rv7a(at)cox.net Guest
Posted: Sat Jun 06, 2009 3:05 pm Post subject: Wiring is done but SL-30 comm won't transmit |
I used the bottom half of the Z-13 or I guess the Z-11 drawings. Finally turned on the Master Switch. The good news all the smoke stayed in the wires and the fuses didn't blow. The radio receives loud and clear. The only problem is when I hit the PTT on the SL-30 all I get is a loud squeal, thank goodness ground control didn't know where it was coming from, where do I start looking, using the old look for the simple fixes first? I have the CH stick grips with the PTT in the trigger portion. I'm sure that I'm not the first that has experienced this problem but couldn't find anything in the archives so would appreciate any helpful suggestions.
Jim Thorne
RV-7A CHD
Getting close
floyd wilkes
Joined: 11 Jun 2007 Posts: 39 Location: spring branch, tx
Posted: Sat Jun 06, 2009 3:41 pm Post subject: Wiring is done but SL-30 comm won't transmit |
Jim,
I had the same thing and it turned out to be a shorted antenna cable. Disconnect the cable at both ends and use an ohm meter to determine if the center connector is shorted to the ground. In my case, one of the BNC connectors was shorted.
Hope this helps.
Floyd Wilkes
601XL
_________________ Floyd Wilkes |
Posted: Sat Jun 06, 2009 4:15 pm Post subject: Wiring is done but SL-30 comm won't transmit |
When you hit the trigger, does the SL30 TX light go on - indicating that the mic was keyed?
