IFR Certification
Speedy11(at)aol.com
PostPosted: Wed Jun 10, 2009 9:23 am    Post subject: IFR Certification Reply with quote
This may not be the ideal forum for asking this question, but I'll try it anyway.
I want to certify my RV-8 for IFR flight. I know the FARs - I've looked at them.
I have the Blue Mountain EFIS One as primary instrumentation.
I have the Blue Mountain EFIS Lite as a backup.
Both EFISs are on different electrical busses - the main and the standby. - which can be tied together, if needed.
I asked a local avionics guy about doing a pitot-static and transponder check for IFR. He said I would have to install a separate altimeter and encoder in order to get IFR certification. The EFIS has a built-in encoder.
Has anyone else encountered this obstacle?
Stan Sutterfield
Dell Inspiron 15 Laptop: Now in 6 vibrant colors! Shop Dell's full line of laptops.
frank.hinde(at)hp.com
PostPosted: Wed Jun 10, 2009 10:25 am    Post subject: IFR Certification Reply with quote
Nonsence!..He'll be telling you you need a vacuum pump next!
I have a Dynon D100 that does the altitude encoding and there is certainly no requirement for a second altimeter.
Go elsewhere..
Frank
7a IFR
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com
Sent: Wednesday, June 10, 2009 10:21 AM
Subject: IFR Certification
Stan Sutterfield
ist">http://www.matronics.com/Navigator?AeroElectric-List
ics.com
.matronics.com/contribution
n8zg(at)mchsi.com
PostPosted: Wed Jun 10, 2009 10:40 am    Post subject: IFR Certification Reply with quote
Stan –
Other folks have had similar issues.  Some avionics shops demand TSOd equipment, then can’t quote chapter and verse of the reg that requires it.
The technician’s task is to test the equipment as installed and verify that the data it puts out is accurate within limits, not to pass judgment on your choice of hardware.
Find yourself another shop.
Neal
Stan Sutterfield
stein(at)steinair.com
PostPosted: Wed Jun 10, 2009 11:27 am    Post subject: IFR Certification Reply with quote
This is a rather common occurance by shops that are either uneducated or inexperienced with experimental aircraft. Sometimes it's also as a result of naiive FSDO people as well. Basically the information provided to you is completely false and not correct. The EFIS with it's encoder is just fine....so is it's altimeter - assuming both will pass an IFR check. We have our FAA Repair Station Certification and do a lot of said pitot static and/or transponder checks on both certified and experimentals. Should be no problem if you find the right people or right shop.
Cheers,
Stein
[quote] -----Original Message-----
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Speedy11(at)aol.com
Sent: Wednesday, June 10, 2009 12:21 PM
Stan Sutterfield
bakerocb
PostPosted: Thu Jun 11, 2009 5:09 am    Post subject: IFR Certification Reply with quote
6/11/2009
Hello Stan, You wrote: "This may not be the ideal forum for asking this
question, but I'll try it anyway."
Actually, this is the ideal forum for asking this question.
This topic has been hashed out extensively on the aeroelectric list. If you
are interested in better understanding the situation go to the aeroelectric
archives and search for "encoder approval". You will find many entries under
this search phrase and there are other search phrases that will also
generate past postings on this subject.
To save you some time searching take a look at some of the postings in
August , 2006 with the subject "encoder approval".
You received some good advice in response to your posting copied below --
just go to another agency capable of performing the required 14 CFR 91.411
"IFR certification" tests and have them perform the tests and provide the
paper work. You'll be joining hundreds of other amateur builders happily
flying IFR with non TSO'd altitude encoders that have passed the required
tests of 14 CFR 91.411.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
PS: Stein Bruch wrote: " Basically the information provided to you is
completely false and not correct."
That is not entirely true. In defense of your local avionics guy he is
taking the same position that FAA headquarters took on the altitude
encoder -- that is, the altitude encoder must either be TSO'd or be tested
in accordance with 14 CFR paragraph 91.217 (b). The tests that FAA
headquarters described for compliance with 91.217 (b) are very elaborate and
extensive.
Time: 10:23:41 AM PST US
anyway.
them.
er.
Stan Sutterfield
Speedy11(at)aol.com
PostPosted: Thu Jun 11, 2009 6:11 am    Post subject: IFR Certification Reply with quote
Thanks for all the responses.
I will use this guy to do the initial VFR certification because he will come to me rather than me having to take the airplane to him. Then maybe I'll just fly it to Stein's place and get him to do the IFR cert for me.  : )
Stan Sutterfield
Dell Deals: Don't miss huge summer savings on popular laptops starting at $449.
PostPosted: Thu Jun 11, 2009 6:43 am    Post subject: IFR Certification Reply with quote
Don't if it was legal but I didn't do a VFR cert..I just labeled the Transponder "Inooperative" and flew it to get the IFR cert done...Why pay twice if you don't have to?
Frank
Sent: Thursday, June 11, 2009 7:11 AM
Subject: Re: IFR Certification
Stan Sutterfield
ics.com
longg(at)pjm.com
PostPosted: Thu Jun 11, 2009 8:18 am    Post subject: IFR Certification Reply with quote
Stan,
This is the “birds of a feather theory�. Stay away from folks that have their mental investment too deep in the Piper manuals. They really do mean well but…
Glenn
Sent: Thursday, June 11, 2009 10:11 AM
Subject: AeroElectric-List: Re: IFR Certification
Stan Sutterfield
  _-============================================================_-=          - The AeroElectric-List Email Forum -_-= Use the Matronics List Features Navigator to browse_-= the many List utilities such as List Un/Subscription,_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,_-= Photoshare, and much much more:_-=_-=   --> http://www.matronics.com/Navigator?AeroElectric-List
ChangDriver
PostPosted: Thu Jun 11, 2009 4:47 pm    Post subject: Re: IFR Certification Reply with quote
Recently had my Blue Mountain Sport (new install) calibrated and certified. Not an issue.
bakerocb
PostPosted: Fri Jun 12, 2009 4:10 am    Post subject: IFR Certification Reply with quote
6/12/2009
Hello Frank, You wrote: "Why pay twice if you don't have to?"
I agree. To determine if a flight without a transponder is legal go to 14
CFR 91.215.
Also note that permission for a flight without a transponder can be obtained
as described in 91.215 (d).
Time: 07:43:07 AM PST US
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Subject: RE: AeroElectric-List: Re: IFR Certification
Frank
rampil
PostPosted: Fri Jun 12, 2009 6:40 am    Post subject: Re: IFR Certification Reply with quote
My BMA system has served as my encoder for my Mode C for 5 years
in the NYC area. Islip Avionics had absolutely no issue with the certifications. If the boss at your local shop does not understand the
regulations pertaining to OBAM aircraft, find another shop. Especially,
since they would, if they finally elect to do the work, would take twice
as long and charge twice as much!
Ira N224XS
bakerocb
PostPosted: Sat Jun 13, 2009 4:14 am    Post subject: IFR Certification Reply with quote
6/13/2009
Hello Ira, You wrote: "If the boss at your local shop does not understand
the
regulations pertaining to OBAM aircraft, find another shop."
I agree that finding another shop is the best way to resolve this situation.
However outright condemnation of the boss for "not understand(ing) the
regulations pertaining to OBAM aircraft" is not warranted.
1) The issue is not OBAM (amateur built experimental aircraft) versus
standard type certificated aircraft.
2) 14 CFR 91.217 applies equally to both of those kinds of aircraft.
3) The fundamental issue relates to TSO'd versus non TSO'd altitude
encoders.
4) Note that 91.217 applies to flight under VFR as well as flight under IFR.
5) Headquarters FAA is in agreement with the boss's position of not
approving a non TSO'd altitude encoder unless the tests required by 14 CFR
paragraph 91.217 (b) have been accomplished.
6) FAA Headquaters says that the tests required by 91.217 (b) are far more
complex and demanding than the tests required by 91.411 and the associated
appendicies of 14 CFR part 43.
7) Some people dispute FAA Headquarters position on this issue, but no one
to date has adequately challenged them to change their position.
Cool My current recommendations on this issue are:
A) Understand the issues. (Hence this posting to you and fellow builders).
B) Let sleeping dogs lie because if FAA Headquarers really tried to enforce
their position it would cause chaos in the amateur built community because
of the large number of non TSO'd altitude encoders already flying, being
built into aircraft, and being manufactured.
Please let me know if you have any questions. Thanks.
Time: 07:41:50 AM PST US
certifications.
Ira N224XS
bakerocb
PostPosted: Sun Jun 14, 2009 3:25 am    Post subject: IFR Certification Reply with quote
6/14/2009
Hello Ira, Thanks for your input. You wrote:
1) "For VFR into B, C airspace the BMA should be fine according to my
reading of the regs."
Note that the wording of 14 CFR 91.217 makes no distinction between the
requirement for either a TSO'd altitude encoder (91.217 (c)) or a tested
altitude encoder (91.217 (b)) for mode C operations (automatic pressure
altitude reporting equipment) under IFR or VFR.
Further, no class of airspace is excluded from the requirements of 91.217 by
the wording therein.
Can you cite some regulation that says otherwise?
2) "I treated my airframe to a brand new Sandia SAE5-35 TSO'd blind
encoder."
A valid solution. When people have attempted to get the assistance of EAA to
change / clarify FAA Headquarter's position on this subject that is what EAA
has recommended -- just install a TSO'd altitude encoder.
Time: 10:35:39 AM PST US
Actually I didn't condemn the boss, I simply referenced the boss
as the key to the problem. I am familiar with the issues you raised
which is why when finally got IFR certification for myself, I treated
my airframe to a brand new Sandia SAE5-35 TSO'd blind encoder.
Ira N224XS
