tank size
europa(at)pstewart.f2s.co
PostPosted: Tue Jun 09, 2009 1:51 am    Post subject: tank size Reply with quote
anyone tell me total fuel capacity and reserve side capacity.
regards
Paul
G-GIDY
raimo.toivio(at)rwm.fi
PostPosted: Tue Jun 09, 2009 2:13 am    Post subject: tank size Reply with quote
I assume I have 68 liters including 9 liters reserve side.
Raimo OH-XRT 117 hrs
- almosto too happy with Airmaster and Trio
nwcmc(at)tiscali.co.uk
PostPosted: Tue Jun 09, 2009 5:31 am    Post subject: tank size Reply with quote
It will vary. Not just between individual tanks but with time. My total
tank started out at 69 litres and swelled to 75 litres and then finally
stabilised at 76 litres.
Nigel Charles
loboloda(at)execulink.com
PostPosted: Tue Jun 09, 2009 6:28 am    Post subject: tank size Reply with quote
I just emptied my tank and re-filled 5 litres at a time to calibrate
a fuel gauge.
Topped out at 65 litres, although I might have had a 5% or so
overfill with each 5 litre input.
Dave C-FBZI
regards
Paul
G-GIDY
jpg12305
PostPosted: Sat Jun 13, 2009 10:27 am    Post subject: Re: tank size Reply with quote
I get 65 liters total, 7 liters reserve.
It seems there is significant variability here....
Jean-Paul
Monowheel 332
paul.the.aviator(at)gmail
PostPosted: Sat Jun 13, 2009 11:50 am    Post subject: tank size Reply with quote
Hi Jean-Paul & others
I measured mine last year and I seemed be able to get a little more in after 4 years of "bulging and sagging" of the tank. I came us with 19.1 US Gallons which is 72 liters in total.
Paul
jpg12305
PostPosted: Fri Jun 19, 2009 9:40 am    Post subject: Re: tank size Reply with quote
BTW I observed a nasty issue when leaving the aircraft outside on a warm day, tank full (or close to).
Fuel spills off the vent, for what I presume being a significant quantity (taints the paint, and significant traces on the ground).
This drove me to the assumption that a significant empty space remains over the fuel, due to fuselage pitch on ground (3 wheels Europa's may not exert that). With warming, vapor tension increases and push fuel out into the vent.
I feel this ceiling space is wasted, on top of the spillage issue. Probably a tube extending front from the vent port into the tank could permit carrying more fuel, while avoiding the warming issue.
Has anyone already experienced and solved that?
Many thanks in advance,
Jean-Paul
frans(at)paardnatuurlijk.
PostPosted: Fri Jun 19, 2009 10:14 am    Post subject: tank size Reply with quote
You could use the same outlet, if you attach a small copper pipe to it,
extending to the upper front of the tank. I'm doing that, because the
tri-gear, while sitting on its trailer, is also resting with its tail
down, and filling the tank while driving to the airport would give me
the same problem.
Frans Veldman
jrgowing(at)bigpond.net.a
PostPosted: Fri Jun 19, 2009 4:44 pm    Post subject: tank size Reply with quote
Is vibration going to crack off the pipe?
JR (Bob) gowing UK Kit 327 in Oz
jpg12305
PostPosted: Fri Jun 19, 2009 10:03 pm    Post subject: Re: tank size Reply with quote
The solution is actually in the latest CBM-16 build manual I got from the Europa website. Embarassed
The vent fitting F09B mounting instructions now clearly shows that a 30cm aluminium extension tube must be bonded with Redux.
This was not mentioned in my original Classic manual, and I just need to go for a retrofit.
pjeffers(at)talktalk.net
PostPosted: Sat Jun 20, 2009 1:08 am    Post subject: tank size Reply with quote
Hi,
I think many of us have seen this issue of fuel venting on warm to hot days
due to air/fuel vapour expansion.
The cure (and it works fine) is to route the vent pipe from the tank, to the
filler neck instead of the roof vent tube. Thus as fuel tries to vent
overboard, as in the past, it now vents back into the tank. Saves the mess
on the paintwork and also saves precious fuel!!!
You will however still need to vent the tank, so a further connection into
the filler neck now needs to be connected to the roof vent tube.
A further refinement used by some is to move the roof vent tube to the
bottom of the fuselage instead of the top. This later part of the mod
ensures that if for any reason the aircraft ends up inverted, fuel does not
run freely from the vent tube as it would if it remained on top of the
fuselage.
I think you will find this fix simple and very effective.
Pete Jeffers
grahamsingleton(at)btinte
PostPosted: Sat Jun 20, 2009 8:37 am    Post subject: tank size Reply with quote
Peter Jeffers wrote:
Hi,
fuselage.
Pete Jeffers
 Filesize:  306.25 KB
 Viewed:  13459 Time(s)
houlihan(at)blueyonder.co
PostPosted: Sat Jun 20, 2009 8:55 am    Post subject: tank size Reply with quote
Hi
Would this solution work in the Classic original setup ? assuming you
run the vent pipe to the top of the filler pipe in the alloy receptacle
Tim Houlihan.
> <pjeffers(at)talktalk.net>
> Hi,
> hot days
> to the
> the mess
> into
> does not
> fuselage.
> Pete Jeffers
Checked by AVG - www.avg.com
PostPosted: Sat Jun 20, 2009 9:13 am    Post subject: tank size Reply with quote
Tim
should work fine but not as easy to fit a stub into the hose. Not sure
how I'd do it
Graham
Tim Houlihan wrote:
<houlihan(at)blueyonder.co.uk>
Hi
Tim Houlihan.
>> hot days
>> tank, to the
>> the mess
>> connection int
Tim
On second thoughts, I'd replace the big hose in the Classic with an
aluminium tube, help to get rid of the fuel smell too!
Graham
PostPosted: Sat Jun 20, 2009 1:50 pm    Post subject: tank size Reply with quote
Hi Graham
That sounds like a good idea.
What wall thickness do you think would be required to allow the fuel
hose to be clamped to the alloy tube at the elbow?
Tim
<grahamsingleton(at)btinternet.com>
Tim
Graham
