gareywittich2000(at)yahoo Guest
Posted: Mon Jun 08, 2009 11:17 am Post subject: Filler for unwanted Rivet Holes |
Greetings:
What material have you Builders used to fill in a couple of unwanted holes in the Skin, where a rivet can NOT be placed to plug the hole ????
Is Super-Fil a possible solution ????
Thanks, Garey Wittich Santa Monica, CA
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
lifeofreiley2003(at)yahoo Guest
Posted: Mon Jun 08, 2009 11:52 am Post subject: Filler for unwanted Rivet Holes |
A dab of West Coast 410 mixed with epoxy will do the trick.
-d-
--- On Mon, 6/8/09, gareywittich2000(at)yahoo.com <gareywittich2000(at)yahoo.com> wrote:
lrhelming(at)gmail.com Guest
Posted: Tue Jun 09, 2009 3:36 am Post subject: Filler for unwanted Rivet Holes |
I'd say it depends on the paint you plan to use. Superfil works great for 3-part epoxy based paint like PPG Concept. Just check to be sure whatever filler you use is compatible with the paint you use. Indiana Larry, RV7 300+ hours
On Mon, Jun 8, 2009 at 2:16 PM, <gareywittich2000(at)yahoo.com (gareywittich2000(at)yahoo.com)> wrote:
| Quote: | Greetings:
et="_blank">http://www.matronics.com/Navigator?RV7-List
ttp://forums.matronics.com
In God I Trust.
Typo error == Make that 2-part epoxy paint ( not 3-part ) Indiana Larry
On Tue, Jun 9, 2009 at 6:31 AM, Larry Helming <lrhelming(at)gmail.com (lrhelming(at)gmail.com)> wrote:
| Quote: | I'd say it depends on the paint you plan to use. Superfil works great for 3-part epoxy based paint like PPG Concept. Just check to be sure whatever filler you use is compatible with the paint you use. Indiana Larry, RV7 300+ hours
| Quote: | Greetings:
In God I Trust.
In God I Trust.
