kearney
Posted: Sun Jun 28, 2009 10:12 am Post subject: Fibreglass fasteners |
Hi
I am working on my canopy and have a small access cover that I want to attach. What are the recommended fasteners for fibreglass? Ideally I would like to be able to use small screws but need to know the best way to attach the screws to the canopy.
Any suggestions from the fibreglass mavens?
Cheers
Les
#40643 – Living in a fibreglass world
Deems Davis
Posted: Sun Jun 28, 2009 3:17 pm Post subject: Fibreglass fasteners |
Les, depending on the use of the cover, If it's going to be removed
infrequently and is not subject to a lot of direct vibration,
countersink the fiberglass and use a countersunk AN screw. As you know
fiberglass can 'wallow' around any hole if it's not very thick, In these
cases you can use a countersunk washer to backup the screw and prevent
the wallowing. If you want to go one step further and hide the
countersunk washers, I just helped a friend on the field who was redoing
his wheel pants, and we used a spot face to relieve the fiberglass
surface just enough enough to embed the countersunk washers in flox,
then cleaned everything up and filled the washers with Metal Glaze, used
a countersink to clean out the hole, sanded, primed and painted, It
looks great and is stronger than just the glass itself.
Deems
Les Kearney wrote:
Hi
Cheers
Les
Posted: Sun Jun 28, 2009 4:13 pm Post subject: Fibreglass fasteners |
Lol.....glassing in CS washers....guess I'm not as anal as I thought I was....there is someone worse!!!
Rick Sked
N246RS
Sent via BlackBerry by AT&T
Deems Davis
Posted: Sun Jun 28, 2009 7:23 pm Post subject: Fibreglass fasteners |
Careful, the Groupies are restless!
Deems
Rick Sked
N246RS
