wroe1(at)dbtech.net Guest
Posted: Tue Jun 23, 2009 6:11 am Post subject: Dual mags now...one Plasma II plus later |
My plan is to fly off several hours in the RV-7 using two Slick mags
before transitioning over to a one mag and Plasma II plus system. With
this in mind, what is the best way to spec-out and set-up the ignition
switches? I am referencing Z-13/8 AEC as the basis for my design. The
Z-13 diagram shows an s700-1-3 and a s700-2-10. Perhaps a s700-2-50
would make more sense.
Wade Roe
EAA 557
Aeronca 7AC flying
RV-7 in process
Posted: Tue Jun 23, 2009 7:33 am Post subject: Dual mags now...one Plasma II plus later |
At 08:58 AM 6/23/2009, you wrote:
A pair of S700-1-3 switches will do fine for both the pair
of mags and for the final configuration.
( -Thomas Paine 1776- )
Posted: Tue Jun 23, 2009 8:16 am Post subject: Dual mags now...one Plasma II plus later |
Thanks for the input!
Wade Roe
SOUTHERN CARBIDE TECHNOLOGIES, INC.
7739 Unity Road M&D Industrial Park
Tuscaloosa, AL 35401
205-248-6700
205-248-6372 fax
bicyclop(at)pacbell.net Guest
Posted: Thu Jun 25, 2009 8:03 pm Post subject: Dual mags now...one Plasma II plus later |
Yup, but you'll need to turn one of the switches over when you want to
use it to switch the ei. The mag switch closes to turn the mag off, but
the ei switch will close to turn on. You want the "up" position to be on.
Pax,
Ed Holyoke
<nuckolls.bob(at)aeroelectric.com>
Posted: Thu Jun 25, 2009 8:34 pm Post subject: Dual mags now...one Plasma II plus later |
At 11:58 PM 6/25/2009, you wrote:
to use it to switch the ei. The mag switch closes to turn the mag
off, but the ei switch will close to turn on. You want the "up"
position to be on.
No, the 1-3 switches are single pole, two position switches.
They function for either breaking power to an electronic
ignition -OR- grounding a magneto by simply moving a wire
to the opposite terminal.
Posted: Fri Jun 26, 2009 10:04 pm Post subject: Dual mags now...one Plasma II plus later |
I get it. I was thinking of the 1-2 swiches.
Pax,
Ed Holyoke
> <bicyclop(at)pacbell.net>
> position to be on.
