 9V battery is fresh,
the contactor will pull in for BOTH directions of battery
connection if NO diode is present . . . and FAIL to pull
in for ONE direction if diode IS present.
