Rear baggage wall access panel
wayne.e(at)grandecom.net
PostPosted: Wed Jun 17, 2009 3:23 pm    Post subject: Rear baggage wall access panel Reply with quote
I saw a post at one time where one of you made an access panel in the back baggage wall and am trying to locate the person that did that and see his pictures of the panel. I just finished my second conditional and made up my mind I've got to do something that make it easier for that back area access. Tons of screws to remove and undoing the seat belts etc. I also have my oxygen tank attached to the back baggage wall area, which I took the idea from Randy's web site.
So whoever that was I hope you can post your idea so I can copy you.
Wayne Edgerton N602WT
Deems Davis
PostPosted: Wed Jun 17, 2009 3:50 pm    Post subject: Rear baggage wall access panel Reply with quote
Wayne, here's a link to a photo album, that shows how I did mine, I
copied the idea from Robin Marks. just follow the links to next image
there should be about 20 pics that show the process.
http://deemsrv10.com/album/Sec%20The%20Home%20Stretch/slides/DSC06496.html
Deems Davis N519PJ
ricksked(at)embarqmail.co
PostPosted: Wed Jun 17, 2009 3:52 pm    Post subject: Rear baggage wall access panel Reply with quote
Ck Robin Marks site. I copied his
Sent via BlackBerry by AT&T
effectus(at)rogers.com
PostPosted: Wed Jun 17, 2009 4:05 pm    Post subject: Rear baggage wall access panel Reply with quote
Wayne,I did that mod to the rear baggage wall. I'll get a couple of photos tomorrow and e-mail them to you. I am not sure how to post photos. - will also put a write-up about it on my blog. Here is the link wwwmkitaircraftmods.comDaveFitting the door hardware.
Sent from my BlackBerry device on the Rogers Wireless Network
Date: Wed, 17 Jun 2009 18:22:09 -0500
Subject: RV10-List: Rear baggage wall access panel
I saw a post at one time where one of = you made an=20 access panel in the back baggage wall and am trying to locate the person = that=20 did that and see his pictures of the panel. I just finished my second=20 conditional and made up my mind I've got to do something that make it = easier for=20 that back area access. Tons of screws to remove and undoing the seat = belts etc.=20 I also have my oxygen tank attached to the back baggage wall area, which = I took=20 the idea from Randy's web site.
So whoever that was I hope you can post = your idea=20 so I can copy you.
_-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - The RV10-List Email Forum - _-=3D Use the Matronics List Features Navigator to browse _-=3D the many List utilities such as List Un/Subscription, _-=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, _-=3D Photoshare, and much much more: _-=3D _-=3D --> http://www.matronics.com/Navigator?RV10-List _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - MATRONICS WEB FORUMS - _-=3D Same great content also available via the Web Forums! _-=3D _-=3D --> http://forums.matronics.com _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - List Contribution Web Site - _-=3D Thank you for your generous support! _-=3D -Matt Dralle, List Admin. _-=3D --> http://www.matronics.com/contribution _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
gengrumpy(at)AOL.COM
PostPosted: Wed Jun 17, 2009 5:14 pm    Post subject: Rear baggage wall access panel Reply with quote
I'd be a little cautious about cutting the panel as it may affect
strength of the bulkhead as designed by Van's.
Might check with them before shortcutting potential strength design.
grumpy
N184JM
image there should be about 20 pics that show the process.
Deems Davis N519PJ
> site.
> do not archive
robin1(at)mrmoisture.com
PostPosted: Wed Jun 17, 2009 5:33 pm    Post subject: Rear baggage wall access panel Reply with quote
Wayne, I think that is my build. My only regret is that’s it’s not even larger or add a second one. Tremendous for Battery access etc.. My O2 filler connect is also located there.
On important component. Use a split hinge pin to allow for easy removal.
A slightly different design is to have the door hinge at the top and hold it up by a simple Velcro strap or the like.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Wednesday, June 17, 2009 4:22 PM
Subject: Rear baggage wall access panel
Checked by AVG - www.avg.com
06/17/09 05:53:00
 Filesize:  184.31 KB
 Viewed:  9103 Time(s)
 Filesize:  176.94 KB
 Filesize:  148.93 KB
 Filesize:  58.16 KB
Tim Olson
PostPosted: Wed Jun 17, 2009 6:24 pm    Post subject: Rear baggage wall access panel Reply with quote
Actually, I've heard many times that it is a structural wall,
and that you can't fly without it, and if you alter the back
wall you want to make sure it's sufficiently beefed up to
give it back it's structural-ness. So, if you cut into it,
just plan ahead to make sure you do all you need to make it
just as strong again. Contacting Vans on that one wouldn't
be a bad idea.
Tim Olson - RV-10 N104CD
grumpy
N184JM
> Deems Davis N519PJ
>> do not archive
indigoonlatigo(at)msn.com
PostPosted: Wed Jun 17, 2009 7:34 pm    Post subject: Rear baggage wall access panel Reply with quote
There is a reason for all those corregations
[quote] Date: Wed C 17 Jun 2009 21:24:03 -0500
Subject: Re: Rear baggage wall access panel
dave.saylor.aircrafters(a
PostPosted: Wed Jun 17, 2009 10:11 pm    Post subject: Rear baggage wall access panel Reply with quote
In a past life, I used to have to pull off this one little 6" x 6" plate that had a screw about every inch around the perimeter--it was a structural panel.  Unfortunately, that's usually true of anything with a lot of screws/bolts/rivets/welds..."lots of screws" should be the first sign that maybe it needs more than casual treatment!  Not that it can't be doubled up or reinforced, but it's worth checking.
Dave
On Wed, Jun 17, 2009 at 7:24 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
be a bad idea.
Miller John wrote:
--> RV10-List message posted by: Miller John <gengrumpy(at)aol.com (gengrumpy(at)aol.com)>
I'd be a little cautious about cutting the panel as it may affect strength of the bulkhead as designed by Van's.
grumpy
N184JM
--> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net (deemsdavis(at)cox.net)>
Wayne, here's a link to a photo album, that shows how I did mine, I copied the idea from Robin Marks. just follow the links to next image there should be about 20 pics that show the process.
Deems Davis N519PJ
le, List Admin.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
dlm46007(at)cox.net
PostPosted: Thu Jun 18, 2009 6:57 am    Post subject: Rear baggage wall access panel Reply with quote
One other consideration. You might substitute screws in the baggage area. I used the NAS comb external hex head and internal Phillips head. meets or exceeds fastener standards and can be removed with an electric drill and nut driver or ratchet. Takes me five minutes to remove the screws with the Makita and since I have the overhead inertial reels a ratchet to remove the two screws behind the reels. I think a call to Vans is in order given the corrugations in the panel.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor
Sent: Wednesday, June 17, 2009 11:10 PM
Dave
be a bad idea.
grumpy
N184JM
Deems Davis N519PJ
le, List Admin.
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
rene(at)felker.com
PostPosted: Thu Jun 18, 2009 7:39 am    Post subject: Rear baggage wall access panel Reply with quote
David…….can you give us the part number on those screws? Sound like a great upgrade for my next annual…condition inspection. Those Phillips head screws behind the reels are a real pain in the butt.
FYI…the seat belts are working out great…. J
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Thursday, June 18, 2009 8:55 AM
Subject: RE: Rear baggage wall access panel
Dave
be a bad idea.
grumpy
N184JM
Deems Davis N519PJ
le, List Admin.
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c
nukeflyboy
PostPosted: Thu Jun 18, 2009 8:55 am    Post subject: Re: Rear baggage wall access panel Reply with quote
Listen carefully to what Tim and Grumpy are saying. I'll be more blunt. The baggage bulkhead IS a structural component and is necessary for asymmetrical HS loading/twisting moments. (Sound familiar? Check the tail SB). That is the reason for the corrugations and all of the screws. It must not be compromised for ease of access. I do not like what I see in the photos.
Dave Moore
RV-6 built and sold
RV-10 built and flying
dlm46007(at)cox.net
PostPosted: Thu Jun 18, 2009 9:27 am    Post subject: Rear baggage wall access panel Reply with quote
check http://www.aircraftspruce.com/catalog/hapages/nas1096.php
Also I used CS with an internal hex head for the last two screws on the forward tunnel edge. Wrong CS angle but certainly easier to use, an allen wrench removes rather tha pressure on a Phillps head.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker
Sent: Thursday, June 18, 2009 8:34 AM
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Dave
be a bad idea.
grumpy
N184JM
Deems Davis N519PJ
le, List Admin.
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
5 [quote][b]
dlm46007(at)cox.net
PostPosted: Thu Jun 18, 2009 9:44 am    Post subject: Rear baggage wall access panel Reply with quote
Also there are other places on the airframe where the NAS hex heads are more maintenance friendly. The lower cowl where the center piece connects to the cowl and the firewall.Put the Makita and a 1/4" 12p socket on a 1/4 drive extension and they are easy out. Inspection panels under the seats are 8 screws and easy out. I bought #10, #8, and #6 in 100 count bags.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Dave
be a bad idea.
grumpy
N184JM
Deems Davis N519PJ
le, List Admin.
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
5 [quote][b]
dlm46007(at)cox.net
PostPosted: Thu Jun 18, 2009 10:22 am    Post subject: Rear baggage wall access panel Reply with quote
One other thing. use the Makita torque setting at lowest 1? Then the screws can be removed next time with a reverse torque setting 2 o3?.
Sent: Thursday, June 18, 2009 10:39 AM
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Dave
be a bad idea.
grumpy
N184JM
Deems Davis N519PJ
le, List Admin.
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
5
6 [quote][b]
karolamy(at)roadrunner.co
PostPosted: Thu Jun 18, 2009 11:24 am    Post subject: Rear baggage wall access panel Reply with quote
be a bad idea.
Yes, Vans will more than discourage any modification of the rear baggage
bulkhead. However, looking at the pictures of Deems and Waynes door, I
think if you were to use #4 rivets along the supporting frame not #3's, AND
used the same hinge program at the bottom but used ( 9 qty.) #8 nutplates
and screws - 3, on each side as well as 3 along the top, your strength would
be there. Yes, you still have 9 screws to remove (with a screw gun this is
only minutes) but still way less than the 25 - 30 it takes to remove the
entire bulkhead.
Which now leads to the next question of if this modified portion of the
bulkhead is now stronger than the other side of the bulkhead how does that
effect the integrity of the part as designed? Just a question to ponder -
no replys needed....
Rich Hansen
10 - Finishing kit
RV-6A, 1000 hrs
Ron.McGann(at)thalesgroup
PostPosted: Thu Jun 18, 2009 2:46 pm    Post subject: Rear baggage wall access panel Reply with quote
FWIW, a mod that I made to the baggage bulkhead was the simple addition
of a couple of female terminals that paralleled the battery. This
allowed me to directly monitor the battery state (by multimeter) both on
the ground and in flight, recharge the battery, and supplement the
battery with a DC power supply for avionics testing/setup; without
having to remove the bulkhead. I would do it again in an instant.
Ron
VH-XRM in Oz
Albert Gardner
PostPosted: Thu Jun 18, 2009 3:47 pm    Post subject: Rear baggage wall access panel Reply with quote
An outfit called Microfasteners.com makes a Torx equivalent flat and round head screw. I have used these and like the fact that you don’t have to push like you do on Phillips screws. Better make sure you carry some Torx wrenches with your emergency maint kit if you use them however. (They call them 6 lobe screws and avoid the Torx name.)
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
