mz(at)cariama.nl Guest
Posted: Wed Jun 03, 2009 12:55 pm Post subject: Stall Warners |
(just kicking up this thread, hoping to find an answer)
Part of Mod 61 (stall warner) is a pressure switch.
Mine has recently started to continiously 'blow the horn', so I believe this could mean one of two things:
1. I have some moist in the tube
2. The switch is starting to decease (corrosion, internal movements getting sticky, who knows...)
I will blow the tubes tomorrow to make sure there is no moist, but I would also like to replace just the switch. Can anybody please tell me where this switch can be bought as a single item? (I haven't tried Europa yet, but I also would like to know other suppliers for this item).
Thanks.
Marcel
Visit - www.EuropaOwners.org
frans(at)paardnatuurlijk. Guest
Posted: Wed Jun 03, 2009 1:23 pm Post subject: Stall Warners |
believe this could mean one of two things: 1. I have some moist in
the tube 2. The switch is starting to decease (corrosion, internal
item).
Something like this could be of help:
http://www.aircraftspruce.com/catalog/inpages/mpl.php
Too bad, I just placed an order at ACS, if I would have known earlier I
could have added it to the order.
BTW, Did you receive my email?
Frans Veldman
Ivor Phillips
They can be had at RS components,
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=0317443
ivor
Thanks.
Marcel
Posted: Wed Jun 03, 2009 1:40 pm Post subject: Stall Warners |
Hi Frans,
I saw that one too, could serve as an alternative I guess.
[quote:1af0ab0845="Frans Veldman"]BTW, Did you receive my email?[/quote:1af0ab0845]
Nope, when did you sent it?
Marcel
kheindl(at)msn.com Guest
Posted: Wed Jun 03, 2009 3:47 pm Post subject: Stall Warners |
the low pressure switch from RS is exactly the same. I assume that Europa buy it from them.
Ivor Phillips
Posted: Wed Jun 03, 2009 10:23 pm Post subject: Stall Warners |
Yes they are the same switch as the Europa one,
same principle as the Carling Toggle switches that can operate up to 10 amp at
250v or 15 amp at 125v
ivor
stranfaer(at)btinternet.c Guest
Posted: Thu Jun 04, 2009 9:10 am Post subject: Stall Warners |
Marcel
The part is indeed available from RS Cpmponents. Also try adjusting it with
screwdriver, and check to make sure you have not pulled off the pipe by
accident and replaced it onto the wrong nozzle (its easily done, I did it
when I fitted it)..
rgds
Dave Joyce
