Quick Drain
recapen(at)earthlink.net
PostPosted: Fri Jun 19, 2009 9:50 am    Post subject: Quick Drain Reply with quote
Curtis took my quick drain and drilled it for safety wire - evidently a bad one slipped through as their website says they should be drilled.
They also gave me the proper torque setting for the fitting.
I had already put it back together with the original plug - didn't want to wait another weekend and the flying weather was good.
Just thought I should notify everyone of the outcome.
Ralph Capen
brucebell74(at)sbcglobal.
PostPosted: Fri Jun 19, 2009 10:42 am    Post subject: Quick Drain Reply with quote
So what is the torque setting?
RV-4 N23BB
PostPosted: Fri Jun 19, 2009 10:53 am    Post subject: Quick Drain Reply with quote
I've got it at home - I'll post it
PostPosted: Fri Jun 19, 2009 4:14 pm    Post subject: Quick drain Reply with quote
Here's the torque and sealant that they specified:
Torque Value = 15-18 ft lbs.
Use Teflon tape or equivalent sealant
This is for the CCA1700 quickdrain valve from Curtis.
