Posted: Fri Jun 19, 2009 3:57 pm Post subject: brake line fitting |
Hi guys...
By any chance, can anyone give me the size of the brake line fitting
which threads into the master cylinder?
I'm wanting to switch out the Europa-provided master cylinder and
lever for a Harley-Davidson lever/cylinder which would mount on the
control stick which requires a 10 mm fitting on the end of the brake
line; I'd like to continue to use the Europa-provided brake line.
FWIW, the H-D part # is a 45013-93A (lever/master cylinder) along w/ a
#45044-82 (clamp for a 1" dia. handle), and also requires two #4015
(bolts); quoted price was $169. and change.
This component weighs 1.5 lbs. I went looking for alternatives after
being quoted $375. for the HOPE mountain bike unit, the price seeming
to be a bit over the top.
Fred
A194
believed to be clean.
mikenjulie.parkin(at)btin Guest
Posted: Fri Jun 19, 2009 9:21 pm Post subject: brake line fitting |
Fred,
Did you look at this one......
http://mcylulm.free.fr/doc/pdf/maitre_cyl_a_main.pdf
I did bin the europa plastic hose for some stainless braided hose that came
with the master cylinder. Much better solution.
regards,
Mike
johnwigney(at)windstream. Guest
Posted: Sat Jun 20, 2009 6:43 am Post subject: brake line fitting |
Hi Mike,
Thanks for the link to the MDO Aircraft brake fitting. It seems to be
just what I am looking for. I have never been very happy with the
standard brake master cylinder set up on my mono and this appears to be
quite elegant. For those who need help with the French, Babelfish gives
the following translation which can be decoded fairly easily.
MASTER CYLINDER OF BRAKE “TO THE HANDLE” Weight: 265 G Price: 184€ (1207
FF) Envisaged to be gone up vertically on the handle, it comprises one
tank integrated to optimize its obstruction. A device of blocking makes
it possible to fulfill the function “brake of park” Its assembly is easy
using a support which makes it possible to fix it on handle.
APPLICATIONS: This master cylinder is particularly used on mono
apparatuses coils (Europa or sailplane); he equips also the machines has
combined caster for which directing braking is not necessary. BODY:
Built out of alloy 5754, C `is a part entirely machined in the anodic
mass then. It is reamed has a diameter of 12.5 mm in order to realize an
optimal reduction with clamps MDO PISTON: Out of light alloy high
efficiency, (7075 A), it receives one anodization lasts which enables
him to support a great number of operations under constraint. The
sealing is entrusted has a set of cups in assembled EPDM out of tandem.
TANK: Integrated into the body of the transmitting cylinder, it forms
integral part of the unit. It is equipped with a visible gauge of level
with outside. LID: Out of light alloy (2017 A) anodic of red color, it
is provided with a joint and an opening of vent. BRAKE OF PARK: After
the pressurization of the circuit by the lever the main thing, an
eccentric has hand drive operation comes to immobilize it in its
position. A simple news pressure on the lever releases it its thrust.
By the way on another subject, I have now flown 53 Young Eagles in my
trusty Europa. See http://www.eaa.org/youngeagles/
Cheers, John
N262WF, mono XS, 912S
Mooresville, North Carolina
ORIGINAL MESSAGE
From: "Mike Parkin" <mikenjulie.parkin(at)btinternet.com>
Subject: RE: brake line fitting
Fred,
http://mcylulm.free.fr/doc/pdf/maitre_cyl_a_main.pdf I did bin the
europa plastic hose for some stainless braided hose that came with the
master cylinder. Much better solution. regards, Mike
Posted: Sat Jun 20, 2009 8:40 am Post subject: brake line fitting |
On Jun 19, 2009, at 10:20 PM, Mike Parkin wrote:
Mike...very elegant indeed. Re: the brake line, I take it that the included braided hose was long enough for your installation...(?).
And John...thanks for the translation to English...not quite so elegant, but valuable and amusing!
Fred
A194
-- This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean. [quote][b]
