Covering system
aslsa.rng(at)gmail.com
PostPosted: Wed Jun 03, 2009 9:25 am    Post subject: Covering system Reply with quote
While I'm removing corrosion and getting ready to alodine the Firestar wings I went looking for fabric covering info on the web and found Stewart Systems series of videos on You Tube. Since I'm always looking for stuff for our EAA chapter's newsletter I put all the links into a Punisher document and then made the attached PDF. Disclaimer: I've never used their products, they are very pricey, and I have no commercial interest or emotional investment in them. I'm sending it only because I found it interesting.
If nothing else it'll give time to bury the dead horse about props that's been beaten, well, to death. Of course you haven't covered gear box ratios, fancy tips like the Prince, or ducts, so there's hope for the deceased trotter, yet. Smile
Rick
Covering_Videos.pdf
 Filename:  Covering_Videos.pdf
 Filesize:  127.35 KB
 Downloaded:  334 Time(s)
JetPilot
PostPosted: Wed Jun 03, 2009 11:34 am    Post subject: Re: Covering system Reply with quote
As I have said before, anything labeled " Eco " usually means does not work very well. Cleaners, paints, you name it, when they come up with the " Eco Friendly " version, it is usually not as strong and not as good as the non eco friendly stuff...
Seems that labeling a product " ECO " is a good way of selling a substandard product that would never sell on its own merits. Even if this eko friendly system was cheap, I sure as heck would not want my airplane to be the test case for this.
Mike
Kolb MK-III Xtra, 912-S
