Measuring voltage on aircraft and engine sensors?
PostPosted: Thu Jun 11, 2009 6:17 am    Post subject: Measuring voltage on aircraft and engine sensors? Reply with quote
At 02:11 PM 6/10/2009, you wrote:
--> AeroElectric-List message posted by: "mosquito56" <mosquito-56(at)hotmail.com>
I am trying to connect my aircraft to a microcontroller and some adc's.
Will a hall effect rpm sensor work on 5vdc?
Get the data sheet for the sensor you plan to use.
The HE devices I've used in the past to look at
shaft rpms were quite happy with 5v supply. I
suspect most are but the manufacturer's data
sheet is the last word.
Are the oil temp and oil pressure sensors just pots?
I presume you're building from scratch. Temperature
and pressure sensors come in lots of flavors.
I personally favor the use of thermocouples for
all temperature measurements. These are most
easily adapted to the 5v microprocessor world
with thermocouple conditioning chips like the
AD594 series.
http://www.mne.psu.edu/sommer/me445/AD594_5_c.pdf
But there are numerous other products using
thermo-resistive sensors to choose from. The
nice thing about thermocouples is that they're
calibrated right off the roll of wire. Pressure
transducers these days are usually amplified
piezo-resistive device like . . .
[img]cid:7.1.0.9.0.20090611090552.01d28c30(at)aeroelectric.com.0[/img]
These can be pretty pricey compared to the automotive
devices that behave pretty much like a rheostat.
[img]cid:7.1.0.9.0.20090611090552.01d28c30(at)aeroelectric.com.1[/img]
You can adapt about anything to your task when
starting from a clean piece of paper.
( -Thomas Paine 1776- )
 Filesize:  41.32 KB
 Viewed:  2118 Time(s)
 Filesize:  8.19 KB
