longg(at)pjm.com Guest
Posted: Tue Jun 09, 2009 1:25 pm Post subject: Canopy Switch |
I want to add a canopy (open) warning switch to my Lanciar Legacy. I've
got a Dynon 180 which handles all the high tech stuff but I need the
appropriate switch and vendor information from which to source it.
Naturally the switch should be low profile or recessed and perhaps be
adjustable in depth such that it could be adjusted to the canopy
tightness.
The premise of the Dynon is to alert via a contact light of a normally
closed or normally open item. Basically if it's grounded, it closes the
switch and allows the turns the light green.
If you have completed such an installation I'd be glad to hear of what
switch you used and related frustrations if any.
Thanks in advance,
Glenn
frank.hinde(at)hp.com Guest
Posted: Tue Jun 09, 2009 1:53 pm Post subject: Canopy Switch |
Personally I would use a buzzer from Radio shack instead of a light so it works in bright sunlight.
Don't know if the Dynon will drive a buzzer or not but you might just avoid the Dynon altogether and run the buzzer through the switch.
I'm assuming here you want a warning that you left your master on?...if so you could wire the switch such the ground path goes thru the master switch.
If you just want a canopy open switch (not sure what value it really has?) then you can just wire a simple circuit thru the buzzer or light your choice.
Either way there is not much point in going through the Dynon.
Frank
RV7a D100 and Ems10
I want to add a canopy (open) warning switch to my Lanciar Legacy. I've got a Dynon 180 which handles all the high tech stuff but I need the appropriate switch and vendor information from which to source it.
Naturally the switch should be low profile or recessed and perhaps be adjustable in depth such that it could be adjusted to the canopy tightness.
The premise of the Dynon is to alert via a contact light of a normally closed or normally open item. Basically if it's grounded, it closes the switch and allows the turns the light green.
If you have completed such an installation I'd be glad to hear of what switch you used and related frustrations if any.
Thanks in advance,
Glenn
Posted: Tue Jun 09, 2009 5:51 pm Post subject: Canopy Switch |
Frank,
Thanks for your ideas. No, actually I want what I asked for, a canopy alert light, not a "I forgot the master" warning light. The Dynon has some great contact display features that allow one to connect gear down, canopy open type things. When I'm ready to launch I'm looking strait at the EFIS and should see a big red light. You are correct, the sun can be a factor, but in PA where I live, rarely so. The probability of forgetting the canopy on a sunny day in PA is probably much less than forgetting it on an overcast day.
The buzzer is a great idea, but does one really want the buzzer in your ears anytime the master is on and you are running around in sweat with the canopy in tilt position?
I will stick to trying to find the right switch for mounting on the canopy jam.
Glenn
From: owner-aeroelectric-list-server(at)matronics.com on behalf of Hinde, Frank George (Corvallis)
Sent: Tue 6/9/2009 5:47 PM
Subject: RE: Canopy Switch
--> AeroElectric-List message posted by: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Frank
RV7a D100 and Ems10
Thanks in =======================
href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.Same great content also available via the Web href="https://exc03wwp.corp.ds.pjm.com/f5-w-687474703a2f2f666f72756d732p; - List Contribution Web bsp; -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
tim2542(at)sbcglobal.net Guest
Posted: Tue Jun 09, 2009 6:53 pm Post subject: Canopy Switch |
Glenn, if you think the buzzer is a good idea but have the concern you mentioned, just install a second switch on the throttle. If the canopy is open and the throttle is opened more than enough for taxi….you get the idea.
Tim Andres
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of longg(at)pjm.com
Sent: Tuesday, June 09, 2009 6:50 PM
Subject: RE: AeroElectric-List: Canopy Switch
Frank,
Glenn
Frank
RV7a D100 and Ems10
http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
No virus found in this incoming message. Checked by AVG - www.avg.com 270.12.59/2165 - Release Date: 06/09/09 05:53:00 [quote][b]
ianxbrown
Posted: Tue Jun 09, 2009 7:18 pm Post subject: Canopy Switch |
Simple switches that can be either normally open or normally closed are
those that are used on housing security systems. GE makes a line of
pressure operated switches like that, that fit into window frames.
An appropriate choice might depend on the area where you intend to mount
the switch, and the how small it needs to be.
Ian Brown
Bromont
Quebec
On Tue, 2009-06-09 at 21:50 -0400, longg(at)pjm.com wrote:
| Quote: | Frank,
canopy jam.
Glenn
______________________________________________________________________
the master switch.
your choice.
Frank
RV7a D100 and Ems10
tightness.
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Wed Jun 10, 2009 7:37 am Post subject: Canopy Switch |
The RV-10 guys have the same issue and can have a really bad day if they
launch without the doors being latched. I've got two friends with RV-10s
that have switches that are triggered by the door pins. I can't give you
part numbers but check the RV-10 sites. I think they are 3rd party and not
Van's.
Greg Young
[quote] --
phil(at)petrasoft.net Guest
Posted: Wed Jun 10, 2009 1:15 pm Post subject: Canopy Switch |
I put a switch on the canopy latch of my RV-7. It indicates that the
canopy is "closed and latched." I don't remember the part number of
the switch but it was just a tiny little limit switch. it has worked
well for 180 hours. Occasionally it even reminds me to close the
canopy.
There are a couple of pictures here...
http://www.myrv7.com/viewlog.php?year 05&month
Any switch that is a SPDT should work for what you want to do, I
seriously doubt that the detection circuit carries more than a few
milliamps. You just need to find one that fits the geometry.
Phil
On Jun 9, 2009, at 4:23 PM, <longg(at)pjm.com> <longg(at)pjm.com> wrote:
I've
tightness.
the
Thanks in advance,
Glenn
bcondrey
Posted: Wed Jun 10, 2009 6:52 pm Post subject: Re: Canopy Switch |
The mechanism referred to in RV-10s is a simple magnetic reed switch arrangement. There is a magnet in each door pin and the reed switches mounted in the door frames.
Bob
RV-10 N442PM
Posted: Thu Jun 11, 2009 6:12 am Post subject: Canopy Switch |
Thanks to all for the suggestions. It sounds like the best solution is
to find a switch that fits the geometry of my latch and work it from
there (more fun there). I'm also checking on a pitot pressure switch or
throttle up switch as a backup.
Glenn
