Clive J
Posted: Tue Jun 30, 2009 12:12 am Post subject: Clearance between cowling and exhaust pipe |
I've got the big daft single down pipe on my exhaust and have to cut out the cowling to go round it.
How much should I make the gap so that the fibreglass doesn't get scorched?
I've got about 1/8" at the moment, enough?
Regards, Clive [quote][b]
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
info(at)flylightning.net Guest
Posted: Tue Jun 30, 2009 5:23 am Post subject: Clearance between cowling and exhaust pipe |
Clive,
1/8” should be ok. I would go with a ¼”. Than you can get some ¼” thick PVC pipe and slide it over the tail pipe for a spacer, than lay glass from the cowl over the pipe to make a exhaust tunnel, looks really good.
Nick
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of James, Clive R
Sent: Tuesday, June 30, 2009 3:10 AM
To: lightning-list(at)matronics.com
Subject: Clearance between cowling and exhaust pipe
Regards, Clive Quote: | http://www.matronics.com/Navigator?Lightning-List | 0123456789
N1BZRich(at)AOL.COM Guest
Posted: Tue Jun 30, 2009 5:59 am Post subject: Clearance between cowling and exhaust pipe |
Close testing show 47.5knts calibrated….well that’s what I like to believe. Should add 50knts to the looks though!
nick
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of N1BZRich(at)aol.com
Sent: Tuesday, June 30, 2009 8:31 AM
Subject: Re: Lightning-List: Clearance between cowling and exhaust pipe
Clive,
I would also recommend 1/4" as Nick suggested. Remember the engine will actually move around a little in flight as you pull Gs. Those rubber shock mounts really help to reduce any major vibrations from being transmitted to the fuselage, but they do allow the engine to move around some - as they were designed to do. The exhaust tunnel that Nick mentioned really does look nice and gives a great finished look. Might even add at least 50 knots.
Buz
Make your summer sizzle with fast and easy recipes for the grill.
dashvii(at)hotmail.com Guest
Clive J
Posted: Wed Jul 01, 2009 11:25 pm Post subject: Clearance between cowling and exhaust pipe |
The 'tunnel' sounds a good idea which I'll fit. Thanks.
Next question, how long should I make the end on the exhaust that comes out of the cowling? Currently it's 10" out of the bottom of the cowling which puts the tail pipe 6.5 inches clear of the fuselage belly. I figure I can trim some off, after flying my Jabiru with hot feet for 10 years I'd like to avoid that but minimise the protuberance (big word...).
Thanks again guys, Regards, Clive
[img]cid:015561907(at)02072009-1BE0[/img]
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
