mjpienaar(at)shaw.ca Guest
Posted: Tue Apr 07, 2009 8:33 pm Post subject: Electrical, Fuel system and other questions |
Hi All,
I hope to be installing a supercharged M332 in the next couple of month's and have a few questions after going through the engine installation manual. The motor is still in the crate and sealed so I can't look too closely to see what I've got.
It has a 12 volt alternator, will it have an internal or external regulator and are there any other electrical pointers you can give me, I've looked at the engine installation manual but the quality of the printing is so poor I can hardly read anything.
Where do I get a starter buzzer?
For the fuel system, where do I get a "hand operated pump" or has anybody found a substitute for this.
Has anybody built their own oil tank and do you have any plans or hints for this.
I'm building a low wing aircraft, best place to see what it looks like is here http://kisbuild.onfinal18.com/
Thanks for the help
| | - The Matronics Lom-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lom-List |
sbeaver(at)columbus.rr.co Guest
Posted: Wed Apr 08, 2009 3:57 am Post subject: Electrical, Fuel system and other questions |
Yes, you probably need a regulator. Can’t say which type without knowing the alternator model.
Starter buzzers are advertised by Moravia – Perhaps there is one in the box with your engine ?
You most likely don’t really need an external pump. The LOM fuel pump and fuel injection system are one and the same. If it fails, an external pump is not going to help. You could use a small Facet electric pump to prime the plumbing on first start though.
You can make an oil tank or adapt one from another source. I made one from cardboard to check fit, then cut it out of soft aluminum and had it welded by an expert aluminum welder.
Good luck.
On 4/8/09 12:32 AM, "Mike Pienaar" <[url=mjpienaar(at)shaw.ca]mjpienaar(at)shaw.ca[/url]> wrote:
[quote]Hi All,
Thanks for the help
ail Forum -
">http://www.matronics.com/Navigator?Lom-List
; - MATRONICS WEB FORUMS -
matronics.com
;- List Contribution Web Site -
; -Matt Dralle, List Admin.
://www.matronics.com/contribution
bobf(at)feldtman.com Guest
Posted: Wed Apr 08, 2009 8:04 am Post subject: Electrical, Fuel system and other questions |
I converted the buzzer to a slick-start - starts much faster - Buzzers are about 500 bucks from Moravia in Canada. If you want mine, it is available contact me off line (bobf(at)feldtman.com (bobf(at)feldtman.com))
Ditto on the fuel pump. I do have a facet, for the purposes noted, and actually, put a line with a electrical temporary valve to prime the engine for start with the facet.
I've just encountered some problems with my LOM, huge oil usage, an engine near failure on downwind at about 1000 feet, with sever rough and loss of power thank goodness I was on a "downwind leg" as I was departing the airport, and landed fine.
We'll see what gives.
I might be looking at some major work
bobf
On Wed, Apr 8, 2009 at 6:56 AM, Stephen Beaver <sbeaver(at)columbus.rr.com (sbeaver(at)columbus.rr.com)> wrote:
[quote] Yes, you probably need a regulator. Can’t say which type without knowing the alternator model.
Good luck.
On 4/8/09 12:32 AM, "Mike Pienaar" <mjpienaar(at)shaw.ca> wrote:
| Quote: | Hi All,
Thanks for the help
ail Forum -
matronics.com
Posted: Wed Apr 08, 2009 3:16 pm Post subject: Electrical, Fuel system and other questions |
Thanks for the response.
Bob, I would like to know a bit more about the electrical temporary valve that you put in to prime the engine. A photo or general description would be appreciated. Good luck with the repairs, hope it is not as bad as it sounds.
Stephen, is the tank just a tank, if that makes any sense, the engine installation manual shows 2 drainage valves and a de-aerator which looks like a tube inside the oil tank that goes from the bottom to the top and the top end is open inside the tank and the bottom of the tube is connected to the engine. The manual is not very clear on what connects to where. What capacity did you make the tank?
Thanks again for the help
Posted: Wed Apr 08, 2009 3:23 pm Post subject: Electrical, Fuel system and other questions |
A lot of the complexity in the tank shown in the manual comes from accommodation of an inverted system. - Not something you will use much in a KIS.
Basically you will need an outlet at the bottom, a return line near the top, a vent line and a filler cap. Not much more than that. I would make it of at least 8 qts capacity, no more than 10 and plan to keep it 2/3 full.
Steve
On 4/8/09 7:14 PM, "Mike Pienaar" <[url=mjpienaar(at)shaw.ca]mjpienaar(at)shaw.ca[/url]> wrote:
[quote]Thanks for the response.
Posted: Wed Apr 08, 2009 3:37 pm Post subject: Electrical, Fuel system and other questions |
Stephen, thanks for your quick response, where does the vent line connect to or does it just vent the tank overboard?
10kDA
Posted: Wed Apr 08, 2009 3:38 pm Post subject: Electrical, Fuel system and other questions |
Glad you're OK, Bob. Keep us in the loop about the problems.
Chris
--- On Wed, 4/8/09, Robert Feldtman <bobf(at)feldtman.com> wrote:
| Quote: | From: Robert Feldtman <bobf(at)feldtman.com>
Subject: Re: Electrical, Fuel system and other questions
To: lom-list(at)matronics.com
Date: Wednesday, April 8, 2009, 11:03 AM
- Buzzers are
it is available
contact me off line (bobf(at)feldtman.com)
noted, and
prime the engine
rough and loss of
I was departing the
bobf
> with your engine ?
> Good luck.
> Hi All,
> see what I've got.
> this.
> Thanks for the help
> Mike
> ail Forum -
> matronics.com
Posted: Wed Apr 08, 2009 3:57 pm Post subject: Electrical, Fuel system and other questions |
It just vents overboard to allow for expansion.
Steve Beaver(614) 937 4189
On Apr 8, 2009, at 7:36 PM, "Mike Pienaar" <mjpienaar(at)shaw.ca (mjpienaar(at)shaw.ca)> wrote:
[quote] Stephen, thanks for your quick response, where does the vent line connect to or does it just vent the tank overboard?
Posted: Wed Apr 08, 2009 4:17 pm Post subject: Electrical, Fuel system and other questions |
will let you know the final.
bobf
On Wed, Apr 8, 2009 at 6:35 PM, Chris Kinnaman <dogspiritnow(at)yahoo.com (dogspiritnow(at)yahoo.com)> wrote:
[quote]--> Lom-List message posted by: Chris Kinnaman <dogspiritnow(at)yahoo.com (dogspiritnow(at)yahoo.com)>
Chris
--- On Wed, 4/8/09, Robert Feldtman <bobf(at)feldtman.com (bobf(at)feldtman.com)> wrote:
> From: Robert Feldtman <bobf(at)feldtman.com (bobf(at)feldtman.com)>
| Quote: | Date: Wednesday, April 8, 2009, 11:03 AM
| Quote: | I converted the buzzer to a slick-start - starts much faster
> - Buzzers are
> it is available
> noted, and
> prime the engine
> rough and loss of
> I was departing the
> bobf
> > with your engine ?
> > Good luck.
> > Hi All,
> > see what I've got.
> > this.
> > Thanks for the help
> > Mike
> > ail Forum -
> > matronics.com
| Quote: | > ;- List Contribution Web Site -
rget="_blank">http://www.matronics.com/Navigator?Lom-List
http://forums.matronics.com
le, List Admin.
