Erich_Weaver(at)URSCorp.c Guest
Posted: Tue Jun 09, 2009 8:07 am Post subject: RF interference |
In my last post I said: "This all seems strange to me as there are many RVs with similar equipment(SL-40 comm, GRT EFIS/EIS)and wiring(Z-13/8)that
have my problem." Meant to say "....that DONT have my problem". Makes more sense that way eh?
Got a private email from a List follower inquiring about the 'device' referenced in my earlier post - it allows use of a handheld comm on the main ships antenna for emergency use. Bob reviewed this product some time ago and seemed to think it was satisfactory. Here is a link to it
http://www.edmo.com/index.php?module=products&func=display&prod_id=19280&cat_id
You will likely want to also get a patch cord to allow you to hook up your headset to the handheld to make it easier to hear/transmit
erich [quote][b]
Posted: Tue Jun 09, 2009 2:49 pm Post subject: RF interference |
At 10:57 AM 6/9/2009, you wrote:
| Quote: | In my last post I said: "This all seems strange to me as there are many RVs with similar equipment(SL-40 comm, GRT EFIS/EIS)and wiring(Z-13/8)that
http://www.edmo.com/index.php?module=products&func=display&prod_id=19280&cat_id [/u]
[/b]
I really don't like those things . . . they use
a miniature phone jack that looks like #2 in the
view below.
[img]cid:.0[/img]
It features a normally closed switch strut to
provide "feed through" of antenna connection to
the panel mounted comm. This "switch" is low
pressure, exposed to atmosphere and not terribly
reliable. If the thing gives you problems, the
intermittent will be with the panel mounted
radio.
I would prefer/recommend breaking into a coil
bit of slack in your regular comm antenna coax.
You shouldn't have to do this very often which
offsets the inconvenience.
( -Thomas Paine 1776- )
39.63 KB |
2533 Time(s) |
